Need Help asap...
Hello everyone .. this is my 1st post here, but ill get to my point
A little about my computer ...
Computer
AMD Athon 64 Processor
3000+
2.00GHz, 1.00 GB of RAM
Video Card
Radeon 9600SE
Hard Drive
WDC WD1600JS-00MHB0
I am trying to reformat my computer Iv been tould that its DEFINATLY A scsi hard drive so i was wondering is it 100% for sure? and um can sum 1 give me a detailed STEP by STEP on how to do it and where to get the exact right links to the things i must put on the floppy ( i been reading http://www.short-media.com/forum/showthread.php?t=44910 ) so to sum it all up ..
1 - what kind of hd for sure do i have?
2 - what do i put on the floppy?
3 - step by step instructions
4 - where do i get the files i need to put on the floppy
5 - the file names
- thanks Cheers
Computer
3000+
Video Card
Radeon 9600SE
Hard Drive
WDC WD1600JS-00MHB0
5 - the file names
- thanks Cheers
Have you changed the setting anytime soon?
Who built this computer/where did you buy it?
- to reformat im using window xp cd
- no
- my friend built it for me and he was the one that tould me how 2 reformat it.
Depending on your setup you may need to make a disk with SATA drivers which you can load at the start of the windows setup wizard.
As GrayFox asked, try to find out which motherboard you have. After that you can find out which drivers to get.
also...ask ur friend how he installed windows xp he should remember
but basically put the cd in before bootup first
then press the appropiate button to boot to cdrom
run the setup
if it detects the hd, ur done and its fairly simple from then on
except: you would wanna download drivers for ur network card if its not onboard (but it probably is) but ant any rate make sure but u still need to find out what motherboard ur running.. itl\'ll be difficult to download drivers if u can't reach th internet
Board: ASRock K8Upgrade-1689 1.00
Bus Clock: 200 megahertz
BIOS: American Megatrends Inc. L2.01 08/30/2005
Even has a guide with it too.
http://www.asrock.com/support/download.asp?Model=K8Upgrade-1689
