USB Storage device problem
I just got a 400G HD-D2-U2 USB storage device. Whe I plug it into the usb port the computer sees it but it doesnt show up in My Computer so I cant use it. How do I get to this thing? Its supposed to be plug and play with windows XP.....
Thanks.
Thanks.
Tex
Tex just told you what to do. Go into Manage on the My Computer context menu then go to Disk Management. Partition the Drive (it will be the 400 Gig one without a letter assigned to it and no filesystem listed next to it) and then format it.
That did it. Thanks much.....
