Help! DDR problem.
Hi everybody! I am new to the forum. Happy holiday weekend.
I just purchased two 1Gb sticks of OCZ DDR400 platinum dual channel. I am already running two sticks of the exact same RAM in my box. I am trying to upgrade to 4GB. I am also using and Asus A8n-SLi NForce 4 mobo, and AMD64 4200x2 cpu. When I install the new sticks and try to boot, the system gets to memory test and stops. It says memory ok and lists all 4 gigs, but it just stops there. I removed the original 2 sticks and tried just the new stuff. The box booted fine. The problem is just when I try to use all 4 sticks. I have not made any changes to the bios. The manual for the mobo states that it will support 4GB of DDR400. Can anyone help? Please, this is driving me CRAZY! Thanks in advance to all.
J:usflag:
J:usflag:
And, no I did not reduce the command rate to 2T. I was not aware that I needed to do this. If I reduce the command rate to 2T, will I take a performance hit? if so will it be signifcant? Should I be able to run 3 1GB sticks without reducing the command rate?
Thanks for your help,Thrax. I haven't been able find any support on this anywhere. Even Asus was no help.
Ram timings: 2-3-2-5
FSB: 220
CPU: 2.42
And I don't really need the extra memory, just trying to speed up my rig a little more. I had gotten many different answers as to whether or not the added 2GB would make a difference or not(speedwise). So I just decided to try it. So far I can't even POST with it.
Thanks again for your help, fellas. I'm a real n00b.
j
And you are saying to first just change the timings without changing the command rate and then try to boot, and if that does not work then try changing the timing and command rate both?
I'm just trying to make my rig as fast as possible. I have the RAM and would love to use it, but if I have to take a performance hit to do it, that would defeat the whole purpose of my buying it.
Thanks.
J
And for 4 sticks to boot, you will first have to set the command rate to 2T before adding the other 2 sticks in your system.
I would first try setting the 2T command rate and try booting up like that with your present ram timing and all 4 sticks of ddr installed. If that will get you a post screen, then I would advise running memtest86 on the system for at least 2-3 passes and make sure that your system isn't having any memory related problems at 220 fsb and your stock timings before booting into windows. That would help you from inadventently messing your windows install up if the ram isn't stable at 220 fsb with 2-3-2-7 timings. If it makes a couple of complete passes with memtest86, then go ahead and boot into windows and see how your system performs with 4 GB ram.
Being that I doubt you do anything like that, 2GB will be fastest for you. I use 3D stuff and various editing and I use 2GB as well, it's just fine. If you can get 4GB to run at specs, then that would be cool, but it's not gonna happen.
Relax the timings and pump some megahurtz thru those biatches to get your performance back IMO.
j
