radeon 9800 256 flash help
ello i've got a radeon 9800 256 non pro ,pn 1024-2c47-00-sa with samsung 419 memory , i wanted to flash the bios, can i? to what, any tips in would be great
To be honest, the only BIOS flash option available to you would be a 9800XT. Since the 9800 pro you have is the 256bit version, there is no point to doing this. The card is not 'disabled' in any way, so all that will accomplish is higher default core/memory clock speeds. I'd simply try to overclock it as-is and avoid the risk.
