Monitor Problems
emptyempty houston
Starting about a week or i started getting these wierd waves on my monitor. they just come in an out and i dont know whats wrong i havent put anything new by the monitor. its a kds 19" monitor.
  • TheBaronTheBaron Austin, TX
    edited October 2003
    first - i dont think you're stupid
    try degaussing. then, if you have a can of compressed air and your monitor has holes in it, give it a good spray for dusting!
  • emptyempty houston
    edited October 2003
    ive degaussed it ill try the can of air.
    edited October 2003
    try reseating your video card a few times ...if that doesn't help move the entire system to another part of the room or another room completely. let us know.
    edited October 2003
    KDS monitors are also "budget" monitors and as such you could have a monitor that is going bad prematurely. Although I know someone with a KDS that has been working well for 2 years.
    edited October 2003
    ...your refresh rate. Set it as high as your video card & monitor will allow. Also, move the monitor cable around and see if the wavy lines move too. If so, try to find the best spot to route the cable. Make sure that power lines are away from the monitor cable.
    edited October 2003
    if there are flat or bent places in the cable replace it. I have had more trouble with cheap monitor cables. I suppose that it is usually the connectors, but the result is the same, Jive video.
    edited October 2003
    the only thing that has worked is when i hold the monitor down and to the right it goes away. weird.
    edited October 2003
    damn pos broke so i get to rma it.
  • leishi85leishi85 Grand Rapids, MI Icrontian
    edited October 2003
    sorry for going off topic, but edcentric what does TDY: Beijing mean, i know where beijin mean.
