HDD Power Connection Question
I know this is going to sound really basic and stupid to all & sundry but here goes anyway:
I need to power a second hard drive. All the power cables from the actual power supply box are being used, however the mobo has a bunch of cables coming out of it, all neatly bundled up with a cable tie. At least one of these cables has the appropriate black, red and yellow wires required for powering a hard drive, but I just wanted to check if it is OK to use these cables (not the sort of thing I wanted to "trial and error" if you know what I mean).
Chances are you should be able to use it just fine to power the HDD, unless your power supply is at its absolute limit. It should be no problem, though.
Had a heapa ppl going with the problem tho! :Pwned:
This wasn't at band camp was it???
