wireless problems
BudBud Chesterfield, Va
edited October 2005 in Nerdery
i have a wireless setup in my house. It consists of a linksys wireless g router and one computer on the wireless whuch has a linksys wirless g pci adapter. What happens is my computer just drops the connection and doesnt reconnect unless i hit repair. Also my computer is runnign xp pro w/ SP2. The router does not have wep, mac adreess filtering, or anything like that. Any ides what could be causing the problems
  • zero-counterzero-counter Linux Lubber San Antonio Member
    edited October 2005
    What frequency is your home phone and/or other wireless products running on?
  • tmh88tmh88 Pittsburgh / Athens, OH
    edited October 2005
    I had the same problem, so we bought a new phone and it works fine. Since then i convinced my parents to switch to a wired network which is alot better. no more losing connections in hte middle of games for me ;D .
  • BudBud Chesterfield, Va
    edited October 2005
    the phones are 900MHz
    edited October 2005
    What about location? Are the router and/or NICs anywhere near power sources, microwaves, wireless headsets/game controllers? Are you in a heavy network traffic area for wireless networks? If you try searching for other wireless lans in your area, you may find more traffic as in my them broadcasting their SSIDs. You could also try changing the channels on your router, also move the router to a central point of the house. The walls and other electronic devices play big roles in communcation. Set you pre-amble to a shorter one and see if there is any difference. Also make sure that your XR mode is enabled. Dropping the speed tends to help some in wireless situations.
