xbox on pc monitor using component cables?
Hey, I was just messing around with my pc and stuff, and I realized that my videocard, ATI x800XL, has an S-video input. It came with an adapter so that i could plug component cables into it, and also audio. So i just realized, if i buy component cables for my xbox (the red, green and blue ones, not yellow, red, and white), will I be able to plug my xbox in and set it to some other hd mode? I have a decent lcd monitor, which is 17", not widescreen though.
When I open up the ATI TV program from ATI media center, it says S-Video Connection, but I dont have any component cables to test wheter or not my xbox will work with it. I'm assuming it will because it plugs in and fits perfectly, but I just want to see what you guys think before i spend $20 on cables. If it does work, can I set the xbox in an hd mode?
If your cards a vivo you should have no problems.
If you have no idea what vivo is you wont beable to do it.
here is the connection im using to get video to my computer
yea im 100% sure
and also should I be using ATI TV or some other program. What other programs will allow me to hook up my xbox using the svideo input that are 3rd party?
