Suround Sound Help
I just put in my new ABIT IS7 Board in, and now I have:
Front Speaker Out
Line In
Mic
Rear Speaker Out
Center/Sub Speaker Out
I also have 2 Fiber Optic connections, but my speakers don't use them.
So anyways, I haven't had Suround Sound before, so I never tweaked with it before. My Speakers are 4.1 Suround SOund from Altec. They have the Front Speaker out, Rear Speaker OUt, and Center/Sub Out.
But when I do the tests, it don't seem to work, and i have it setup in the sound profile as suround sound and all that too. Whats up?
Front Speaker Out
Line In
Mic
Rear Speaker Out
I assume that means that you have your speaker options set like this:
I don't know how to explain it, except that it runs simila to a 2 speaker setup. Except my front and rear speakers work.
For instance when I do the TEST thing, and click on my Front left speaker to play a sound, BOTH my REAR LEFT and FRONT LEFT speakers play the soun, the same goes for the Right Side.
BUT if I push the REAR LEFT speaker to play a sound, no sound comes out.
My sub works fine.
Are they not supposed to all have their OWN sound? this way I can know that a hail of bullets are coming from my back left or my front right, whereever it came from in the game?
You say you actually have 4.1 sound, which mean 4 satellites and a subwoofer (no center channel). Is that correct?
Absolutly no clue...
Either way, I have no sound anymore, I can't figure it out! Driving me nutz, god damned Abit boards always giving me **** when I first buy them. The only reason I continue is becuase they don't give me issues after the first couple days.
The sound was working one moment, then all of a sudden it stops, I cannot find the program either, and when I open the windows setting for sound, it is all greyed out and I cannot select or change crap. WTF?
Works now, but I still don't have surround sound.
I've tried all the different speaker configs listed in Windows in conjunction with all the different speaker configs listed in my drivers. Doesn't seem to do any good, even when I plug the bastard into the Line-In after it supposedly turns to a rear out. *sigh*
If you find a fix, please let me know. I haven't been digging much, but that's only because I haven't had a computer in operating condition for the last week and a half.
Then it's uninstall, clean the registry, reinstall old SB drivers, and swear never to do it again...
Maybe you have something similar going on. Have you tried a different driver?
