Computer will not power up
I'm trying to help an elderly friend. She has an HP Pavillion 511W. She apparently had some kind of virus problem that caused her to ultimately reset back to the original state in which the PC came. She shut it down and was then going to try to get up to speed by first reinstalling McAfee.
However, the computer will no longer power up. When you plug it in the green led next to the power cord socket will flash once, but nothing happens.
I believe it may be a power supply problem, but wanted to check if there is anything else I should look at or try first. Thank you.
Thanks. Will try that, but I suspect a new power supply is on the horizon.
