IE does not connect?! and more problems!!! URGENT HELP!!
edited March 2006 in Nerdery
everynow and then, aim, winamp, and other programs ask to dial up a connection. And it will not stop, even when i chage it to never dial a connection. Then when igo to IE, it brings the dial a connection thing up and it doens't work. I have a good dsl connection but it still does it. Help please!.. and alsy why does firefox make it so when i want to play something in windows media player, it doesn't work, ten i go to the netowrk properties and set everything to default, and it works, then it changes again. THANK YOU IN ADVANCE!! PLEASE HELP ME!
  • V-PV-P State College, PA Member
    edited February 2006
    Can't hink of what to do about your Internet problem right now, but I use Firefox and I'm pretty sure it's incompatible with Windows Media Player, but there is a plugin somewhere on this site that will allw you to use Windows Media Player with Firefox.
  • edited February 2006
    i alrady have the plugin and everything, but it doens't work becasue of the first part. When i try wathcing a video at like spiekdhumor.com, it drings up the box to dial up to connect , even though im conencted now
    edited March 2006
    Look in Control Panel>>Network Connections and see if there is a reference to a dial-up connection there. If there is, delete it. It may pay to run the Network Setup Wizard again, too.
    I'd also run a Spyware and Virus scan. There are lousy bugs out there which try to dial "900" numbers, etc, which could be messing with your network settings.
    edited March 2006
    WindowsUpdate Media Player also, please. There ae THREE recent updates for it, including Version 10 as the latest update.
  • edited March 2006
    Thank you for telling me to delete the dial up refeercnes, tha seemed to make Internet explorer work, and so far it has not asked me to dial anything again.!! thank you so much!! This cleared up the windows media player problem too, cuase that too wanted to dial up a conenction.
