Need help removing Purityscan - also not sure if Trojan is gone {SOLVED}
Hi - A few days ago, Norton AV started popping up saying I had a Trojan that it couldn't delete, at the same time as I got random ad popups appearing. I tried numerous things to remove the trojan, finally running Moosoft's Cleaner, which seems to have gotten rid of it. Norton never did seem to pick it up on a system scan, though, so I'm not sure.
I still have the adware, and Norton calls it Adware.Purityscan and can't delete it. I tried uninstalling Cowabanga from Add/Remove programs, but that didn't help. I've also scanned and tried to fix with both AdAware and Spybot. Here's my HJT log:
Logfile of HijackThis v1.99.1
Scan saved at 2:30:42 AM, on 8/1/2006
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
C:\Program Files\Common Files\Symantec Shared\SNDSrvc.exe
C:\Program Files\Common Files\Symantec Shared\SPBBC\SPBBCSvc.exe
C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
C:\Acer\eManager\anbmServ.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Norton AntiVirus\IWP\NPFMntor.exe
C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
C:\Program Files\Synaptics\SynTP\SynTPLpr.exe
C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
C:\WINDOWS\SOUNDMAN.EXE
C:\WINDOWS\AGRSMMSG.exe
C:\WINDOWS\system32\Rundll32.exe
C:\WINDOWS\system32\keyhook.exe
C:\Program Files\Arcade\PCMService.exe
C:\Program Files\Launch Manager\QtZgAcer.EXE
C:\Program Files\iTunes\iTunesHelper.exe
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
C:\Program Files\The Cleaner\tca.exe
C:\Program Files\The Cleaner\tcm.exe
C:\Program Files\MSN Messenger\MsnMsgr.Exe
C:\WINDOWS\system32\SSTEM~1\mshta.exe
C:\WINDOWS\system32\sistray.exe
C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\Program Files\HP\Digital Imaging\bin\hpqgalry.exe
C:\Program Files\HP\Digital Imaging\bin\hpqSTE08.exe
C:\Program Files\HP\Digital Imaging\Product Assistant\bin\hprblog.exe
C:\Program Files\acer\eRecovery\Monitor.exe
C:\Program Files\Norton AntiVirus\navapsvc.exe
C:\Documents and Settings\User\Application Data\??sembly\r?ndll.exe
C:\Program Files\Messenger\msmsgs.exe
C:\HijackThis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.google.ca/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://global.acer.com
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://global.acer.com/
R3 - URLSearchHook: (no name) - {B27FF259-63CA-143F-BFCC-30B6A8E52CC1} - C:\WINDOWS\system32\bayhrhu.dll (file
missing)
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0
\ActiveX\AcroIEHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O2 - BHO: (no name) - {B27FF259-63CA-143F-BFCC-30B6A8E52CC1} - C:\WINDOWS\system32\bayhrhu.dll (file missing)
O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program Files\Norton AntiVirus\NavShExt.dll
O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton
O4 - HKLM\..\Run: [LaunchApp] Alaunch
O4 - HKLM\..\Run: [SynTPLpr] C:\Program Files\Synaptics\SynTP\SynTPLpr.exe
O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files\Synaptics\SynTP\SynTPEnh.exe
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
O4 - HKLM\..\Run: [SiSPower] Rundll32.exe SiSPower.dll,ModeAgent
O4 - HKLM\..\Run: [SiS Windows KeyHook] C:\WINDOWS\system32\keyhook.exe
O4 - HKLM\..\Run: [IMJPMIG8.1] "C:\WINDOWS\IME\imjp8_1\IMJPMIG.EXE" /Spoil /RemAdvDef /Migration32
O4 - HKLM\..\Run: [MSPY2002] C:\WINDOWS\system32\IME\PINTLGNT\ImScInst.exe /SYNC
O4 - HKLM\..\Run: [PHIME2002ASync] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /SYNC
O4 - HKLM\..\Run: [PHIME2002A] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /IMEName
O4 - HKLM\..\Run: [PCMService] "C:\Program Files\Arcade\PCMService.exe"
O4 - HKLM\..\Run: [LManager] C:\Program Files\Launch Manager\QtZgAcer.EXE
O4 - HKLM\..\Run: [eRecoveryService] C:\Windows\System32\Check.exe
O4 - HKLM\..\Run: [HP Component Manager] "C:\Program Files\HP\hpcoretech\hpcmpmgr.exe"
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [Symantec NetDriver Monitor] C:\PROGRA~1\SYMNET~1\SNDMon.exe /Consumer
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
O4 - HKLM\..\Run: [tcactive] C:\Program Files\The Cleaner\tca.exe
O4 - HKLM\..\Run: [tcmonitor] C:\Program Files\The Cleaner\tcm.exe
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\MSN Messenger\MsnMsgr.Exe" /background
O4 - HKCU\..\Run: [Bwer] "C:\WINDOWS\system32\SSTEM~1\mshta.exe" -vt yazr
O4 - HKCU\..\Run: [Gscptbn] C:\Documents and Settings\User\Application Data\??sembly\r?ndll.exe
O4 - Global Startup: Utility Tray.lnk = C:\WINDOWS\system32\sistray.exe
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
O4 - Global Startup: HP Image Zone Fast Start.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06
\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program
O16 - DPF: {1239CC52-59EF-4DFA-8C61-90FFA846DF7E} (Musicnotes Viewer) -
http://www.musicnotes.com/download/mnviewer.cab
O16 - DPF: {1F2F4C9E-6F09-47BC-970D-3C54734667FE} (LSSupCtl Class) -
http://www.symantec.com/techsupp/asa/ctrl/LSSupCtl.cab
O16 - DPF: {3451DEDE-631F-421C-8127-FD793AFC6CC8} (ActiveDataInfo Class) -
http://www.symantec.com/techsupp/asa/ctrl/SymAData.cab
O16 - DPF: {44990200-3C9D-426D-81DF-AAB636FA4345} (Symantec SmartIssue) -
http://www.symantec.com/techsupp/asa/ctrl/tgctlsi.cab
O16 - DPF: {44990301-3C9D-426D-81DF-AAB636FA4345} (Symantec Script Runner Class) -
http://www.symantec.com/techsupp/asa/ctrl/tgctlsr.cab
O16 - DPF: {A8F2B9BD-A6A0-486A-9744-18920D898429} (ScorchPlugin Class) -
http://www.sibelius.com/download/software/win/ActiveXPlugin.cab
O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} (MsnMessengerSetupDownloadControl Class) -
http://messenger.msn.com/download/MsnMessengerSetupDownloader.cab
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - "C:\PROGRA~1\MSNMES~1\msgrapp.dll" (file missing)
O20 - AppInit_DLLs: C:\WINDOWS\system32\chkntfs.dll
O20 - Winlogon Notify: WgaLogon - C:\WINDOWS\SYSTEM32\WgaLogon.dll
O20 - Winlogon Notify: winzzd32 - winzzd32.dll (file missing)
O23 - Service: Notebook Manager Service (anbmService) - OSA Technologies Inc. - C:\Acer\eManager\anbmServ.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec
Shared\ccEvtMgr.exe
O23 - Service: Symantec Password Validation (ccPwdSvc) - Symantec Corporation - C:\Program Files\Common
Files\Symantec Shared\ccPwdSvc.exe
O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec
Shared\ccSetMgr.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common
Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: iPodService - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Norton AntiVirus Auto-Protect Service (navapsvc) - Symantec Corporation - C:\Program Files\Norton
O23 - Service: Norton AntiVirus Firewall Monitor Service (NPFMntor) - Symantec Corporation - C:\Program Files\Norton
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
O23 - Service: SAVScan - Symantec Corporation - C:\Program Files\Norton AntiVirus\SAVScan.exe
O23 - Service: ScriptBlocking Service (SBService) - Symantec Corporation - C:\PROGRA~1\COMMON~1\SYMANT~1\SCRIPT~1
\SBServ.exe
O23 - Service: Symantec Network Drivers Service (SNDSrvc) - Symantec Corporation - C:\Program Files\Common
O23 - Service: Symantec SPBBCSvc (SPBBCSvc) - Symantec Corporation - C:\Program Files\Common Files\Symantec
O23 - Service: Symantec Core LC - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\CCPD-
LC\symlcsvc.exe
Any help would be greatly appreciated; I'm a newbie at all this!
Running processes:
missing)
\bin\ssv.dll
Shared\ccEvtMgr.exe
Shared\ccSetMgr.exe
\SBServ.exe
LC\symlcsvc.exe
Please download and install ewido anti-spyware tool
- Close all other Applications Select language click Ok
- Click I Agree
- Click next
- Click Install
- Click Finish
- Wait and Ewido will open to the main screen automatically.
- Wait again a few minutes and Ewido Should Auto update itself. If it doesn't click update at top of screen.
- This in very important to get updates
- When updating has finished. Close Ewido.
If you have an "always on" connection to the internet, physically disconnect that connection until you are finished with Safe Mode and have rebooted back into normal mode.- Next, please reboot your computer in Safe Mode by doing the following:
- Restart your computer
- After hearing your computer beep once during startup, but before the Windows icon appears, press F8.
- Instead of Windows loading as normal, a menu should appear use arrow up to highlight
- Select the first option, to run Windows in Safe Mode hit enter.
- For additional help in booting into Safe Mode, see the following site: HERE
Make sure to close all open windows/programs/folders. Have nothing else open while ewido performs its scan!You MUST manage to get into Safe Mode for the fix to work.
- Open Ewido
- Click on scanner top of Ewido sceen
- Click on Settings
- Under How to Act click on Recommended Action choose Quarantine
- Under How to scan all boxes should be selected
- Under Possibly unwanted software all boxes should be selected
- On right side under Reports: click on Automatically generate report after every scan.
- Under What to scan select scan every file
- Click On scan Tab
- Click on Complete system scan
- Let the program scan the machine It can take awhile give it time.
- When scan has finished At bottom of screen click Apply all Actions
- Click Save report
- Click Save Report as (Save as window's screen should pop up.)
- Click desktop
- Click Save
- Exit ewido
Reboot back to normal modePost the Ewido log and a new hijackthis log please.
