Anyway use USB wireless adapter as a WIFI finder
edited September 2006 in Nerdery
Hi there,
Is there anyway or application that become my USB wireless adapter to a WIFI signal finder when I connected it to the pc?
  • GHoosdumGHoosdum Icrontian
    Most WiFi cards (including the USB ones) come with a utility that finds networks that are broadcasting their SSID. This is typically called the "Site Survey" - look and see if your user's manual has any details on that.
  • Park_7677Park_7677 Missouri Member
    Wireless devices generally scans for a signal, in effect becoming a signal finder. They are designed to do that.
    Not sure exactly what you're asking for, since that's what wireless devices do by default (search for single when plugged into a computer).
    Edit: GHoosdum posted first. Most devices do come with their own software, but Windows XP (and on) have their own. Either way works.
  • edited September 2006
    Thanks a lot. :)
