Help?
A few days ago, I was playing WoW... My computer suddenly froze and I couldn't do anything. I forcefully turned off my PC and rebooted it up. Everything turns on just fine and everything is plugged in, but after a few seconds after the computer turns on, it beeps 5 times and nothing appears on the screen. Did my video card over heat? I'm not sure exactly what to do and I'm not very smart about computers. Help would be greatly appreciated.
Thanks.
Thanks.
http://www.computerhope.com/beep.htm
If you do a search on "beep codes" in your favorite search engine, you'll get lotsa hits.
In any case, beeps indicate a hardware issue. If you have no display, your video CCA (circuit card assembly) may have failed. Do you know how to change a circuit card (expansion card) inside your computer?
