critical system errors...help me please[solved]
aljaare7aljaare7 Palestine
edited November 2006 in Spyware & Virus Removal
hello I am running Microsoft Windows XP Professional. I am currently using kaspersky internet security ,hijack this, AVG Anti spyware,. I think my situation is a result of tashi's sticky post. The results are much the same and described as follows:
My taskbar currently has a flashing X and ? in a blue circle in it. A mouseover reads "Critical System Errors!" and clicking it directs me to virusburst.com.
as u see at this pic.
I've also noticed under software explorer in Windows Defender two isamonitor.exe running in startup. Then isamonitor.exe ,PMSNGR.exe PMMON.exe and isamini.exe currently running. Both paths lead to a ivedeocodec "C:\Program Files\ivedeo codec"
I also experienced an issue where I open up IE it would redirect to the safeiepage that said I had W32.Myzor.Fk@yf and numerous system warning messages would pop up through the yellow triangle sign at the bottom right hand corner and porn popups. These symptoms have not happened over the past day or so, yet I don't know what I did to stop it. I'd like to make sure this is no residual from whatever caused this.
With that problem I also had I have a blinking ! inside a yellow triangle. There was a balloon message that pops up above it too:
"System Alert: Malware threats
Your computer is infected with a back door Trojan that allows the remote attacker to perform various malicious actions. Click this Baloon to download malware removal software"
However now i removed the category "C:\Program Files\ivedeo codec"
and also "isamonitor.exe ,PMSNGR.exe PMMON.exe and isamini.exe" have stopped runnig and all that done by doing what this thread view " http://www.short-media.com/forum/showthread.php?t=50851&highlight=video+codec " and i think its a similar problem
the main thing i want to say that my task bar is still flashingX and ? in a blue circle in it A mouseover reads "Critical System Errors!" and clicking it directs me to virusburst.com.
so please help me remove it
  • aljaare7aljaare7 Palestine
    Logfile of HijackThis v1.99.1
    Scan saved at 10:50:01 PM, on 11/3/2006
    MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
    Running processes:
    C:\WINDOWS\System32\smss.exe
    C:\WINDOWS\system32\lsass.exe
    C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
    C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
    C:\Program Files\ThinkPad\ConnectUtilities\AcPrfMgrSvc.exe
    C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
    C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 6.0\avp.exe
    C:\Program Files\Lenovo\Bluetooth Software\bin\btwdins.exe
    C:\Program Files\Softex\OmniPass\Omniserv.exe
    C:\WINDOWS\system32\PMSveH.exe
    C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
    C:\WINDOWS\system32\PMHandler.exe
    C:\Program Files\ThinkPad\ConnectUtilities\AcSvc.exe
    C:\Program Files\Softex\OmniPass\OPXPApp.exe
    C:\WINDOWS\Explorer.EXE
    C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\avgas.exe
    C:\Program Files\Java\jre1.5.0_09\bin\jusched.exe
    C:\Documents and Settings\mahdi\Desktop\HijackThis.exe
    O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
    O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_09\bin\ssv.dll
    O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
    O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar2.dll
    O2 - BHO: Windows Live Toolbar Helper - {BDBD1DAD-C946-4A17-ADC1-64B5B4FF55D0} - C:\Program Files\Windows Live Toolbar\msntb.dll
    O3 - Toolbar: Windows Live Toolbar - {BDAD1DAD-C946-4A17-ADC1-64B5B4FF55D0} - C:\Program Files\Windows Live Toolbar\msntb.dll
    O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar2.dll
    O4 - HKLM\..\Run: [kis] "C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 6.0\avp.exe"
    O4 - HKLM\..\Run: [!AVG Anti-Spyware] "C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\avgas.exe" /minimized
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.5.0_09\bin\jusched.exe"
    O8 - Extra context menu item: &Google Search - res://c:\program files\google\GoogleToolbar2.dll/cmsearch.html
    O8 - Extra context menu item: &Translate English Word - res://c:\program files\google\GoogleToolbar2.dll/cmwordtrans.html
    O8 - Extra context menu item: &Windows Live Search - res://C:\Program Files\Windows Live Toolbar\msntb.dll/search.htm
    O8 - Extra context menu item: Add to Kaspersky Anti-Banner - C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 6.0\\ie_banner_deny.htm
    O8 - Extra context menu item: Backward Links - res://c:\program files\google\GoogleToolbar2.dll/cmbacklinks.html
    O8 - Extra context menu item: Cached Snapshot of Page - res://c:\program files\google\GoogleToolbar2.dll/cmcache.html
    O8 - Extra context menu item: Open in new background tab - res://C:\Program Files\Windows Live Toolbar\Components\en-us\msntabres.dll.mui/229?cca29128168e4313b0095a7b58fe1b40
    O8 - Extra context menu item: Open in new foreground tab - res://C:\Program Files\Windows Live Toolbar\Components\en-us\msntabres.dll.mui/230?cca29128168e4313b0095a7b58fe1b40
    O8 - Extra context menu item: Send to &Bluetooth Device... - C:\Program Files\Lenovo\Bluetooth Software\btsendto_ie_ctx.htm
    O8 - Extra context menu item: Similar Pages - res://c:\program files\google\GoogleToolbar2.dll/cmsimilar.html
    O8 - Extra context menu item: Translate Page into English - res://c:\program files\google\GoogleToolbar2.dll/cmtrans.html
    O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_09\bin\npjpi150_09.dll
    O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_09\bin\npjpi150_09.dll
    O9 - Extra button: Web Anti-Virus - {1F460357-8A94-4D71-9CA3-AA4ACF32ED8E} - C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 6.0\scieplugin.dll
    O11 - Options group: [JAVA_IBM] Java (IBM)
    O18 - Protocol: livecall - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
    O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
    O20 - AppInit_DLLs: C:\PROGRA~1\KASPER~1\KASPER~1.0\adialhk.dll
    O20 - Winlogon Notify: ACNotify - ACNotify.dll (file missing)
    O20 - Winlogon Notify: igfxcui - C:\WINDOWS\SYSTEM32\igfxdev.dll
    O20 - Winlogon Notify: klogon - C:\WINDOWS\system32\klogon.dll
    O20 - Winlogon Notify: OPXPGina - C:\Program Files\Softex\OmniPass\opxpgina.dll
    O20 - Winlogon Notify: tphotkey - C:\WINDOWS\SYSTEM32\tphklock.dll
    O21 - SSODL: bonspells - {11853d5f-f894-4cc7-bbc3-fc7a9dcfd896} - C:\WINDOWS\system32\okkmtv.dll
    O23 - Service: Ac Profile Manager Service (AcPrfMgrSvc) - Unknown owner - C:\Program Files\ThinkPad\ConnectUtilities\AcPrfMgrSvc.exe
    O23 - Service: Access Connections Main Service (AcSvc) - Lenovo - C:\Program Files\ThinkPad\ConnectUtilities\AcSvc.exe
    O23 - Service: AVG Anti-Spyware Guard - Anti-Malware Development a.s. - C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
    O23 - Service: Kaspersky Internet Security 6.0 (AVP) - Unknown owner - C:\Program Files\Kaspersky Lab\Kaspersky Internet Security 6.0\avp.exe" -r (file missing)
    O23 - Service: Bluetooth Service (btwdins) - Broadcom Corporation. - C:\Program Files\Lenovo\Bluetooth Software\bin\btwdins.exe
    O23 - Service: Intel(R) PROSet/Wireless Event Log (EvtEng) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
    O23 - Service: Softex OmniPass Service (omniserv) - Softex Inc. - C:\Program Files\Softex\OmniPass\Omniserv.exe
    O23 - Service: PMSveH - Lenovo - C:\WINDOWS\system32\PMSveH.exe
    O23 - Service: Intel(R) PROSet/Wireless Registry Service (RegSrvc) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
    O23 - Service: Intel(R) PROSet/Wireless Service (S24EventMonitor) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
    O23 - Service: TuneUp WinStyler Theme Service (TUWinStylerThemeSvc) - TuneUp Software GmbH - C:\Program Files\TuneUp Utilities 2006\WinStylerThemeSvc.exe
  • edited November 2006
    you can try to delete \windows\system32\okkmtv.dll
    I too am having the same issue with this root infection. Through google I have managed to get rid of the annoying question mark but now have the blanking exclamation point in yellow. Which says Security Alert: NetWorm-i.Virus@fp when I run my mouse over it. Please help as well!
    I ran a System Restore to a date prior to when this problem began occurring. That knocked it out in one fell swoop. I'm glad it's gone; that was annoying!
    :banghead:
    For those who haven't done a system restore before, go to Accessories -> System Tools -> System Restore and select a date before this problem starting happening. This may remove programs that you've installed since that date, but if you need to you can undo the systems restore.
    Good luck!
    :banghead:
    Good luck!
    lol.. I feel so dumb right about now. I just completed the system restore and wala, problem solved! Thanks for the tip!
    Excellent! Glad I could help. The System Restore thing was a last resort shot-in-the-dark idea. Just got lucky.
    :cheers:
  • jmoney3457jmoney3457 Maine
    thank you for helping him bee :) i'll mark this resolved/lock it
