Strange problems occuring...please help!
edited April 2006 in Nerdery
Hi, recently my computer has been slowly coming up with more and more problems. Here are the main ones. I cannot get to the Task Manager, it will not open. Also, when I open a few programs, they will begin to load then will not appear. When I try to open my Music folder, an error comes up and the desktop must reset, and obviously the folder will not open. My iTunes also has an error when I try to open it. In AIM, it logs me off every time I try to transfer a file. The "search" feature also does not run, as it says a file is missing. I have no idea what is causing all these problems, but basically it seems nothing can run smoothly. Any help would be much appreciated! Thank you.
