a8n sli wont power up. please help
ishiiiishiii Cold lake, AB, CA
edited December 2005 in Hardware
hi guys
I started setting up my new system tonight, and it wont power up.
the green led on the mobo is illuminated but when i puch the power button nothing happens.
I tried reseating all the power connectors and the pwr sw
a8n sli
amd 64 4000+
ocz platinum 2gb dual channel kit
bfg 7800gt oc
ultra 600watt sli psu
  • QeldromaQeldroma Arid ZoneAh Member
    My first suspicion is that the power button isn't right- like maybe your case button isn't seated properly over the underlying pushbutton. You may also want to trace the wiring from your power button and see that there are no breaks or problems with the wire run. Also make sure that the underlying button isn't stuck.
  • ishiiiishiii Cold lake, AB, CA
    I thought of that, so i used the power button from my current pc. still nothing
    Try resetting the BIOS.
    It would also be a good idea to triple-check which set of pins you're hooking the switch to. I'm sure you've thought of this, but it's so easy to get off by a pin (or on the wrong row). I did this myself just yesterday. :o
    You can also use the tip of a small screwdriver to manually short the two pins together; that's all the switch does for you anyway.
    Good luck. :)
    OK. Can you try the power supply from your old PC?
    EDIT: Good suggestions, prof- do his suggestions first.
    ill try profs then ill try the older psu
    which is my last resort i think
    Also, if there is an extra power connector on the MB and/or the video card make sure you've attached a power lead to them.
    I reset the bios
    i tired other psu
    all connectors are plugged in
    still nothing
    tried the pwr sw in every possible config, with pwr sw from old pc aswell. and the screwdriver trick
    garrr
    nothing
    Unhook everything except the RAM, CPU & HS/F, and Video Card. If you have an old PCI Video Card you can use temporarily go with that.
    Then give it another shot.
  • botheredbothered Manchester UK
    I had a similar prob while building one PC. (shame mode) I'd check the HDD and power LEDs are the right way round or even disconnect them for now. Simple mistake but it stopped it booting.
    it was the power supply, pc is up and running and kicks ass
    Yeah! :D
    Good call, Qeldroma. :thumbsup:
    I have my moments, prof.
    Great, Ishiii! That system should rock!
