water cooling question
I want to use a Swiftech Storm Waterblock on an Athlon 64x2 4800+ and an undetermined VGA block for a 7800gtx. I am using a 317GPH pump with 1/2" id tubing, and 2 120mm radiators. The CPU block is supposed to have high pressure to work properly, and I don’t want to chain the VGA and CPU blocks together in series. If I use a standard Y splitter I’m afraid I will loose too much pressure in the CPU block. Is there some kind of Y flow valve I can use to slightly restrict the flow to the VGA block, or should I not worry about it? Any suggestions would be great
I wouldn't worry about it loosing pressure. I dont think it will make much of a difference.
http://www.voyeurmods.com/index.php?action=item&id=1001&prevaction=category&previd=2&prevstart=0
the eheim is a great pump, its quiet, and will be more than enough to push through that loop. it has removable barbs so you can replace the stock 1/2 in with 1/4 in without much problem. remember to use silicon tape on teh threads though your youll have like problems
i have another question lol. what is the best way to keep 5/8" OD tubing from kinking on curves? im going to use some elbow joints to help, but i dont want to use too many.
i was lookin at the site for the company that makes the stuff, and they have all kinds. what specifically should i get and where should i get it? fyi, i would like clear tubing since im using UV coolant.
i looked around and i cant find tygon anymore, i have used clearflex myself as well and hear that it is made of the same formula. it works just as well. ive bought from voyeurmods and they're a good supplier. one of the cheapest prices as well.
http://forums.procooling.com/vbb/showthread.php?goto=lastpage&t=12203
