Help!!
I need help I just keep get this error over and over again. I have try changing versions, changing flags, erasing everything and starting over. I can't seem to get it nailed down. I gone as far as testing every part of my system, and clean the dust out of everything. Does anyone have any Ideas? Thanks, Adam
__________________________________________________
[14:56:57] Sending work to server
[14:56:57] + Attempting to send results
[14:58:30] - Server reports digital signature does not match.
[14:58:30] (May be due to corruption during network transmission or a corrupted file.)
[14:58:30] - Error: Could not transmit unit 01 (completed October 22). Keeping unit in queue.
[14:58:30] + Attempting to send results
[14:59:27] - Server reports digital signature does not match.
[14:59:27] (May be due to corruption during network transmission or a corrupted file.)
[14:59:27] - Error: Could not transmit unit 01 (completed October 22). Keeping unit in queue.
[14:59:27] + Attempting to get work packet
[14:59:27] - Connecting to assignment server
[14:59:28] - Successful: assigned to (171.67.89.149).
[14:59:28] + News From Folding@Home: Welcome to Folding@Home
[14:59:28] Loaded queue successfully.
[14:59:30] + Closed connections
Then uninstall the whole F@H client and core installation, download a new client, use same F@H user ID and if this is a new box, a NEW machine ID like 3. Let it set itself up, then quit it and move back what you backed up adn see what happens. If the error reappears you have a corrupt wudata archive, but when I had this the UID Hash had gotten corrupted or I had told two boxes to use the same machine ID number-- THEN, the F@H server would take WUs for only one machine.
If you are using the Windows GRAPHIC client let us know, we can find the config file that you can edit to tell the new box to use a different machine ID or tell you how to start|run the client with specific codes to force it to reconfigure itself maybe also. Sometimes, copying a client archive to another box can result in two boxes having the same machine user ID and then the servers can object on grounds that two boxes are using one machine ID and same UID and know it by timing of WU turnins.
Each new box gets its own machine ID usually, and the combo of User ID and Machine ID are made into what is called a hash (hashing takes a string of text and numbers, runs them through something kinda like encryption-- can also be a BASE transaltion, like what Linux uses as Base64 or Base256 for security, essentially the thing you can understand is coded in a different number base system and each machine needs its own) but which is a unique code for each machine if one thinks in plain English. One of the instructions in for installing says to make sure to download a new client for each new machine and folks can get into trouble by copying the archives to multiple boxes if the boxes all try to call in WUs.
Overclocking can do this also especially if RAM is overheating, having a virus stick junk in your download can (and F@H does not do that, but a virus on your box COULD possibly do this), and having RAM that is acting up or a RAM stick not seated right (just partly in socket all the way,maybe one end not down all the way) can do this, as can RAM that is physically malfunctioning or not matched in speed to other RAM in computer or not set right in BIOS or misdetected by BIOS and not set up except by BIOS(in this last case, could be not compatible with that particular box while not defective in and of itself-- wrong RAM for YOUR computer).
Try the client stuff first, then try checking the RAM very thoroughly.
John.
Hope this helps.:)
Have you tried coping Work folder, queue and log files to another computer and trying it there?
Are you using a download/upload manager? Some of them can ocassionally goof up and corrupt a file transmission.
And as Ageek mentioned, a virus scan wouldn't be a bad idea, if your "testing every part of my system" didn't already include that.
Good luck!
Maybe somebody at Stanford in the support department could shed some light on the cause of the error.
Maybe they can help.
