Regular hose clamps for swiftech radiator?
Ok, my pump started leaking, I rma'd it, got it back, put everything back together, and decided to reroute some of the tubes, and after taking off the little clickey hose clamp they include with their systems, I havesince been unable to get it back together. I'm wondering if I can use the regular plumbing tyoe hose clamps that just get tighter as you turn the screw?
2. wrap a layer of tape (electrical) over they end of the tube (under the clamp) other wise you will tear the tubing.
I'll remember to wrap the tube in a layer or 2 of electrical tubing to prevent tears.
thanks guys.
