Options
Major "SpyAxe" problems....HELP!!!
Web surfer at best that deveolped this horrific virus today. I ran HiJackThis as seen in another discussion. Can someone direct me on what I can do before I wipe out my hard drive? Much appreciated.
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\nvctrl.exe
C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
C:\Program Files\DIGStream\digstream.exe
C:\Program Files\Adaptec\Easy CD Creator 5\DirectCD\DirectCD.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgcc.exe
C:\Program Files\Microsoft AntiSpyware\gcasServ.exe
C:\Program Files\SpyAxe\spyaxe.exe
C:\Program Files\Microsoft AntiSpyware\gcasDtServ.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgamsvr.exe
C:\PROGRA~1\Grisoft\AVGFRE~1\avgupsvc.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\DOCUME~1\Steve\LOCALS~1\Temp\Temporary Directory 1 for hijackthis_199.zip\HijackThis.exe
O2 - BHO: HomepageBHO - {e0103cd4-d1ce-411a-b75b-4fec072867f4} - C:\WINDOWS\system32\hp5BCC.tmp
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
O4 - HKLM\..\Run: [DIGStream] C:\Program Files\DIGStream\digstream.exe
O4 - HKLM\..\Run: [AdaptecDirectCD] "C:\Program Files\Adaptec\Easy CD Creator 5\DirectCD\DirectCD.exe"
O4 - HKLM\..\Run: [AVG7_CC] C:\PROGRA~1\Grisoft\AVGFRE~1\avgcc.exe /STARTUP
O4 - HKLM\..\Run: [gcasServ] "C:\Program Files\Microsoft AntiSpyware\gcasServ.exe"
O4 - HKLM\..\Run: [SpyAxe] C:\Program Files\SpyAxe\spyaxe.exe /h
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll (file missing)
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll (file missing)
O9 - Extra button: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - C:\Program Files\PartyPoker\PartyPoker.exe (file missing)
O9 - Extra 'Tools' menuitem: PartyPoker.com - {B7FE5D70-9AA2-40F1-9C6B-12A255F085E1} - C:\Program Files\PartyPoker\PartyPoker.exe (file missing)
O16 - DPF: {01113300-3E00-11D2-8470-0060089874ED} - http://activation.rr.com/install/download/tgctlcm.cab
O16 - DPF: {12E5E9D9-4366-45D9-BA41-D0BCD55AD8CF} - http://17.sharedsource.org/html/NrsgroupUD_1.0.0.3ie.cab?
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
O16 - DPF: {56336BCB-3D8A-11D6-A00B-0050DA18DE71} (RdxIE Class) - http://software-dl.real.com/26adffc7b93e7f9c4a23/netzip/RdxIE601.cab
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://v5.windowsupdate.microsoft.com/v5consumer/V5Controls/en/x86/client/wuweb_site.cab?1096233972499
O23 - Service: AVG7 Alert Manager Server (Avg7Alrt) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVGFRE~1\avgamsvr.exe
O23 - Service: AVG7 Update Service (Avg7UpdSvc) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVGFRE~1\avgupsvc.exe
O23 - Service: IMAPI CD-Burning COM Service (ImapiService) - Roxio Inc. - C:\WINDOWS\system32\ImapiRox.exe
Running processes:
Can you post the top bit from HJT. It should look like this:
You are currently running HijackThis from here:
Please make a folder here:
c:\HJT
and place HijackThis in that folder.
Post a new HJT log
Logfile of HijackThis v1.99.1
Scan saved at 9:09:19 PM, on 1/2/2006
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\DOCUME~1\Steve\LOCALS~1\Temp\Temporary Directory 2 for hijackthis_199.zip\HijackThis.exe
O2 - BHO: HomepageBHO - {e0103cd4-d1ce-411a-b75b-4fec072867f4} - C:\WINDOWS\system32\hp5C58.tmp
Download smitRem.zip and save the file to your desktop.
Right click on the file and extract it to it's own folder on the desktop.
Place a shortcut to Panda ActiveScan on your desktop.
Please download the trial version of Ewido Security Suite here:
http://www.ewido.net/en/download/
Please read Ewido Setup Instructions
Install it, and update the definitions to the newest files. Do NOT run a scan yet.
If you have not already installed Ad-Aware SE 1.06, follow these download and setup instructions, otherwise, check for updates:
Ad-Aware SE Setup
Don't run it yet!
Next, please reboot your computer in SafeMode by doing the following:
- Restart your computer
- After hearing your computer beep once during startup, but before the Windows icon appears, press F8.
- Instead of Windows loading as normal, a menu should appear
- Select the first option, to run Windows in Safe Mode.
Now scan with HJT and place a checkmark next to each of the following items and click 'Fix Checked':===================================================
O16 - DPF: {12E5E9D9-4366-45D9-BA41-D0BCD55AD8CF} - http://17.sharedsource.org/html/Nrsg...1.0.0.3ie.cab?
Open the smitRem folder, then double click the RunThis.bat file to start the tool. Follow the prompts on screen.
Wait for the tool to complete and disk cleanup to finish.
The tool will create a log named smitfiles.txt in the root of your drive, eg; Local Disk C: or partition where your operating system is installed. Please post that log along with all others requested in your next reply.
Open Ad-aware and do a full scan. Remove all it finds.
Run Ewido:
- Click on scanner
- Click Complete System Scan and the scan will begin.
- [color “red”]NOTE:[/color] During some scans with ewido it is finding cases of false positives.
- You will need to step through the process of cleaning files one-by-one.
- If ewido detects a file you KNOW to be legitimate, select none as the action.
- DO NOT select "Perform action on all infections"
- If you are unsure of any entry found select none for now.
- When the scan is finished, click the Save report button at the bottom of the screen.
- Save the report to your desktop
Close EwidoNext go to Control Panel click Display > Desktop > Customize Desktop > Website > Uncheck "Security Info" if present.
Reboot back into Windows and click the Panda ActiveScan shortcut.
- Once you are on the Panda site click the Scan your PC button
- A new window will open...click the Check Now button
- Enter your Country
- Enter your State/Province
- Enter your e-mail address and click send
- Select either Home User or Company
- Click the big Scan Now button
- If it wants to install an ActiveX component allow it
- It will start downloading the files it requires for the scan (Note: It may take a couple of minutes)
- When download is complete, click on Local Disks to start the scan
- When the scan completes, if anything malicious is detected, click the See Report button, then Save Report and save it to a convenient location.
Post the contents of the Panda scan report, along with a new HijackThis Log, the contents of smitfiles.txt and the Ewido Log by using Add Reply.
Let us know if any problems persist.
