Algebra Problem help
edited November 2006 in Software
Hi,
I have matrix A of [ I/100 + 0.1 I/100 + 0.2 I/100 + 0.3 I/100 + 0.4
I/100 + 0.7 I/100 + 0.8 I/100 + 0.9 I/100 + 1.1 ]
[2 0
0 2
0 0
0 0
0 0
0 0]
I tried A = [I\100 + 0.1 I\100 + 0.2 I\100 + 0.3 I\100 +0.4 ; I\100 + 0.7 I\100 + 0.8 I\100 + 0.9 I\100 + 1.0] + [ 2 0 ; 0 2; 0 0; 0 0; 0 0; 0 0]
And there is this error:
??? Capitalized internal function I; Caps Lock may be on.
So how should i write this part? please advise. Thanks.
  • CycloniteCyclonite Tampa, Florida Icrontian
    What application are you using to calculate?
    Is this an addition of matrices? If so, they have to be the same dimensions. What does the 'I' signify? Is it just a variable for which you're trying to solve, or does it represent an imaginary number?
    if this is matlab, and you mean i = sqrt(-1), you need to use a lower case i (or j).
  • edited November 2006
    Hi,
    Here's the attached question.
    Here's my try:
    A = [I/100+0.1; I/100+0.2; I/100+0.3; I/100+0.4; I/100+0.5; I/100+0.6; I/100+0.7; I/100+0.8; I/100+0.9; I/100+1.0; I/100+1.1; I/100+1.2; I/100+1.3; I/100+1.4; I/100+1.5; I/100+1.6; I/100+1.7; I/100+1.8; I/100+1.9; I/100+2.0; I/100+2.1; I/100+2.2; I/100+2.3; I/100+2.4; I/100+2.5; I/100+2.6; I/100+2.7; I/100+2.8; I/100+2.9; I/100+3.0; I/100+3.1; I/100+3.2; I/100+3.3; I/100+3.4; I/100+3.5; I/100+3.6] + [2 0 0 0 0 0; 0 2 0 0 0 0; 0 0 2 0 0 0; 0 0 0 2 0 0;0 0 0 0 2 0; 0 0 0 0 0 2]
    And here's the error:
    In this case, I is undefined. So what should i input to make this program works? Please advise. Thanks
    use lowercase i. I = sqrt(-1). In matlab, i = j = sqrt(-1).
