TV tuner problem along with InterVideo WinDVR and Windows Movie Maker problems
edited July 2006 in Software
Not sure if I am on the right catagory but I have about 3 problems all related to one (I think) and any ANY help is much appricated. So this is whats going on:
Any help I can get I appricate I have 2 problems First I am taking Video from VHS from my VCR thr Coaxial cable to the computer to editing then to dvd. When I use Windows Movie Maker to capture Video It plays the sound while it records But to play it after is records there is no sound. All my settings seem to be right and I have 2 sets of speakers hooked up one to Tv tuner card and the other to the computer When I use InterVideo WinDVR I do not have this problem But problem with using InterVideo WinDVR is about 90% of the time it will not work I get a blue screen error message and windows shuts down I scratched the message down and it says:
A problem has been detected and windows has been shut down to prevent damage to your computer.
If this is this first time you've seen this stop error screen restart your computer. If this screen appears again follow these steps:
Check to be sure you have adequte disk space. If a driver is idenitifed in the stop message disable the driver or check with the manufactor for driver updates.
Try changing video adapters
Check with your hardware vendor for any BIOS updates. Diable BIOS memory options such as catching or shadowing. If you need to use safe mode to remove or disable componets, restart your computer press F8 to select start up options then safe mode.
Techincal Information:
STOP: 0x00000085 (0xc0000005, 0x8054A51A, 0xa8586a64, 0x00000000)
Begining dump of physical memory. Physical memory dump complete. Contact your system adminstrator or techinacal support for asstiance.
So after this i have to cut power to restart then the popup comes up when back on windows saying something like windows has recovered from a serious error then you either pick send error report or don't send error report so when I finally clicked send my internet exploroer popped up after it was thru saying:the link is: http://oca.microsoft.com/en/response.aspx?SGD=9b8bb802-5089-49e8-9867-5d6a3f4065cb&SID=703
(this is a copy paste)
All products
| Support
| Search
| microsoft.com guide
Online Crash Analysis | Corporate Error Reporting | Online Crash Analysis Worldwide
Browser security settings may impair site functionality
JavaScript and cookies must be enabled
Microsoft Online Crash Analysis uses JavaScript and cookies to display content correctly.
To upload your error report or check the status of a previously submitted error report, ensure that your browser security settings meet the following requirements:
JavaScript must be enabled.
Cookies must be enabled.
Error caused by device driver
Thank you for submitting an error report.
Problem description
The error was likely caused by:
cap7134.sys
Recommendations
cap7134.sys is a video capture device driver. It is distributed by numerous companies in different products. Microsoft is unable to determine which product on your computer shipped with cap7134.sys. Below is a list of some of the products that ship cap7134.sys.
If you have one of the products below, click the product. This will open a website where you can obtain the updated driver for that product.
ASUS TV7134
Compro VideoMate TV
NEC SmartVision/TV
Otherwise, you need to determine which product installed Cap7134.sys on your system and seek updates for that product. Other products that may include Cap7134.sys are:
TerraTec Cinergy 400 TV
LifeView FlyVideo
MEDION TV-TUNER 7134
Philips Proteus (7130)
KNC ONE TV-Station
V-Gear MyTV
Now My computer is a dell with windows xp home I have had only a month I called Dell as usual they refuse to help you on anything unless you pay per minute- So I refused to do that again- My TV tuner card is been installed about a week or a week and half and I bought off ebay brand new and these people refuse to even talk to me if you want to look at my auction win for all the info on the tv tuner the number is 220007784552
link is http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN%3AIT&rd=1
There is no brand anywhere on box or tuner but however the auction says
NEW TV Tuner Video Capture PCI Card(Philips SAA7130HL chipset) w/ Remote controller
But when I click on the link from microsoft for the phillips tuner it is only a pdf file and nothing about a driver download or update nor have I had any luck with any of the other sites
ANY ANY ANY help I appricate it so much I am going out of my mind!!!
Thanks Samantha
