Please help! ATI tv-out problems =(
Later i had a nvidia gf4 card that I run with Tv-out to an ordinary TV. It was alot of problems in the beginning but after a while it worked.
Now i have bought a ATI-Radeon X1600 PRO with tv-out. But the problem is that it won´t work. After som fixing, the problem right now is only the color, the picture is black/white.
I have heard that the choice of software is an important factor to get it work. I have tried ATI control center, but thats not work.
Can someone give me some hints or god ideas how i can fix this, i get wicked of it.. =(
What program should I try, that may be optional with ATI graphic cards.
/Cyanide
/Cyanide
strange.. =
If using Svid, try Svid - Composite Direct to TV AV In, Obviously Ensuring TV is Switched on Before PC. Have seen Similar Problems Before.
S/W wise, use Power DVD
