Need help with display
Hello all.
I am having problems setting the correct resolution on my display. I have just purchased a widescreen TFT with a native resolution of 1366x768. I have an XFX GeForce 7600GT XE with a max resolution of 2560x1600, and I am running XP home MCE. When I try to change the display settings, the highest resolution available is 1024x768. I can't get widescreen. Anyone have any ideas? Thanks in advance for any help.
what brand is the TFT display? model #?
Another thought, is you driver showing 'supported modes' or all? If you tell it to show all you should be able to get what you need.
