Need help and some questions...
iHatePopUpsiHatePopUps Singapore
edited March 2006 in Spyware & Virus Removal
I've just installed ZoneAlarm recently, following this forum's recommendations. I noticed that simply 3 days after installing it, 2500+ attempted intrusions have been blocked by it. Is that normal or am i receiving a very high amount of attempted 'break-ins'?
Also, there's this very annoying application that is trying to get access rights to the internet. The application name is "Universa Application" and the files are found in the C:/WINDOWS/temp folder. There are many variations of the filenames too. What exactly are these files/applications? I've blocked all of them seeing that they are in the 'temp' folder. Was I right to do it?
Examples of the filenames are:
win28.tmp.exe
win24.tmp.exe
winA05.tmp.exe
«1
  • TroganTrogan London, UK
    edited March 2006
    You were right to deny access to the Internet for those temp files; it is safe to remove files from inside the temp folder. I just installed ZoneAlarm two days ago and I am getting program popups and such but 2500+ attempts is a bit much.
    If you could post a HJT log, that would help.
    If you have WIN XP, then run this tool to clean your temp folders.
    Download ATF (Atribune Temp File) Cleaner© by Atribune
    http://www.atribune.org/ccount/click.php?id=1
    It is a stand-alone program that does not need to be "installed". Save it to a convenient location and make a shortcut on your desktop.
    Run ATF Cleaner
    Double-click ATF Cleaner.exe
    Under Main choose:
    Windows Temp
    Current User Temp
    All Users Temp
    Temporary Internet Files
    Prefetch
    *The other boxes are optional*
    Then click the Empty Selected button.
    Firefox:
    Click Firefox at the top and choose: Select All
    Click the Empty Selected button.
    NOTE: If you would like to keep your saved passwords, please click NO at the prompt.
    Click Exit on the Main menu to close the program.
    For Technical Support, double-click the e-mail address located at the bottom of each menu
  • iHatePopUpsiHatePopUps Singapore
    edited March 2006
    I've already posted 2 other threads requesting help. One in the Windows section, the other in the Spyware section entitled "SpyFalcon Aftermath" but it is still yet to be replied to by you guys. I'm getting more problems now. In my temp folder there is this irritating file - "ZLT0168e.TMP" which cannot be deleted. Also, the files I mentioned earlier keep reappearing, only with different sets on numbers in the filenames. When they do appear, either i get a ZoneAlarm prompt or the following message occurs:
    ULWindowSeek: win95A.tmp.exe - Application Error
    The instruction at"0x6c371351" referenced memory at "0x00000004". The memory could not be "read". Click on "OK" to terminate the program.
    win95A.tmp.exe is the file that's found in the temp folder. The filename is always different though the error's the same. It could be win09C.tmp.exe or win32A.tmp.exe as an example. These files are constantly appealing to ZoneAlarm for net access using the application name 'Universa Application'. Is there something playing around with my memory? How do i fix this? This is popping up more and more frequently. Also, the number of Blocked Intrusions summerized by ZoneAlarm has reached nearly 6500, with 5 high-rated ones. Do you know what is wrong with my PC? How do i fix this? I'll submit my HJT log below.
    Logfile of HijackThis v1.99.1
    Scan saved at 11:26:04 PM, on 3/11/2006
    MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
    Running processes:
    C:\WINDOWS\System32\smss.exe
    C:\WINDOWS\system32\lsass.exe
    C:\Program Files\ewido anti-malware\ewidoctrl.exe
    C:\Program Files\Common Files\Microsoft Shared\VS7Debug\mdm.exe
    C:\WINDOWS\Explorer.EXE
    C:\WINDOWS\system32\ZoneLabs\vsmon.exe
    C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
    C:\Program Files\BitTornado\btdownloadgui.exe
    C:\Program Files\Internet Explorer\IEXPLORE.EXE
    C:\WINDOWS\TEMP\win97.tmp.exe
    C:\Documents and Settings\Administrator\Desktop\hijackthis\HijackThis.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = about:blank
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.animenewsnetwork.com/
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,SearchURL = about:blank
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = about:blank
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,SearchURL = about:blank
    R1 - HKCU\Software\Microsoft\Internet Explorer\Search,SearchAssistant = about:blank
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page = about:blank
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page_bak = about:blank
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = about:blank
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page_bak = about:blank
    O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\ycomp5_6_2_0.dll (file missing)
    O3 - Toolbar: (no name) - {62999427-33FC-4baf-9C9C-BCE6BD127F08} - (no file)
    O4 - HKLM\..\Run: [Zone Labs Client] C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe
    O8 - Extra context menu item: &Download with &DAP - C:\Program Files\DAP\dapextie.htm
    O8 - Extra context menu item: &Google Search - res://c:\program files\google\GoogleToolbar2.dll/cmsearch.html
    O8 - Extra context menu item: &Search - http://kc.bar.need2find.com/KC/menusearch.html?p=KC
    O8 - Extra context menu item: Backward Links - res://c:\program files\google\GoogleToolbar2.dll/cmbacklinks.html
    O8 - Extra context menu item: Cached Snapshot of Page - res://c:\program files\google\GoogleToolbar2.dll/cmcache.html
    O8 - Extra context menu item: Download &all with DAP - C:\Program Files\DAP\dapextie2.htm
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
    O8 - Extra context menu item: Similar Pages - res://c:\program files\google\GoogleToolbar2.dll/cmsimilar.html
    O8 - Extra context menu item: Translate into English - res://c:\program files\google\GoogleToolbar2.dll/cmtrans.html
    O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll (file missing)
    O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll (file missing)
    O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
    O16 - DPF: {48884C41-EFAC-433D-958A-9FADAC41408E} (EGamesPlugin Class) - https://www.e-games.com.my/com/EGamesPlugin.cab
    O16 - DPF: {9A9307A0-7DA4-4DAF-B042-5009F29E09E1} (ActiveScan Installer Class) - http://acs.pandasoftware.com/activescan/as5free/asinst.cab
    O17 - HKLM\System\CCS\Services\Tcpip\..\{A8842474-7D8D-4371-9462-79560AC4808D}: NameServer = 202.156.1.48,202.156.1.68
    O20 - Winlogon Notify: winuqw32 - C:\WINDOWS\SYSTEM32\winuqw32.dll
    O23 - Service: Apache2 - Unknown owner - C:\Program Files\Apache Group\Apache2\bin\Apache.exe" -k runservice (file missing)
    O23 - Service: ewido security suite control - ewido networks - C:\Program Files\ewido anti-malware\ewidoctrl.exe
    O23 - Service: Macromedia Licensing Service - Macromedia - C:\Program Files\Common Files\Macromedia Shared\Service\Macromedia Licensing.exe
    O23 - Service: MySql - Unknown owner - C:\MySql\bin\mysqld (file missing)
    O23 - Service: OracleMTSRecoveryService - Oracle Corporation - C:\oracle\ora92\bin\omtsreco.exe
    O23 - Service: OracleOraHome92Agent - Oracle Corporation - C:\oracle\ora92\bin\agntsrvc.exe
    O23 - Service: OracleOraHome92ClientCache - Unknown owner - C:\oracle\ora92\BIN\ONRSD.EXE
    O23 - Service: OracleOraHome92HTTPServer - Unknown owner - C:\oracle\ora92\Apache\Apache\apache.exe" --ntservice (file missing)
    O23 - Service: OracleOraHome92PagingServer - Unknown owner - C:\oracle\ora92/bin/pagntsrv.exe
    O23 - Service: OracleOraHome92SNMPPeerEncapsulator - Unknown owner - C:\oracle\ora92\BIN\ENCSVC.EXE
    O23 - Service: OracleOraHome92SNMPPeerMasterAgent - Unknown owner - C:\oracle\ora92\BIN\AGNTSVC.EXE
    O23 - Service: OracleOraHome92TNSListener - Unknown owner - C:\oracle\ora92\BIN\TNSLSNR.exe
    O23 - Service: OracleServiceNARU - Oracle Corporation - c:\oracle\ora92\bin\ORACLE.EXE
    O23 - Service: TrueVector Internet Monitor (vsmon) - Zone Labs, LLC - C:\WINDOWS\system32\ZoneLabs\vsmon.exe
    If there's anything more I can do to help you guys to help me, please let me know. The problems are becoming more frequent as time passes. Hope you'll reply with help soon.
    edited March 2006
    Notice that the HJT log has the process "C:\WINDOWS\TEMP\win97.tmp.exe". That's the process that's annoying.
    edited March 2006
    Please don't get discouraged. I notice that you have some things disabled on startup, could you please enable them and then post a new HJT log.
    • Go to Start > Run > Type msconfig
    • Click the Startup Tab
    • Click Enable All
    • Click Apply and then Close
    • Reboot when prompted
    edited March 2006
    Here's the new log:
    Scan saved at 1:35:13 PM, on 3/12/2006
    Running processes:
    C:\MySql\bin\mysqld.exe
    C:\WINDOWS\system32\cmd.exe
    C:\oracle\ora92\bin\dbsnmp.exe
    C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
    C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
    C:\Program Files\Nokia\Nokia PC Suite 6\LaunchApplication.exe
    C:\oracle\ora92\bin\oradim.exe
    C:\Program Files\DAP\DAP.EXE
    C:\Program Files\Common Files\PCSuite\DataLayer\DataLayer.exe
    C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
    C:\PROGRA~1\COMMON~1\PCSuite\Services\SERVIC~1.EXE
    C:\Program Files\Apache Group\Apache2\bin\ApacheMonitor.exe
    c:\oracle\ora92\bin\isqlplus
    C:\oracle\ora92\jdk\bin\java.exe
    O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -osboot
    O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
    O4 - HKLM\..\Run: [RemoteControl] "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe"
    O4 - HKLM\..\Run: [PCSuiteTrayApplication] C:\Program Files\Nokia\Nokia PC Suite 6\LaunchApplication.exe -onlytray
    O4 - HKLM\..\Run: [New.net Startup] rundll32 C:\PROGRA~1\NEWDOT~1\NEWDOT~2.DLL,ClientStartup -s
    O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
    O4 - HKLM\..\Run: [Kind flap warn bits] C:\Documents and Settings\All Users\Application Data\messdefykindflap\EggsBolt.exe
    O4 - HKLM\..\Run: [High Definition Audio Property Page Shortcut] HDAudPropShortcut.exe
    O4 - HKLM\..\Run: [DownloadAccelerator] "C:\Program Files\DAP\DAP.EXE" /STARTUP
    O4 - HKLM\..\Run: [DataLayer] C:\Program Files\Common Files\PCSuite\DataLayer\DataLayer.exe
    O4 - HKLM\..\Run: [DAEMON Tools-1033] "C:\Program Files\D-Tools\daemon.exe" -lang 1033
    O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
    O4 - HKCU\..\Run: [Registry Cleaner] "C:\Program Files\Registry Cleaner Trial\RegClean.exe"
    O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
    O4 - HKCU\..\Run: [deafboob] C:\DOCUME~1\ADMINI~1\APPLIC~1\EXITSO~1\Funk drive.exe
    O4 - Startup: Xfire.lnk = C:\Program Files\Xfire\Xfire.exe
    O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
    O4 - Global Startup: Monitor Apache Servers.lnk = C:\Program Files\Apache Group\Apache2\bin\ApacheMonitor.exe
    Sorry for the trouble because I disabled some processes at startup (those that I didn't need) to free up memory usage. I'm also really alarmed of the rate my blocked intrusions is rising. I've only left the PC on for the past 5 hours and the number blocked has risen up to 7600+ with 8 of them high-rated.
    edited March 2006
    Say...does ZoneAlarm affect your net bandwidth? My connections been like 1/2 the speed since I installed it... and intrusion count has reached 8050+
    edited March 2006
    ZA hasn't slowed down my connection from what I can tell, but my download speeds seem a bit slow...hopefully, its not ZA. None the less, its been a good firewall so far for me but I can understand the your frustration.
    You have NewDotNet and a Lop infection that we need to remove. Please do the following:
    Download LSP-Fix. Create a folder for it and put the file in there. Do NOT use it now.
    Next, please go to Add/Remove Programs in Control Panel and uninstall NewdotNet. If you don't have that option or if you have difficulties then follow PROCEDURE 4 at this site.
    If you lose your internet connection, then open LSP-Fix and at the bottom press "Finish". Reboot your computer!
    Could you go to Start > Control Panel > Add/Remove Programs and uninstall 'Window Search', 'Window Searching', 'Window Active' 'Lop.com', 'LOP SEARCH', 'Browser Enhancer', or 'Ultimate Browser Enhancer' if listed. You may be given a code to insert, do so and reboot when done.
    If none of the above are listed, run the Lop Remover from:
    http://66.220.17.157/help.html
    Reboot and post a new HJT log :)
    edited March 2006
    Done. What's next? Here's the new log.
    Scan saved at 10:50:56 PM, on 3/12/2006
    Running processes:
    C:\Program Files\Internet Explorer\iexplore.exe
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
    O4 - HKCU\..\Run: [ares] "C:\Program Files\Ares\Ares.exe" -h
    Update for the intrusions...it's now more than 10k..
    edited March 2006
    oh...i don't know if it's my bandwidth that's low or not, but the forum is taking very, very long to load. Maybe there're too many users? Also, i wanna ask this: In ZoneAlarm's Firewall/Zones tab i've got 2 entries, Loopback adapter (set to Trusted by default) and Marvell Yukon Gigabit Ethernet 100\/100/1000Base-T Adapter, Copper RJ-45 which is the adapter subnet(Set to Internet by default). Question is, can i set the subnet to Trusted? It seems that my net connection improves a teeney bit when i do that.
    edited March 2006
    It should be ok, but i'm not 100% sure. Networking is not my strongest point :(
    When you say the intrusions are up to 10k, is this a log file size or...?
    Your log is still the same. Did you reboot your computer? Did you follow each instruction carefully? Can you do them again please, reboot and post a new HJT log :)
    edited March 2006
    The total number of intrustions over the past 3 days are more than 10000.
    Here's the log. I did everything again. I checked.
    Scan saved at 12:16:54 AM, on 3/13/2006
    Running processes:
    C:\WINDOWS\system32\Ati2evxx.exe
    C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
    C:\WINDOWS\system32\UAService7.exe
    C:\WINDOWS\system32\wscntfy.exe
    O23 - Service: Adobe LM Service - Unknown owner - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
    O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
    O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
    O23 - Service: StarWind iSCSI Service (StarWindService) - Rocket Division Software - C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
    O23 - Service: SecuROM User Access Service (V7) (UserAccess7) - Unknown owner - C:\WINDOWS\system32\UAService7.exe
    edited March 2006
    i read on another forum that the win**.tmp.exe files are actually the result of a trojan...is that true?
    edited March 2006
    The temp file could be a Trojan but i'm not entirely sure. We could scan the file and determine if it is.
    The infections seem to be gone. Next step is to do the following:
    Please download the trial version of Ewido Security Suite here:
    http://www.ewido.net/en/download/
    When installing the program, under "Additonal Options" uncheck..
    • Install background guard
    • Install scan via context menu
    Once installed, update the definitions to the newest files. Do NOT run a scan yet.
    Next, please reboot your computer in Safe Mode by doing the following:
    1) Restart your computer
    2) After hearing your computer beep once during startup, but before the Windows icon appears, press F8.
    3) Instead of Windows loading as normal, a menu should appear
    4) Select the first option, to run Windows in Safe Mode.
    For additional help in booting into Safe Mode, see the following site:
    http://www.pchell.com/support/safemode.shtml
    Once in Safe Mode, please run Ewido (Do not use the computer while Ewido is scanning as it will interrupt the scan )
    • Click on scanner
    • Click Complete System Scan and the scan will begin.
    • NOTE: During some scans with ewido it is finding cases of false positives.
    • You will need to step through the process of cleaning files one-by-one.
    • If ewido detects a file you KNOW to be legitimate, select none as the action.
    • DO NOT select "Perform action on all infections"
    • If you are unsure of any entry found select none for now.
    • When the scan is finished, click the Save report button at the bottom of the screen.
    • Save the report to your desktop
    Close Ewido
    Restart your computer in normal mode and please post a new HijackThis log, as well as the log from the Ewido scan.
    edited March 2006
    Here're the 2 logs:
    Scan saved at 1:43:08 AM, on 3/13/2006
    Running processes:
    ewido anti-malware - Scan report
    + Created on: 1:40:11 AM, 3/13/2006
    + Report-Checksum: 6E32EB09
    + Scan result:
    [256] C:\WINDOWS\system32\winuqw32.dll -> Downloader.Small.cml : Ignored
    C:\Documents and Settings\Administrator\Desktop\LSP\new_uninstall.exe -> Adware.Lop : Ignored
    C:\WINDOWS\system32\ginuerep.dll -> Not-A-Virus.Hoax.Win32.Renos.bv : Ignored
    C:\WINDOWS\temp\win267.tmp.exe -> Trojan.Dialer.oy : Ignored
    C:\WINDOWS\temp\win26F.tmp.exe -> Trojan.Dialer.oy : Ignored
    C:\WINDOWS\temp\win279.tmp.exe -> Trojan.Dialer.oy : Ignored
    C:\WINDOWS\temp\win27C.tmp.exe -> Trojan.Dialer.oy : Ignored
    C:\Documents and Settings\Administrator\Cookies\administrator@www.myaffiliateprogram[1].txt -> TrackingCookie.Myaffiliateprogram : Cleaned with backup
    ::Report End
    edited March 2006
    OK, lets get this sorted. Please do the following:
    Open HijackThis
    - Click the Do a system scan only button
    - Check the following entries (below)
    - Close ALL open windows
    Click Fix Checked
    NEXT
    View hidden files and folders – explained here
    THEN
    Find and Delete the following, if found:
    C:\WINDOWS\SYSTEM32\winuqw32.dll << this file
    C:\WINDOWS\system32\ginuerep.dll << this file
    C:\WINDOWS\temp\win267.tmp.exe << this file
    C:\WINDOWS\temp\win26F.tmp.exe << this file
    C:\WINDOWS\temp\win279.tmp.exe << this file
    C:\WINDOWS\temp\win27C.tmp.exe << this file
    If you get an "Access Denied" message, then delete the file from Safe Mode
    Please scan with Ad-Aware and SpyBot.
    Panda ActiveScan
    http://www.pandasoftware.com/activescan/com/activescan_principal.htm
    - Once you are on the Panda site, click the Scan your PC button
    - A new window will open...click the Check Now button
    - Enter your Country
    - Enter your State/Province
    - Enter your e-mail address and click send
    - Select either Home User or Company
    - Click the big Scan Now button
    - If it wants to install an ActiveX component allow it
    - It will start downloading the files it requires for the scan (Note: It may take a couple of minutes)
    - When download is complete, click on Local Disks to start the scan
    - When the scan completes, if anything malicious is detected, click the See Report button, then Save Report and save it to a convenient location.
    Reboot and post the contents of the Panda scan report, along with a new HijackThis Log
    edited March 2006
    Scan saved at 3:33:41 AM, on 3/13/2006
    Running processes:
    O20 - Winlogon Notify: winuqw32 - winuqw32.dll (file missing)
    Incident Status Location
    Adware:adware/block-checker Not disinfected Windows Registry
    Potentially unwanted tool:application/need2find Not disinfected HKEY_CURRENT_USER\SOFTWARE\NEED2FIND
    Adware:adware/ist.istbar Not disinfected Windows Registry
    Adware:Adware/Lop Not disinfected C:\Documents and Settings\Administrator\Desktop\LSP\new_uninstall.exe
    Potentially unwanted tool:Application/Processor Not disinfected C:\smitrem\smitRem\Process.exe
    edited March 2006
    Your HJT log is clean.
    How are thigns now? Is ZA still complaining?
    edited March 2006
    Nope..not anymore...thanks...but what about the stuff identified by ActiveScan? They've been there for quite some time and I don't know how to remove them, especially the first file and the one with the H_KEY. Also, how do i rid myself of the file "ZLT0168e.TMP" in the temp folder? The application that you gave me earlier on did not delete it.
    edited March 2006
    Oh...and what can I do to lower the number of blocked intrusions in ZA? The number is almost 15000 now...
    edited March 2006
    I forgot one entry to remove with HJT. Can you please remove the following:
    Find and Delete the following file, if found:
    Could you take a screen shot of the alert from ZA please.
    Please run this online scan:
    - Run the Free Kaspersky Online Virus Scan
    - Click on the Kaspersky Online Scanner button
    - On the new window that opens, click the Accept button
    - Kaspersky will check if you have the ActiveX installed. If not, you will be prompted to download it. Please do - it is perfectly safe.
    - After accepting to install the ActiveX, you will need to click Accept again
    - Kaspersky will then install the ActiveX and download the latest Anti-Virus files from their database. Please be patient, it may take several mintues to download the latest files. Click Next when done
    - Select My Computer
    Please do NOT use the internet while Kaspersky is scanning
    - When the scan is complete, click the Save as Text button. Call it Virus Results and save the report to your desktop.
    - Open the file and paste the entire contents here
    edited March 2006
    Man...you gurus are human too! Haha. Sorry. It won't happen again.
    I took the screenshot of my ZA, but how do i post it here? or send it to you?
    Here're the scan results:
    KASPERSKY ON-LINE SCANNER REPORT
    Wednesday, March 15, 2006 11:44:29 AM
    Operating System: Microsoft Windows XP Professional, Service Pack 2 (Build 2600)
    Kaspersky On-line Scanner version: 5.0.78.0
    Kaspersky Anti-Virus database last update: 15/03/2006
    Kaspersky Anti-Virus database records: 171408
    Scan Settings:
    Scan using the following antivirus database: standard
    Scan Archives: true
    Scan Mail Bases: true
    Scan Target - My Computer:
    A:\
    C:\
    D:\
    E:\
    Scan Statistics:
    Total number of scanned objects: 144608
    Number of viruses found: 13
    Number of infected objects: 19
    Number of suspicious objects: 0
    Duration of the scan process: 01:31:24
    Infected Object Name / Virus Name / Last Action
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0041835.tlb Infected: Trojan-Downloader.Win32.Zlob.hw skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0041911.tlb Infected: Trojan-Downloader.Win32.Zlob.hw skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0041974.tlb Infected: Trojan-Downloader.Win32.Zlob.hw skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0041975.exe Infected: Trojan-Downloader.Win32.Zlob.hw skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0041977.exe Infected: Trojan-Downloader.Win32.Zlob.hw skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0041979.exe Infected: Email-Worm.Win32.VB.an skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0042046.exe Infected: Trojan-Downloader.Win32.Swizzor.cb skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0042047.exe Infected: Trojan-Downloader.Win32.Swizzor.co skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0042466.exe Infected: Trojan-Downloader.Win32.Swizzor.bo skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0042477.exe Infected: Trojan-Clicker.Win32.Delf.dm skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0042479.dll Infected: not-virus:Hoax.Win32.Renos.bs skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0042480.dll Infected: Trojan-Downloader.Win32.IstBar.eq skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0042595.exe Infected: Trojan-Downloader.Win32.Zlob.hw skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0043620.tlb Infected: Trojan-Downloader.Win32.Zlob.ik skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0043621.exe Infected: Trojan-Downloader.Win32.Zlob.il skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0043623.exe Infected: Trojan-Downloader.Win32.Zlob.ik skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0044229.dll Infected: not-virus:Hoax.Win32.Renos.bv skipped
    C:\System Volume Information\_restore{1563BD03-5F95-4B27-B1CE-DF9B6E8AB96D}\RP289\A0044235.dll Infected: Trojan-Downloader.Win32.Small.cml skipped
    C:\WINDOWS\system32\dfrgsrv.exe Infected: Trojan-Downloader.Win32.Zlob.in skipped
    Scan process completed.
    edited March 2006
    okay..my PC is still acting weird...Today it has rebooted itself twice without any reason...Just a sudden reboot, no error messages or whatsoever. The 1st time it happened was around 5-6 hours ago when i was afk and it just hapened again in my face. Is this a measure of ZoneAlarm when someone tries to force himself into my PC or something?? Because my intrusion count as just reached 30000 and it's not slowing down. In fact i think it's going up even faster now.
    Following this i scanned with ewido again and the result is:
    + Created on: 9:02:15 PM, 3/15/2006
    + Report-Checksum: 690B7085
    + Scan result:
    C:\WINDOWS\system32\dfrgsrv.exe -> Downloader.Zlob.in : Ignored
    ::Report End
    What should i do with this? Delete it?
    Also, there is a hidden folder that I can't access in my C: drive called System Volume Information. Why? I'm using the Administrator account...
    edited March 2006
    Yes, please delete this file from Safe Mode.
    C:\WINDOWS\system32\dfrgsrv.exe << this file
    Kaspersky is finding items in System Restore but we can clean that up quite easily.
    To attach a screen shot, click on the manage attachment button when you are posting your message and then upload the file.
    Do that and then we can continue. :)
    edited March 2006
    It's done. Here's the screenshot. It's no alert but the rate of which it's growing is incredible. This is the count since 3/10/2006 6:26:32 PM. Hmm...seems like I can't load your attatchments page..i'm getting a technical error message. I'll upload it to a site and you can download it? It's in JPG. Sry for the inconvenience. Here's the link:
    http://s65.yousendit.com/d.aspx?id=0W8LP0IWWCUWD0YYQOLLGRV3U6
    The file's called "ZA Screenshot.JPG".
    edited March 2006
    Oh hey...it's working now... Ok.. here're the shots... Like I've said it's not an alert by ZA, rather something that is brought up to my concern...
    edited March 2006
    Ah...thanks for the pics. The second one is kinda worrying but atleast ZA is doing its job.
    Can you please do this:
    Follow the instructions here to Disable and Re-enable system restore. I want you to do this:
    1) Disable System Restore
    2) Reboot
    3) Re-enable System Restore
    4) Create a new Restore point (Note: All previous restore points will be lost)
    Please run Panda ActiveScan
    Post the contents of the Panda scan report.
    edited March 2006
    Done! Here's the report:
    Spyware:Cookie/YieldManager Not disinfected C:\Documents and Settings\Administrator\Cookies\administrator@ad.yieldmanager[1].txt
    Spyware:Cookie/Belnk Not disinfected C:\Documents and Settings\Administrator\Cookies\administrator@belnk[1].txt
    Spyware:Cookie/Com.com Not disinfected C:\Documents and Settings\Administrator\Cookies\administrator@com[2].txt
    Spyware:Cookie/Belnk Not disinfected C:\Documents and Settings\Administrator\Cookies\administrator@dist.belnk[2].txt
    edited March 2006
    How are things? Any change?
    Go here and download then run Silent Runners.vbs. It generates a log, please post the information back in this thread.
    If you have a script blocking program, please allow the file to run. It is not malicious.
    edited March 2006
    I scanned with ad-aware and spybot. Ad-aware only had the small stuff brought up. Spybot said that there were no immediate threats.
    edited March 2006
    Here're the log by SilentRunners:
    "Silent Runners.vbs", revision 44, http://www.silentrunners.org/
    Operating System: Windows XP SP2
    Output limited to non-default values, except where indicated by "{++}"
    Startup items buried in registry:
    HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\ {++}
    "Zone Labs Client" = "C:\Program Files\Zone Labs\ZoneAlarm\zlclient.exe" ["Zone Labs, LLC"]
    "KlipFolio" = ""C:\Program Files\KlipFolio\KlipFolio.exe" /BOOT" ["Serence Inc."]
    HKLM\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved\
    "{42071714-76d4-11d1-8b24-00a0c9068ff3}" = "Display Panning CPL Extension"
    -> {HKLM...CLSID} = "Display Panning CPL Extension"
    \InProcServer32\(Default) = "deskpan.dll" [file not found]
    "{88895560-9AA2-1069-930E-00AA0030EBC8}" = "HyperTerminal Icon Ext"
    -> {HKLM...CLSID} = "HyperTerminal Icon Ext"
    \InProcServer32\(Default) = "C:\WINDOWS\system32\hticons.dll" ["Hilgraeve, Inc."]
    "{F0CB00CD-5A07-4D91-97F5-A8C92CDA93E4}" = "Shell Extensions for RealOne Player"
    -> {HKLM...CLSID} = "RealOne Player Context Menu Class"
    \InProcServer32\(Default) = "C:\Program Files\Real\RealPlayer\rpshell.dll" ["RealNetworks, Inc."]
    "{640167b4-59b0-47a6-b335-a6b3c0695aea}" = "Portable Media Devices"
    -> {HKLM...CLSID} = "Portable Media Devices"
    \InProcServer32\(Default) = "C:\WINDOWS\system32\Audiodev.dll" [MS]
    "{cc86590a-b60a-48e6-996b-41d25ed39a1e}" = "Portable Media Devices Menu"
    -> {HKLM...CLSID} = "Portable Media Devices Menu"
    "{E0D79300-84BE-11CE-9641-444553540000}" = "WinZip"
    -> {HKLM...CLSID} = "WinZip"
    \InProcServer32\(Default) = "C:\PROGRA~1\WinZip\wzshlext.dll" [null data]
    "{E0D79301-84BE-11CE-9641-444553540000}" = "WinZip"
    "{E0D79302-84BE-11CE-9641-444553540000}" = "WinZip"
    "{0006F045-0000-0000-C000-000000000046}" = "Microsoft Outlook Custom Icon Handler"
    -> {HKLM...CLSID} = "Outlook File Icon Extension"
    \InProcServer32\(Default) = "C:\Program Files\Microsoft Office\Office10\OLKFSTUB.DLL" [MS]
    "{42042206-2D85-11D3-8CFF-005004838597}" = "Microsoft Office HTML Icon Handler"
    -> {HKLM...CLSID} = (no title provided)
    \InProcServer32\(Default) = "C:\Program Files\Microsoft Office\Office10\msohev.dll" [MS]
    "{506F4668-F13E-4AA1-BB04-B43203AB3CC0}" = "{506F4668-F13E-4AA1-BB04-B43203AB3CC0}"
    -> {HKLM...CLSID} = "ImageExtractorShellExt Class"
    \InProcServer32\(Default) = "C:\Program Files\Microsoft Office\Visio10\VisShe.dll" [null data]
    "{D66DC78C-4F61-447F-942B-3FB6980118CF}" = "{D66DC78C-4F61-447F-942B-3FB6980118CF}"
    -> {HKLM...CLSID} = "CInfoTipShellExt Class"
    "{416651E4-9C3C-11D9-8BDE-F66BAD1E3F3A}" = "PhoneBrowser"
    -> {HKLM...CLSID} = "Nokia Phone Browser"
    \InProcServer32\(Default) = "C:\Program Files\Nokia\Nokia PC Suite 6\PhoneBrowser.dll" ["Nokia"]
    "{FBFE7864-D495-41f0-B7DC-4BB601CC295E}" = "Contact View"
    -> {HKLM...CLSID} = "Contact View"
    \InProcServer32\(Default) = "C:\Program Files\Nokia\Nokia PC Suite 6\ContactView.dll" ["Nokia"]
    "{C0C4375A-5B72-4efe-929D-3B848C3A1E91}" = "Message View"
    -> {HKLM...CLSID} = "Message View"
    \InProcServer32\(Default) = "C:\Program Files\Nokia\Nokia PC Suite 6\MessageView.dll" ["Nokia"]
    "{B41DB860-8EE4-11D2-9906-E49FADC173CA}" = "WinRAR shell extension"
    -> {HKLM...CLSID} = "WinRAR"
    \InProcServer32\(Default) = "C:\Program Files\WinRAR\rarext.dll" [null data]
    "{32020A01-506E-484D-A2A8-BE3CF17601C3}" = "AlcoholShellEx"
    -> {HKLM...CLSID} = "AlcoholShellEx"
    \InProcServer32\(Default) = "C:\PROGRA~1\ALCOHO~1\ALCOHO~1\AXShlEx.dll" ["Alcohol Soft Development Team"]
    "{B4579AA5-E3A0-49A1-AC0B-5112AFBD215B}" = "iSQL*Plus Servers"
    -> {HKLM...CLSID} = "iSqlPlusShellExt Class"
    \InProcServer32\(Default) = "C:\WINDOWS\system32\isqlext.dll" ["Oracle Corporation"]
    HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellExecuteHooks\
    INFECTION WARNING! "{54D9498B-CF93-414F-8984-8CE7FDE0D391}" = "ewido shell guard"
    -> {HKLM...CLSID} = "CShellExecuteHookImpl Object"
    \InProcServer32\(Default) = "C:\Program Files\ewido anti-malware\shellhook.dll" ["TODO: <Firmenname>"]
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\
    INFECTION WARNING! AtiExtEvent\DLLName = "Ati2evxx.dll" ["ATI Technologies Inc."]
    HKLM\Software\Classes\*\shellex\ContextMenuHandlers\
    WinRAR\(Default) = "{B41DB860-8EE4-11D2-9906-E49FADC173CA}"
    WinZip\(Default) = "{E0D79300-84BE-11CE-9641-444553540000}"
    HKLM\Software\Classes\Directory\shellex\ContextMenuHandlers\
    HKLM\Software\Classes\Folder\shellex\ContextMenuHandlers\
    Active Desktop and Wallpaper:
    Active Desktop is disabled at this entry:
    HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellState
    HKCU\Control Panel\Desktop\
    "Wallpaper" = "C:\Documents and Settings\Administrator\Local Settings\Application Data\Microsoft\Wallpaper1.bmp"
    Winsock2 Service Provider DLLs:
    Namespace Service Providers
    HKLM\System\CurrentControlSet\Services\Winsock2\Parameters\NameSpace_Catalog5\Catalog_Entries\ {++}
    000000000001\LibraryPath = "%SystemRoot%\System32\mswsock.dll" [MS]
    000000000002\LibraryPath = "%SystemRoot%\System32\winrnr.dll" [MS]
    000000000003\LibraryPath = "%SystemRoot%\System32\mswsock.dll" [MS]
    Transport Service Providers
    HKLM\System\CurrentControlSet\Services\Winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\ {++}
    0000000000##\PackedCatalogItem (contains) DLL [Company Name], (at) ## range:
    %SystemRoot%\system32\mswsock.dll [MS], 01 - 04, 07 - 16
    %SystemRoot%\system32\rsvpsp.dll [MS], 05 - 06
    Toolbars, Explorer Bars, Extensions:
    Toolbars
    HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\
    "{BDAD1DAD-C946-4A17-ADC1-64B5B4FF55D0}"
    -> {HKLM...CLSID} = "MSN"
    \InProcServer32\(Default) = "C:\Program Files\MSN Apps\MSN Toolbar\01.02.3000.1001\en-us\msntb.dll" [MS]
    "{2318C2B1-4965-11D4-9B18-009027A5CD4F}"
    -> {HKLM...CLSID} = "&Google"
    \InProcServer32\(Default) = "c:\program files\google\googletoolbar2.dll" ["Google Inc."]
    "{EF99BD32-C1FB-11D2-892F-0090271D4F88}"
    -> {HKLM...CLSID} = "Yahoo! Toolbar"
    \InProcServer32\(Default) = "C:\Program Files\Yahoo!\Companion\Installs\cpn\ycomp5_6_2_0.dll" [file not found]
    HKLM\Software\Microsoft\Internet Explorer\Toolbar\
    "{EF99BD32-C1FB-11D2-892F-0090271D4F88}" = (no title provided)
    Extensions (Tools menu items, main toolbar menu buttons)
    HKLM\Software\Microsoft\Internet Explorer\Extensions\
    {08B0E5C0-4FCB-11CF-AAA5-00401C608501}\
    "MenuText" = "Sun Java Console"
    "CLSIDExtension" = "{CAFEEFAC-0015-0000-0006-ABCDEFFEDCBC}"
    -> {HKCU...CLSID} = "Java Plug-in"
    \InProcServer32\(Default) = "C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll" [file not found]
    -> {HKLM...CLSID} = "Java Plug-in 1.5.0_06"
    \InProcServer32\(Default) = "C:\Program Files\Java\jre1.5.0_06\bin\npjpi150_06.dll" ["Sun Microsystems, Inc."]
    {FB5F1910-F110-11D2-BB9E-00C04F795683}\
    "ButtonText" = "Messenger"
    "MenuText" = "Windows Messenger"
    "Exec" = "C:\Program Files\Messenger\msmsgs.exe" [MS]
    Running Services (Display Name, Service Name, Path {Service DLL}):
    ewido security suite control, ewido security suite control, "C:\Program Files\ewido anti-malware\ewidoctrl.exe" ["ewido networks"]
    HTTP SSL, HTTPFilter, "C:\WINDOWS\System32\svchost.exe -k HTTPFilter" {"C:\WINDOWS\System32\w3ssl.dll" [MS]}
    Machine Debug Manager, MDM, ""C:\Program Files\Common Files\Microsoft Shared\VS7Debug\mdm.exe"" [MS]
    SecuROM User Access Service (V7), UserAccess7, "C:\WINDOWS\system32\UAService7.exe" [null data]
    TrueVector Internet Monitor, vsmon, "C:\WINDOWS\system32\ZoneLabs\vsmon.exe -service" ["Zone Labs, LLC"]
    Windows User Mode Driver Framework, UMWdf, "C:\WINDOWS\system32\wdfmgr.exe" [MS]
    + This report excludes default entries except where indicated.
    + To see *everywhere* the script checks and *everything* it finds,
    launch it from a command prompt or a shortcut with the -all parameter.
    + The search for DESKTOP.INI DLL launch points on all local fixed drives
    took 160 seconds.
    + The search for all Registry CLSIDs containing dormant Explorer Bars
    took 19 seconds.
    (total run time: 216 seconds)
