Urgent No POST problem
Hello everyone and Happy New Year,
I was trying to flash the AGP graphics adapter with a new bios release for it but unfortunately I used the wrong file to perform the flash and now the computer will not POST at all.
I have a backup copy of the previous flash version on the floppy disk but I since I can't get the computer to POST and boot from the floppy again, I can't recover the graphics adapter back to it's original BIOS edition.
Is there any way to make the computer POST again and boot from the floppy drive or any other method I should to flash the graphics adapter with the correct BIOS version once more ?
Thanks for all your help and I hope there's a way to sort this problem out.
I've never tried this b4 but...How 'bout this... do you have an old PCI video adapter you can drop in? If so, pull the AGP card. Install the PCI card. Don't bother w/ the drivers in your GUI for the PCI card yet. If it works enough to provide video in REAL (DOS) MODE, that's all you need for now.
Get into the system BIOS w/ the PCI video adapter installed. Set the system BIOS video detection order to PCI/AGP (if it's available). Now,shut down and add the AGP card. Let's see if you can get away w/ booting w/ the AGP and the PCI video cards installed. If so,
I'll have to look and see if there's a vga adapter lying around somewhere so I can try what you suggest.
It's sounds pretty ominous though.. If I remove the AGP card that has been flashed wrongly and put in a different AGP video adapter altogeter do you think the computer will be able to post ?
You're certainly welcome. That's what we're here for.
In answer to your question, I doubt the bad BIOS caused any damage to your system hardware. So a replacement AGP video adapter should work fine. The steps I outlined are more to salvage the AGP video adapter. If it's not important to you and you have other AGP cards laying around, you might just want to toss the critter and write it off as the price paid for a lesson learned.
Don't feel bad. We have a-l-l shot ourselves in the foot from time to time. As we gain more experience, we learn to be more cautious - taking precautions we might otherwise not have in our "younger days". That's just one of the fruits of "experience" - learning from (most often our own) mistakes
I was asking about the alternative AGP card because it's more likely I'll be able to dig out an old AGP card rather than a simple PCI vga graphics card
There I was, thinking the bios release I flashed the AGP with will provide an improved performance
Well, that's the way the mop flops sometimes. I would be interested if the method I suggested (to recover the AGP card) works. I've never tried that b4.
Be sure to let us know, ok?
Nice way to kick off 2007
I will certainly let you know if I manage to restore the BIOS of my faulty AGP card when I use it in a machine that has a PCI VGA adapter already on it.
Thanks again for all your suggestions Pterocarpous
My pleasure, nonstop301. Glad you got it cookin' again.
Happy New Year!
I know it doesn't sound like the best idea but the purpose is just to achieve a successful POST to boot from a floppy and flash the AGP with the right BIOS
Do PCIexpress cards work at all if they are fitted on a motherboard that only has regular PCI slots ?
Notice the key for the PCIe slots is on the left. The key for the old style PCI slot is on the right. The key is the bar that crosses the connector perpendicular to its length. The purpose of it is to keep us from plugging in a card backwards or misaligned.
It's just regular PCI then I have to turn to for this purpose.
I still can't believe the other card I found and have to use at the moment is AGP
Yep, it's the PCI way or the Highway.... The industry, I believe, tries to protect us from ourselves w/ form factor changes from one technology to the next. It's actually a good thing in this instance.
Is the AGP card you're trying to salvage a high end card? If so, I'd pursue finding the elusive (and obsolete) PCI graphics card. If not, I'd send it to computer parts heaven and move on......:bigggrin:
On the other hand, it is intriguing.... hard to resist the temptation to track down a PCI card and try it out just to see if it'd work.....would be for me anyway....
The AGP card isn't anything special but I consider it more than adequate for the purposes it has to fulfill for me
It's time will come and an upgrade will be inevitable, but I'd rather upgrade a working AGP and keep it in the goody bag since you never know when it might come in handy
I have now found a PCI graphics adapter for that matter, so when I get home I'll give it a shot and see whether I can successfully recover the original BIOS of the AGP
Good luck!
I think I'll try and boot into windows with both the PCI and the AGP in place and try a flash utlity that operates under windows instead. That will also give me a chance to see what the windwos device manager has detected.
It's not looking very good for the AGP at the moment
I think I'll try and boot into windows with both the PCI and the AGP in place and try a flash utlity that operates under windows instead. That will also give me a chance to see what the windows device manager has detected.
In Windows the PCI card is detected and drivers for it are installed automatically so it's working properly. With the AGP I get the appearance of the Found New Hardware Wizard so I'll use the CD that came with the card to see whether this will help in any way. Unfortunately, the CD that came with the card tells me Sorry We Don't Support This VGA Card
I have a flash utility for the AGP that works under Windows so I'll try that and see if it does anything noteworthy
I think it's curtains for the AGP card unfortunately and a bad BIOS flash has taken it to the point of no return.
If anyone has any other ideas on how I can flash it back to its original BIOS I would be most grateful
We sure don't win all the battles do we? Well you gave it a try, didncha! Sometimes that's all we can do.
