ASUS A8R-MVP sound problem
i'm trying to get sound on my new PC and when i try to install the sound driver all i get is:
" The audio driver files do not support your computer hardware
Note: If you have uninstalled audio software without restarting your PC, restart now, then run this setup again "
I've tried the driver that was included with the A8R-MVP motherboard and a downloaded driver for it. and both do the same thing, if anyone knows why it's doing this i would really like to know what i can try to fix this becuase right now i have a computer with no sound. I don't have a sound card so i don't know if that's part of the problem or the whole problem. So if anyone can help i would appreciate it grately!!
Thanks
Thanks
Actually I don't even use the asus driver ...all I did was install the hotfix and let it run from there.
Before you do anything ...look in your add/remove software and see if you have a Microsoft High Definition Driver. If so remove it and reboot. If your audio works then I would leave it alone. If not ...then install this hotfix.
If you PM me your email I can send it right to you.
Yes i have the same problem will you send me the link?
