water cooling nightmare
well, im workin on the 3 grand system, and for 3 days now ive been leak testing the water cooling system. satisfied with the results, i added the uv coolant and powered it on. was working great. last night sometime the reservoir sprung a leak and the entire inside of the case got sprayed while it was running. i came down stairs and noticed the system was off. the thing is, its not my system. im building it for someone. whats the best way to do a cleanup on something like this. please help!
that really sucks, man.
The only thing I can suggest is let it dry thoroughly, and see if it works.
I read a few success stories on this same subject during the week.
the mainboard is pretty clean, as are the hard drives and the psu. the 7800GTX is probably screwed. there is corrosion on the solder points for the 12v connector, and weird looking bubbly brown and black $hi7 on it. i have yet to open up the dvd burners. in the mean time, the store i got the reservoir from has agreed to exchange it for a non leaky one.
if ya want it done right...
My old v180 cell phone got put through an entire cycle in the washing machine one time. It was power ON before it went in, and when it came out it was OFF. I let it dry out, and it DID power back on. There's still hope for you!
