Options
Need help cleaning up
My system seems to be running fairly clean but spybot and MS antivirus keep finding and deleting the same keys.
Look2Me.BM2: Settings (Registry key, fixed)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{DDFFA75A-E81D-4454-89FC-B9FD0631E726}
Huntbar: Settings (Registry key, fixed)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{87067F04-DE4C-4688-BC3C-4FCF39D609E7}
Wind Updates: Code storage database (Registry key, fixed)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{15AD4789-CDB4-47E1-A9DA-992EE8E6BAD6}
please help
here is my hijackthis log
Logfile of HijackThis v1.99.1
Scan saved at 4:11:50 PM, on 11/15/2005
Platform: Windows 2000 SP4 (WinNT 5.00.2195)
MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
Running processes:
C:\WINNT\System32\smss.exe
C:\WINNT\system32\winlogon.exe
C:\WINNT\system32\services.exe
C:\WINNT\system32\lsass.exe
C:\WINNT\system32\svchost.exe
C:\WINNT\system32\spoolsv.exe
C:\PROGRA~1\SYMANT~1\SYMANT~1\DefWatch.exe
C:\WINNT\system32\cmd.exe
C:\WINNT\System32\svchost.exe
C:\Program Files\Vantage\WebPoint\Home.exe
C:\PROGRA~1\SYMANT~1\SYMANT~1\Rtvscan.exe
C:\WINNT\system32\stisvc.exe
C:\WINNT\System32\WBEM\WinMgmt.exe
C:\WINNT\Explorer.EXE
C:\WINNT\System32\hkcmd.exe
C:\Program Files\Symantec_Client_Security\Symantec AntiVirus\vptray.exe
C:\Program Files\Microsoft AntiSpyware\gcasServ.exe
C:\Program Files\QuickTime\qttask.exe
E:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
C:\Program Files\Microsoft AntiSpyware\gcasDtServ.exe
C:\WINNT\explorer.exe
E:\Program Files\ACAD2000\acad.exe
E:\Program Files\Microsoft Office\Office\EXCEL.EXE
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\WINNT\REGEDIT.exe
E:\spy removers\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,SearchAssistant = http://
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = http=localhost:3118
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = 127.0.0.1
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - E:\PROGRA~1\SPYBOT~1\SDHelper.dll
O4 - HKLM\..\Run: [IgfxTray] C:\WINNT\System32\igfxtray.exe
O4 - HKLM\..\Run: [HotKeysCmds] C:\WINNT\System32\hkcmd.exe
O4 - HKLM\..\Run: [vptray] C:\Program Files\Symantec_Client_Security\Symantec AntiVirus\vptray.exe
O4 - HKLM\..\Run: [gcasServ] "C:\Program Files\Microsoft AntiSpyware\gcasServ.exe"
O4 - HKLM\..\Run: [Synchronization Manager] mobsync.exe /logon
O4 - HKCU\..\Run: [SpybotSD TeaTimer] E:\Program Files\Spybot - Search & Destroy\TeaTimer.exe
O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\WINNT\system32\msjava.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\WINNT\system32\msjava.dll
O16 - DPF: {00000075-0000-0010-8000-00AA00389B71} -
O16 - DPF: {00000075-9980-0010-8000-00AA00389B71} -
O16 - DPF: {11B2C0D3-DFFB-11D3-9253-00500498D7E5} (ShowSetupObj5 Class) - http://invite.mshow.com/(hg0tic45skmueg453t4wzu45)/ShowSetup5.cab
O16 - DPF: {31564D57-0000-0010-8000-00AA00389B71} -
O16 - DPF: {32564D57-0000-0010-8000-00AA00389B71} -
O16 - DPF: {33564D57-0000-0010-8000-00AA00389B71} -
O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) - http://security.symantec.com/sscv6/SharedContent/common/bin/cabsa.cab
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1127406080296
O16 - DPF: {74D05D43-3236-11D4-BDCD-00C04F9A3B61} -
O16 - DPF: {AB86CE53-AC9F-449F-9399-D8ABCA09EC09} -
O16 - DPF: {BA83FD38-CE14-4DA3-BEF5-96050D55F78A} -
O23 - Service: AutoExNT - Unknown owner - C:\WINNT\system32\AutoExNT.Exe
O23 - Service: DefWatch - Symantec Corporation - C:\PROGRA~1\SYMANT~1\SYMANT~1\DefWatch.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: Symantec AntiVirus Client (Norton AntiVirus Server) - Symantec Corporation - C:\PROGRA~1\SYMANT~1\SYMANT~1\Rtvscan.exe
  • TroganTrogan London, UK
    edited November 2005
    Hi,
    Please move HJT to its own folder on your C: so backups can be created. Do this before continuing.
    Check the following in HJT and click 'Fix Checked'
    Download CWShredder 2.15 from here. Check for updates first and then Run it and press the *fix,* not scan and allow it to clean the infection. Close all browser and explorer windows before hitting the fix button.
    Enable everything on startup
    • Go to Start > Run > Type msconfig
    • Click the Startup Tab
    • Click Enable All
    • Reboot when prompted
    Post a new HJT log :)
  • edited November 2005
    Ok here is the scoop. I deleted all but one of the O16. Unless you are sure that the following is a problem I feel I should keep it. I use mshow for web conf.
    I scaned with CWShredder 2.15 and it found no infections.
    I get a error using msconfig.
    Cannot find the file 'msconfig'......bla,bla,bla
    Is there a service I need to enable?
    Here is my new Hijack this file.
    Scan saved at 4:09:13 PM, on 11/16/2005
    Running processes:
    C:\HijackThis.exe
    O16 - DPF: {1C955F3B-5B32-4393-A05D-24B4970CD2A1} -
    If you want to keep that O16 entry, then thats fine. I couldn't find any info on it, thats why I decided to remove it.
    I'm not sure why msconfig isn't working. You probably have a file missing - not service to enable.
    We'll need to unload Spybot's Teatimer before we begin. To do this can you start Spybot and go to Tools > Resident and uncheck the box next to Tea-Timer. Make sure that the icon in the system tray is no longer there. If it is, just right click on it and select "Exit". Do not forget to re-enable it when we are done :).
    Go here and in the box provided, type the following. Then press SUBMIT
    The files will be scanned by various Anti-Virus scanners. Please post the results here.
    Download Ewido Security Suite
    • Install ewido security suite
    • When installing, under "Additional Options" uncheck..
      • Install background guard
      • Install scan via context menu
    • Launch ewido, there should be an icon on your desktop, double-click it.
    • You will need to update ewido to the latest definition files.
      • On the left hand side of the main screen click update.
      • Then click on Start Update.
    • The update will start and a progress bar will show the updates being installed.
      (the status bar at the bottom will display "Update successful")
    • Now, scan with it by clicking 'Scanner' on the left and choosing 'Complete System Scan'
    How are things now?
    I scanned Home.exe no problems found. It is web based control program.
    Ewido found the following
    HKLM\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{15AD4789-CDB4-47E1-A9DA-992EE8E6BAD6} -> Spyware.WinFavorites : Cleaned with backup
    HKLM\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{1C955F3B-5B32-4393-A05D-24B4970CD2A1} -> Dialer.Generic : Cleaned with backup
    HKLM\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{87067F04-DE4C-4688-BC3C-4FCF39D609E7} -> Spyware.WebSearch : Cleaned with backup
    HKLM\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{DDFFA75A-E81D-4454-89FC-B9FD0631E726} -> Spyware.VX2 : Cleaned with backup
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{01F44A8A-8C97-4325-A378-76E68DC4AB2E} -> Spyware.IEPlugin : Cleaned with backup
    HKU\S-1-5-21-943488094-688087463-1210191635-1024\Software\Microsoft\Internet Explorer\Explorer Bars\{50B4D2B3-723F-41B3-AEC4-0BD66F0F45FF} -> Spyware.eZula : Cleaned with backup
    the problem is still around. All's fine until I login, then all the problem files are back again.
    Here is my new hijack this log. (till I restart)
    Scan saved at 4:10:51 PM, on 11/18/2005
    Running processes:
    C:\Program Files\ewido\security suite\ewidoctrl.exe
    C:\Program Files\ewido\security suite\ewidoguard.exe
    C:\WINNT\system32\NOTEPAD.EXE
    O23 - Service: ewido security suite control - ewido networks - C:\Program Files\ewido\security suite\ewidoctrl.exe
    O23 - Service: ewido security suite guard - ewido networks - C:\Program Files\ewido\security suite\ewidoguard.exe
    Remove these with HJT:
    Please download WebRoot SpySweeper from HERE (It's a 2 week trial):
    Click the Free Trial link under to "SpySweeper" to download the program.
    Install it. Once the program is installed, it will open.
    It will prompt you to update to the latest definitions, click Yes.
    Once the definitions are installed, click Options on the left side.
    Click the Sweep Options tab.
    Under What to Sweep please put a check next to the following:
    Sweep Memory
    Sweep Registry
    Sweep Cookies
    Sweep All User Accounts
    Enable Direct Disk Sweeping
    Sweep Contents of Compressed Files
    Sweep for Rootkits
    Please UNCHECK Do not Sweep System Restore Folder.
    Click Sweep Now on the left side.
    Click the Start button.
    When it's done scanning, click the Next button.
    Make sure everything has a check next to it, then click the Next button.
    It will remove all of the items found.
    Click Session Log in the upper right corner, copy everything in that window.
    Click the Summary tab and click Finish.
    Paste the contents of the session log you copied into your next reply.
    What problems are you having?
    To better explain the problems that I am having; I restarted by system before the following scans.
    Basicly, I currently delete most of these files when I start my computer through various methods. The next time I login again all this crap is back. I need to kill the source of these files not just the files themselves.
    spy sweeper log session
    10:59 AM: | Start of Session, Monday, November 21, 2005 |
    10:59 AM: Spy Sweeper started
    10:59 AM: Sweep initiated using definitions version 574
    10:59 AM: Starting Memory Sweep
    11:02 AM: Memory Sweep Complete, Elapsed Time: 00:03:37
    11:02 AM: Starting Registry Sweep
    11:03 AM: Found Adware: ieplugin
    11:03 AM: HKLM\software\microsoft\windows\currentversion\explorer\browser helper objects\{01f44a8a-8c97-4325-a378-76e68dc4ab2e}\ (ID = 128184)
    11:03 AM: Found Adware: websearch toolbar
    11:03 AM: HKLM\software\microsoft\code store database\distribution units\{87067f04-de4c-4688-bc3c-4fcf39d609e7}\ (4 subtraces) (ID = 146454)
    11:03 AM: Found Adware: winad
    11:03 AM: HKLM\software\microsoft\code store database\distribution units\{15ad4789-cdb4-47e1-a9da-992ee8e6bad6}\ (4 subtraces) (ID = 147184)
    11:03 AM: Registry Sweep Complete, Elapsed Time:00:00:50
    11:03 AM: Starting Cookie Sweep
    11:03 AM: Cookie Sweep Complete, Elapsed Time: 00:00:00
    11:03 AM: Starting File Sweep
    11:19 AM: Warning: Failed to access drive E:
    11:19 AM: File Sweep Complete, Elapsed Time: 00:15:29
    11:19 AM: Full Sweep has completed. Elapsed time 00:20:06
    11:19 AM: Traces Found: 11
    11:20 AM: Removal process initiated
    11:20 AM: Quarantining All Traces: websearch toolbar
    11:20 AM: Quarantining All Traces: ieplugin
    11:20 AM: Quarantining All Traces: winad
    11:20 AM: Removal process completed. Elapsed time 00:00:10
    Ewido reports
    ewido security suite - Scan report
    + Created on: 1:16:52 PM, 11/21/2005
    + Report-Checksum: 4394C211
    + Scan result:
    ::Report End
    Hijack this
    Scan saved at 1:19:43 PM, on 11/21/2005
    Running processes:
    C:\Program Files\Webroot\Spy Sweeper\WRSSSDK.exe
    C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe
    C:\WINNT\system32\notepad.exe
    C:\Program Files\ewido\security suite\securitysuite.exe
    O4 - HKLM\..\Run: [SpySweeper] "C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe" /startintray
    O20 - Winlogon Notify: WRNotifier - C:\WINNT\SYSTEM32\WRLogonNTF.dll
    O23 - Service: Webroot Spy Sweeper Engine (svcWRSSSDK) - Webroot Software, Inc. - C:\Program Files\Webroot\Spy Sweeper\WRSSSDK.exe
    After removing what we discussed prev
    Scan saved at 1:22:31 PM, on 11/21/2005
    Running processes:
    Is there a program that lets you type in the Reg keys you what to block?
    What files keep coming back after you reboot? And why is there two different HJT logs?
    There are two HJT logs to show you what files keep coming back after I reboot.
    These
    The last HJT log is valid.
    The last HJT log does not show those O16 entries.
    Can you post one new HJT log please.
    Scan saved at 3:48:53 PM, on 11/22/2005
    Running processes:
    E:\PROGRA~1\MICROS~1\Office\OUTLOOK.EXE
    C:\Program Files\Common Files\System\MAPI\1033\nt\MAPISP32.EXE
    C:\Program Files\Lutron\HomeWorks Interactive\Hwi.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = about:blank
    R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = about:blank
    R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = "C:\Program Files\Outlook Express\msimn.exe"
    R3 - Default URLSearchHook is missing
    O2 - BHO: (no name) - {0000607D-D204-42C7-8E46-216055BF9918} - (no file)
    O2 - BHO: (no name) - {01F44A8A-8C97-4325-A378-76E68DC4AB2E} - (no file)
    O4 - HKCU\..\Run: [H/PC Connection Agent] "C:\Program Files\Microsoft ActiveSync\WCESCOMM.EXE"
    Remove the following with HJT:
    Apart from that, your HJT log is clean.
    How are things running?
