black and white to locked graphics problem some one please help
edited March 2010 in Gaming
hi iv got black and white 2 my pc is brand new and up to spec with 2gig of ram intel extreme processer and ati radeon 9750 but for some reason when i try and change the video graphics through custom it wont let me can some one please help
    edited October 2005
    From the other thread:
    AFAIK, the game automatically determins what your video card can actually run, but there's a config file you can edit. I had to do that so I could lower the settings and be able to play. It overestimated my card.
    The file is: "x\Lionhead Studios\Black & White 2\Data\graphics.config" ("x" being the drive and folder it's installed. If it's in the default directory, just add the "C:\Program Files"). Open it with notepad.
  • edited October 2005
    thx very much worked like a charm
  • dronenglishdronenglish Baltimore
    edited March 2010
    I have a very new computer:
    Windows 7 64-bit
    i7 2.6 x4
    6G RAM
    RADEON 5770
    Locked options here too, opened config and...
    All threes down column 1.
    Zeros down column 2.
    And threes down column 3.
    Unlocked options!
    THANK YOU!
  • edited March 2010
    Windows 7 64-bit
    i7 2.6 x4
    6G RAM
    RADEON 5770
    Unlocked options!
    THANK YOU!
    Thank You that worked for me and my Radeon hd 5850
