ASUS EN 7800GT Dual - Need Help, SLI problems
Can anybody help;
I have an ASUS EN7800GT Dual, but cannot Enable SLI
Used Various Drivers, from ASUS supplied to Latest Nvidia
Mobo is A8N-SLI Premium, Tried Re-Install, Newer Nforce Drivers, Latest BIOS
Card Only Detected as One GPU
Only One HS appears warm
Tried In Both PCIe, currently in Second
Bench Marks Confirm Single GPU Scores
Tried All GPU options In BIOS, AUTO, Single, Dual GFX (Currently Set)
Adjusted Peg Link to fastest
Driver does not indicate Dual GPU, ASUS AI does not allow you to Enable SLI
O/S is XP Pro SP2
No other Hardware Installed, except Creative Audigy 2 ZS
Used Internal PSU and External PSU
Main DVI Connector Used
Any Ideas most welcome...........
O/S is XP Pro SP2
If thats not plugged in, then it's wont let you enable SLI if theres not enough amprage across the cards.
Have you tried the Asus Support forums? Any mention of how to tell if the card is bad?
Personally, I dont think ASUS are very interested, have requested help, but to no Avail.
SLI Power connector is in Use
However, We have fixed the problem if it helps anyone in future;
ASUS, new BETA BIOS's, possibly anything above V:1.9, and the card is not detected as two GPU's. However Asus's new Flash utility, inc DOS version does not allow downgrade, you must use an older Flash Utility to do so.
Downgrade to 1.9 and is detected correctly.
Second problem, card would not complete 3D Mark Tests, causing a reboot. Updated Drivers made no improvement.
Solution, bin the external Power Brick, as we noticed that on a Reset, the Card did not reset, showing no BIOS screen etc, although resuming display at raid BIOS. Using Normal 6 Pin SLi connector, card resets properly, fan spinning up as expected and No more crashes and reboots.
I think I'll inform ASUS of the solution as they can't be bothered to investigate and provide anyone with one themselves.
Hope this helps, and thanks for your suggestions.
