Problem when changing case
Hi all. I purchased a second hand Raidmax Scorpio case the other day. It has the front fascia with the LED's missing from it though
My problem is that I transferred all the hardware from my daughters case into the Raidmax case and I get an error message when booting that the IDE drives cannot be found. There is an HD and a CDRom installed.
Now, the only thing not connected after transferring the hardware are the HDD LED connector and the Power LED connector.
Is there any chance at all that that could be the cause of the problem?
I have now transferred the hardware back into the original case and the PC is running perfectly again
Thanks guys.
.My problem is that I transferred all the hardware from my daughters case into the Raidmax case and I get an error message when booting that the IDE drives cannot be found. There is an HD and a CDRom installed.
.Thanks guys.
I don't even have the leds connected on most of my machines.
Also, take a quick look at the jumpers to ensure that they are in the proper master/slave positions.
As soon as my main PC comes back (it's in the shop having the mobo changed under warranty) I will give this another try
