Sound Driver Help
edited August 2006 in Nerdery
Hi
i recently formated my computer and lost my sound driver
Im not Great with my info but here is what i got
Processor x86 Family 15 Model 4 Stepping 1 GenuineIntel ~2393 Mhz
Celeron CPU 2.40GHz 2.39 GHz ,,SiS962Lua The mother bord is a foxconn but i dont know the model of it :-/
i dunno if this info helps ?
    edited August 2006
    Without the model of the Foxconn board, it's nigh impossible to tell you what drivers to get.
  • Bad_KarmaBad_Karma The Great White North
    edited August 2006
    Foxconn driver downloads are located here:
    http://www.foxconnchannel.com/en-us/service/downloads.aspx
    You will still need to know what the model number is on your motherboard. Open up your case if you have to and keep looking for the model number.
  • edited August 2006
    Hey i found these nummbers on the bord
    Foxxconn ul6k43200963 PC 651M03-g-6l And 651M03-g-6el
    EA=00016c31edea
    ITEit8705f 0429-fxs n09mpI
    SiS 962lua
    RMC rtm360-648r-432101 4091
    Intel. c81248-001
    This is all the info i can Seee :confused:
    I hope this Helps
