I need help to finish cleaning up and removing Vundo and other viruses - RdRash
Hi,
I have two issues that may or may not be related that I would really appreciate help in fixing. If it is easier we can deal with one issue at a time.
The first issue is:
I need help to finish cleaning up my PC. I have been working on cleaning up my PC after getting pilfered with the Vundo, VirtuMonde, AdClicker, Infostealer viruses. Vundo has been the hardest to remove but I am close after gaining insight from your forum on how to remove it. I have Norton Internet Security and it thought it had cleaned up Vundo especially after running Nortons “FixVundo.exe” file but no such luck I found Vundo files C:\WINDOWS\system32\ mlkkj.bak1, .bak2, .ini. ini2, .tmp. that told me Norton wasn’t really able to clean it all up. Norton says it has cleaned up the other viruses as well.
I ran VundoFix.exe v6.2.13 by Atribune, it took a few times running it both in the Safe boot and normal boot modes to delete the C:\WINDOWS\system32\jkklm.dll. It looks to be gone.
Can you take a look at my HijackThis log, VundoFix log and the other logs to let me know what else I should do to completely remove these viruses? These log files were created after VundoFix deleted all the Vundo files (PC in normal boot mode).
I cleaned out all of my temporary internet and temp files both manually prior to running VundoFix.exe and then again after ran VundoFix using ATF (Atribune Temp File) Cleaner© by Atribune.
I installed/scanned with Ad-Aware SE.
I installed/scanned with SpyBot Search & Destroy.
I installed/ran SpywareBlaster.
I installed/scanned my computer for malware using all three on-line scans, Panda ActiveScan, Kaspersky Online Virus Scan and BitDefender Online Scanner. Can you look at their log files to let me know if I need to do anything to fix the issues they identified or not?
I re-ran HijackThis after running all the above applications in normal boot mode, the log file at the bottom.
The second issue is:
With my PC connected to the internet and running in normal boot mode I get the following pop up window occurring rather frequently with the following message:
“Server Busy
This action cannot be completed because the other program is busy. Choose ‘Switch To’ to activate the busy program and correct the problem.”
When I click the ‘Switch To’ button on the popup window it activates the “Start” button on the toolbar. But I don’t know what server or program it is looking for me to take action on. After doing this the message window will disappear for a while then come back again later. Some times in a very short time period, other times after a long time period. The longer my PC is running the longer the time period is between when the message window pops up. This message window does not occur when the PC is running in safe boot mode or if the network cable is unplugged.
Do you know what is causing this error message window? Is it due to a virus or something else? How can I fix the issue?
Thanks in advance
RdRash
All the logs are below in the order the programs were run and the logs were created.
I had to submit this thread in two posts since it exceeds the 50000 character limit.
VundoFix V6.2.13
Checking Java version...
Java version is 1.5.0.6
Scan started at 8:29:31 PM 12/31/2006
Listing files found while scanning....
C:\WINDOWS\system32\mlkkj.ini
C:\WINDOWS\system32\mlkkj.bak1
C:\WINDOWS\system32\mlkkj.bak2
C:\WINDOWS\system32\mlkkj.ini2
C:\WINDOWS\system32\mlkkj.tmp
Beginning removal...
Attempting to delete C:\WINDOWS\system32\jkklm.dll
C:\WINDOWS\system32\jkklm.dll Could not be deleted.
Attempting to delete C:\WINDOWS\system32\mlkkj.ini
C:\WINDOWS\system32\mlkkj.ini Has been deleted!
Attempting to delete C:\WINDOWS\system32\mlkkj.bak1
C:\WINDOWS\system32\mlkkj.bak1 Has been deleted!
Attempting to delete C:\WINDOWS\system32\mlkkj.bak2
C:\WINDOWS\system32\mlkkj.bak2 Has been deleted!
Attempting to delete C:\WINDOWS\system32\mlkkj.ini2
C:\WINDOWS\system32\mlkkj.ini2 Has been deleted!
Attempting to delete C:\WINDOWS\system32\mlkkj.tmp
C:\WINDOWS\system32\mlkkj.tmp Has been deleted!
Performing Repairs to the registry.
Done!
Done!
VundoFix V6.2.13
Scan started at 8:56:18 PM 12/31/2006
C:\WINDOWS\system32\jkklm.dll Has been deleted!
Done!
VundoFix V6.2.13
Scan started at 9:19:09 PM 12/31/2006
No infected files were found.
Ad-Aware SE Log file:
Ad-Aware SE Build 1.06r1
Logfile Created on:Monday, January 01, 2007 2:09:02 AM
Created with Ad-Aware SE Personal, free for private use.
Using definitions file:SE1R141 27.12.2006
References detected during the scan:
Adware.BHO(generic)(TAC index:3):1 total references
Coulomb Dialer(TAC index:5):1 total references
SearchFast(TAC index:5):7 total references
Ad-Aware SE Settings
Set : Search for negligible risk entries
Set : Safe mode (always request confirmation)
Set : Scan active processes
Set : Scan registry
Set : Deep-scan registry
Set : Scan my IE Favorites for banned URLs
Set : Scan my Hosts file
Extended Ad-Aware SE Settings
Set : Unload recognized processes & modules during scan
Set : Scan registry for all users instead of current user only
Set : Always try to unload modules before deletion
Set : During removal, unload Explorer and IE if necessary
Set : Let Windows remove files in use at next reboot
Set : Delete quarantined objects after restoring
Set : Include basic Ad-Aware settings in log file
Set : Include additional Ad-Aware settings in log file
Set : Include reference summary in log file
Set : Include alternate data stream details in log file
Set : Play sound at scan completion if scan locates critical objects
1-1-2007 2:09:02 AM - Scan started. (Full System Scan)
Listing running processes
#:1 [smss.exe]
FilePath : \SystemRoot\System32\
ProcessID : 540
ThreadCreationTime : 1-1-2007 5:51:17 AM
BasePriority : Normal
#:2 [csrss.exe]
FilePath : \??\C:\WINDOWS\system32\
ProcessID : 612
ThreadCreationTime : 1-1-2007 5:51:22 AM
#:3 [winlogon.exe]
ProcessID : 636
ThreadCreationTime : 1-1-2007 5:51:23 AM
BasePriority : High
#:4 [services.exe]
FilePath : C:\WINDOWS\system32\
ProcessID : 684
ThreadCreationTime : 1-1-2007 5:51:24 AM
FileVersion : 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
ProductVersion : 5.1.2600.2180
ProductName : Microsoft® Windows® Operating System
CompanyName : Microsoft Corporation
FileDescription : Services and Controller app
InternalName : services.exe
LegalCopyright : © Microsoft Corporation. All rights reserved.
OriginalFilename : services.exe
#:5 [lsass.exe]
ProcessID : 696
FileDescription : LSA Shell (Export Version)
InternalName : lsass.exe
OriginalFilename : lsass.exe
#:6 [svchost.exe]
ProcessID : 856
ThreadCreationTime : 1-1-2007 5:51:25 AM
FileDescription : Generic Host Process for Win32 Services
InternalName : svchost.exe
OriginalFilename : svchost.exe
#:7 [svchost.exe]
ProcessID : 904
ThreadCreationTime : 1-1-2007 5:51:26 AM
#:8 [svchost.exe]
FilePath : C:\WINDOWS\System32\
ProcessID : 972
#:9 [svchost.exe]
ProcessID : 1040
ThreadCreationTime : 1-1-2007 5:51:27 AM
#:10 [svchost.exe]
ProcessID : 1128
#:11 [ccsvchst.exe]
FilePath : C:\Program Files\Common Files\Symantec Shared\
ProcessID : 1288
ThreadCreationTime : 1-1-2007 5:51:29 AM
FileVersion : 106.1.3.3
ProductVersion : 106.1.3.3
ProductName : Symantec Security Technologies
CompanyName : Symantec Corporation
FileDescription : Symantec Service Framework
InternalName : ccSvcHst
LegalCopyright : Copyright (c) 2000-2006 Symantec Corporation. All rights reserved.
OriginalFilename : ccSvcHst.exe
#:12 [appsvc32.exe]
FilePath : C:\Program Files\Common Files\Symantec Shared\AppCore\
ProcessID : 1356
ThreadCreationTime : 1-1-2007 5:51:30 AM
FileVersion : 1.0.00.101
ProductVersion : 1.0
ProductName : Symantec Application Core
FileDescription : Symantec Application Core Service
InternalName : AppSvc32
LegalCopyright : Copyright (c) 1997-2006 Symantec Corporation
OriginalFilename : AppSvc32.exe
#:13 [spoolsv.exe]
ProcessID : 1468
ThreadCreationTime : 1-1-2007 5:51:31 AM
FileVersion : 5.1.2600.2696 (xpsp_sp2_gdr.050610-1519)
ProductVersion : 5.1.2600.2696
FileDescription : Spooler SubSystem App
InternalName : spoolsv.exe
OriginalFilename : spoolsv.exe
#:14 [aluschedulersvc.exe]
FilePath : C:\Program Files\Symantec\LiveUpdate\
ProcessID : 260
ThreadCreationTime : 1-1-2007 5:51:38 AM
FileVersion : 3.1.0.99
ProductVersion : 3.1.0.99
ProductName : LiveUpdate
FileDescription : Automatic LiveUpdate Scheduler Service
InternalName : Automatic LiveUpdate Scheduler Service
LegalCopyright : Copyright © 1996-2006 Symantec Corporation
OriginalFilename : ALUSchedulerSvc.exe
#:15 [ehrecvr.exe]
FilePath : C:\WINDOWS\eHome\
ProcessID : 400
BasePriority : Above Normal
FileVersion : 5.1.2715.2883 (xpsp(wmbla).060409-2023)
ProductVersion : 5.1.2715.2883
FileDescription : Media Center Receiver Service
InternalName : ehRecvr
OriginalFilename : ehRecvr.exe
#:16 [ehsched.exe]
ProcessID : 416
FileVersion : 5.1.2710.2732 (xpsp(wmbla).050805-1239)
ProductVersion : 5.1.2710.2732
FileDescription : Media Center Scheduler Service
InternalName : ehSched
OriginalFilename : ehSched.exe
#:17 [svchost.exe]
ProcessID : 440
#:18 [lssrvc.exe]
FilePath : C:\Program Files\Common Files\LightScribe\
ProcessID : 556
FileVersion : 1.4.31.1
ProductName : LightScribe
CompanyName : Hewlett-Packard Company
LegalCopyright : © Copyright 2003-2005 Hewlett-Packard Development Company, LP
OriginalFilename : LSSrvc.exe
#:19 [mdm.exe]
FilePath : C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\
ProcessID : 760
ThreadCreationTime : 1-1-2007 5:51:39 AM
FileVersion : 7.00.9466
ProductVersion : 7.00.9466
ProductName : Microsoft® Visual Studio .NET
FileDescription : Machine Debug Manager
InternalName : mdm.exe
OriginalFilename : mdm.exe
#:20 [svchost.exe]
ProcessID : 1276
ThreadCreationTime : 1-1-2007 5:51:42 AM
#:21 [svchost.exe]
ProcessID : 1408
#:22 [mcrdsvc.exe]
FilePath : C:\WINDOWS\ehome\
ProcessID : 1692
FileVersion : 4.1.2710.2732 (xpsp(wmbla).050805-1239)
ProductVersion : 4.1.2710.2732
FileDescription : MCRD Device Service
InternalName : McrdSvc.exe
OriginalFilename : McrdSvc.exe
#:23 [wmpnetwk.exe]
FilePath : C:\Program Files\Windows Media Player\
ProcessID : 1852
FileVersion : 11.0.5721.5145 (WMP_11.061018-2006)
ProductVersion : 11.0.5721.5145
FileDescription : Windows Media Player Network Sharing Service
InternalName : Windows Media Player Network Sharing Service
OriginalFilename : WMPNetwk.exe
#:24 [dllhost.exe]
ProcessID : 2220
ThreadCreationTime : 1-1-2007 5:51:43 AM
FileDescription : COM Surrogate
InternalName : dllhost.exe
OriginalFilename : dllhost.exe
#:25 [alg.exe]
ProcessID : 2420
ThreadCreationTime : 1-1-2007 5:51:44 AM
FileDescription : Application Layer Gateway Service
InternalName : ALG.exe
OriginalFilename : ALG.exe
#:26 [explorer.exe]
ProcessID : 3020
ThreadCreationTime : 1-1-2007 5:51:59 AM
FileVersion : 6.00.2900.2180 (xpsp_sp2_rtm.040803-2158)
ProductVersion : 6.00.2900.2180
FileDescription : Windows Explorer
InternalName : explorer
OriginalFilename : EXPLORER.EXE
#:27 [ehtray.exe]
ProcessID : 3272
ThreadCreationTime : 1-1-2007 5:52:02 AM
FileDescription : Media Center Tray Applet
InternalName : ehtray
OriginalFilename : ehtray.exe
#:28 [hkcmd.exe]
ProcessID : 3288
FileVersion : 3.0.0.4332
ProductVersion : 7.0.0.4332
ProductName : Intel(R) Common User Interface
CompanyName : Intel Corporation
FileDescription : hkcmd Module
InternalName : HKCMD
LegalCopyright : Copyright 1999-2004, Intel Corporation
OriginalFilename : HKCMD.EXE
#:29 [igfxpers.exe]
ProcessID : 3332
ThreadCreationTime : 1-1-2007 5:52:03 AM
FileDescription : persistence Module
InternalName : PERSISTENCE
OriginalFilename : IGFXPERS.EXE
#:30 [sm56hlpr.exe]
ProcessID : 3404
ThreadCreationTime : 1-1-2007 5:52:04 AM
FileVersion : 6.10.01
ProductVersion : SM56 Rel. 6.10 Build 01
ProductName : Motorola SM56 Tray Application
CompanyName : Motorola Inc.
FileDescription : Motorola SM56 Win32 Utility
InternalName : SM56 Modem Helper
LegalCopyright : Copyright © 1998-2004, Motorola Inc.
OriginalFilename : SM56HLPR.EXE
#:31 [ehmsas.exe]
ProcessID : 3412
FileDescription : Media Center Media Status Aggregator Service
InternalName : eHMSAS
OriginalFilename : ehMSAS.exe
#:32 [lsburnwatcher.exe]
FilePath : C:\hp\drivers\hplsbwatcher\
ProcessID : 3436
FileVersion : 4, 10, 15, 0
ProductVersion : 4, 10, 15, 0
FileDescription : LightScribe Burn Watcher
InternalName : LSBurnWatcher
LegalCopyright : Copyright (C) 2005
OriginalFilename : LSBurnWatcher.exe
Comments : LightScribe automatic labeller launcher; waits to see when you've written a music CD and helps you create the LightScribe label for it.
#:33 [hpwuschd2.exe]
FilePath : C:\Program Files\HP\HP Software Update\
ProcessID : 3444
FileVersion : 61.0.163.000
ProductVersion : 061.000.163.000
ProductName : hp digital imaging
CompanyName : Hewlett-Packard Development Company, L.P.
FileDescription : Hewlett-Packard Product Assistant
InternalName : hpwuSchd2
LegalCopyright : Copyright (C) Hewlett-Packard Development Company, L.P. 1995-2005
OriginalFilename : hpwuSchd2.exe
Comments : Hewlett-Packard Product Assistant
#:34 [realsched.exe]
FilePath : C:\Program Files\Common Files\Real\Update_OB\
ProcessID : 3452
FileVersion : 0.1.0.3249
ProductVersion : 0.1.0.3249
ProductName : RealPlayer (32-bit)
CompanyName : RealNetworks, Inc.
FileDescription : RealNetworks Scheduler
InternalName : schedapp
LegalCopyright : Copyright © RealNetworks, Inc. 1995-2004
LegalTrademarks : RealAudio(tm) is a trademark of RealNetworks, Inc.
OriginalFilename : realsched.exe
#:35 [jusched.exe]
FilePath : C:\Program Files\Java\jre1.5.0_10\bin\
ProcessID : 3464
#:36 [apdproxy.exe]
FilePath : C:\Program Files\Adobe\Photoshop Album Starter Edition\3.0\Apps\
ProcessID : 3492
ThreadCreationTime : 1-1-2007 5:52:05 AM
#:37 [hpztsb07.exe]
FilePath : C:\WINDOWS\system32\spool\drivers\w32x86\3\
ProcessID : 3512
FileVersion : 2,140,0,0
ProductVersion : 2,140,0,0
ProductName : HP DeskJet
CompanyName : HP
LegalCopyright : Copyright (c) Hewlett-Packard Company 1999-2002
#:38 [hphmon04.exe]
ProcessID : 3616
FileVersion : 4,2,41
ProductVersion : 4,2,41
ProductName : hp photosmart
FileDescription : HPHmon04
InternalName : HPHmon04
LegalCopyright : Copyright (C) 2001
OriginalFilename : HPHmon04.exe
#:39 [onetouch.exe]
FilePath : C:\PROGRA~1\Maxtor\OneTouch\Utils\
ProcessID : 3752
ThreadCreationTime : 1-1-2007 5:52:06 AM
FileVersion : 2, 0, 0, 0
ProductVersion : 2, 0, 0, 0
ProductName : Maxtor OneTouch
CompanyName : Maxtor
FileDescription : Maxtor OneTouch Detection
InternalName : ComboButton
LegalCopyright : Copyright (C) 2003 Maxtor Corp.
OriginalFilename : OneTouch.EXE
#:40 [mxoaldr.exe]
ProcessID : 3808
FileVersion : 6.00.1010.0
ProductVersion : 6.00.1010.0
ProductName : MXO Storage Adapter
CompanyName : Cypress Semiconductor
FileDescription : Maxtor MXO Auto Loader Application
InternalName : MXOALDR.EXE
LegalCopyright : Copyright (C) 1998-2002 Cypress Semiconductor
OriginalFilename : MXOALDR.EXE
#:41 [ituneshelper.exe]
FilePath : C:\Program Files\iTunes\
ProcessID : 3848
ThreadCreationTime : 1-1-2007 5:52:07 AM
FileVersion : 6.0.4.2
ProductVersion : 6.0.4.2
ProductName : iTunes
CompanyName : Apple Computer, Inc.
FileDescription : iTunesHelper Module
InternalName : iTunesHelper
LegalCopyright : © 2003-2006 Apple Computer, Inc. All Rights Reserved.
OriginalFilename : iTunesHelper.exe
#:42 [qttask.exe]
FilePath : C:\Program Files\QuickTime\
ProcessID : 3888
FileVersion : 7.1
ProductVersion : QuickTime 7.1
ProductName : QuickTime
FileDescription : QuickTime Task
InternalName : QuickTime Task
LegalCopyright : Copyright Apple Computer, Inc. 1989-2006
OriginalFilename : QTTask.exe
#:43 [ccapp.exe]
ProcessID : 3900
FileDescription : Symantec User Session
InternalName : ccApp
OriginalFilename : ccApp.exe
#:44 [ipodservice.exe]
FilePath : C:\Program Files\iPod\bin\
ProcessID : 3980
ThreadCreationTime : 1-1-2007 5:52:08 AM
FileDescription : iPodService Module
InternalName : iPodService
OriginalFilename : iPodService.exe
#:45 [msmsgs.exe]
FilePath : C:\Program Files\Messenger\
ProcessID : 3992
FileVersion : 4.7.3001
ProductVersion : Version 4.7.3001
ProductName : Messenger
FileDescription : Windows Messenger
InternalName : msmsgs
LegalCopyright : Copyright (c) Microsoft Corporation 2004
LegalTrademarks : Microsoft(R) is a registered trademark of Microsoft Corporation in the U.S. and/or other countries.
OriginalFilename : msmsgs.exe
#:46 [ctfmon.exe]
ProcessID : 4012
ThreadCreationTime : 1-1-2007 5:52:10 AM
FileDescription : CTF Loader
InternalName : CTFMON
OriginalFilename : CTFMON.EXE
#:47 [ypager.exe]
FilePath : C:\Program Files\Yahoo!\Messenger\
ProcessID : 4020
#:48 [hpqtra08.exe]
FilePath : C:\Program Files\HP\Digital Imaging\bin\
ProcessID : 560
ThreadCreationTime : 1-1-2007 5:52:12 AM
FileDescription : HP Digital Imaging Monitor
InternalName : HPQTRA00
OriginalFilename : HPQTRA00.EXE
Comments : HP Digital Imaging Monitor
#:49 [hphipm11.exe]
ProcessID : 1820
ThreadCreationTime : 1-1-2007 5:52:14 AM
FileVersion : 4, 5, 0, 770
ProductVersion : 4, 5, 0, 770
ProductName : HP PML
CompanyName : HP
FileDescription : PML Driver
InternalName : PmlDrv
LegalCopyright : Copyright © 1998, 1999 Hewlett-Packard Company
OriginalFilename : PmlDrv.exe
#:50 [hpoavn07.exe]
FilePath : C:\Program Files\Hewlett-Packard\AiO\hp officejet g series\Bin\
ProcessID : 2336
ThreadCreationTime : 1-1-2007 5:52:15 AM
FileVersion : 2.00
ProductVersion : A.14.06.09
ProductName : hp officejet g series
CompanyName : Hewlett-Packard Co.
FileDescription : HP OfficeJet COM Device Objects
InternalName : HPOAVN07
LegalCopyright : Copyright (C) Hewlett-Packard Co. 1995-2000
OriginalFilename : HPOAVN07.EXE
Comments : HP OfficeJet G Series COM Device Objects
#:51 [hpqimzone.exe]
ProcessID : 2360
#:52 [updates from hp.exe]
FilePath : C:\Program Files\Updates from HP\9972322\Program\
ProcessID : 2468
ThreadCreationTime : 1-1-2007 5:52:16 AM
#:53 [hpoevm07.exe]
FilePath : C:\PROGRA~1\HEWLET~1\AiO\Shared\Bin\
ProcessID : 2544
ThreadCreationTime : 1-1-2007 5:52:48 AM
FileVersion : 1.00
FileDescription : HP OfficeJet COM Event Manager
InternalName : HPOEVM07
OriginalFilename : HPOEVM07.EXE
Comments : HP OfficeJet COM Event Manager
#:54 [hpqnrs08.exe]
ProcessID : 2556
ThreadCreationTime : 1-1-2007 5:52:49 AM
FileDescription : HP Network Device Rediscovery Service
InternalName : HPQNRS00
OriginalFilename : HPQNRS00.EXE
Comments : HP Network Device Rediscovery Service
#:55 [hposts07.exe]
FilePath : C:\Program Files\Hewlett-Packard\AiO\Shared\bin\
ProcessID : 840
ThreadCreationTime : 1-1-2007 5:52:56 AM
FileVersion : 1.00
FileDescription : HP OfficeJet Status
InternalName : HPOSTS07
OriginalFilename : HPOCPY07.EXE
Comments : HP OfficeJet Status
#:56 [hpqste08.exe]
ProcessID : 2928
ThreadCreationTime : 1-1-2007 5:52:58 AM
FileDescription : HP CUE Status
InternalName : HPQSTS00
OriginalFilename : HPQSTS00.EXE
Comments : HP CUE Status
#:57 [hpofxm07.exe]
ProcessID : 2948
FileVersion : 1.00
FileDescription : HP OfficeJet G Series Fax Manager
InternalName : HPOFXM07
OriginalFilename : HPOFXM07.EXE
Comments : HP OfficeJet G Series Fax Manager
#:58 [kbd.exe]
FilePath : C:\HP\KBD\
ProcessID : 3700
ThreadCreationTime : 1-1-2007 5:54:16 AM
BasePriority : High
#:59 [soundman.exe]
ProcessID : 3008
ThreadCreationTime : 1-1-2007 5:54:28 AM
FileVersion : 1, 0, 0, 17
ProductVersion : 1, 0, 0, 17
ProductName : Realtek HD Sound Manager
CompanyName : Realtek Semiconductor Corp.
FileDescription : Realtek Sound Manager
InternalName : ALSMTray
LegalCopyright : Copyright (c) 2004 Realtek Semiconductor Corp.
OriginalFilename : ALSMTray.exe
Comments : Realtek HD Audio Sound Manager
#:60 [alcmtr.exe]
ProcessID : 2808
ThreadCreationTime : 1-1-2007 5:54:37 AM
FileVersion : 1.6.0.2
ProductVersion : 1.6.0.2
ProductName : Realtek AC97 Audio - Event Monitor
FileDescription : Realtek Azalia Audio - Event Monitor
InternalName : Alcxmntr
OriginalFilename : Alcxmntr.exe
#:61 [alcwzrd.exe]
ProcessID : 488
ThreadCreationTime : 1-1-2007 5:54:41 AM
FileVersion : 1.1.0.20
ProductVersion : 1.1.0.20
ProductName : ALCWZRD
CompanyName : RealTek Semicoductor Corp.
FileDescription : RealTek AlcWzrd Application
InternalName : ALCWZRD.EXE
LegalCopyright : Copyright (C) 2003-2004 Realtek Semiconductor Corp.
OriginalFilename : ALCWZRD.EXE
Comments : 2005/04/28
#:62 [hpsysdrv.exe]
FilePath : c:\windows\system\
ProcessID : 3716
ThreadCreationTime : 1-1-2007 5:55:21 AM
FileVersion : 1, 7, 0, 0
ProductVersion : 1, 7, 0, 0
ProductName : hpsysdrv
FileDescription : hpsysdrv
InternalName : hpsysdrv
OriginalFilename : hpsysdrv.exe
#:63 [ad-aware.exe]
FilePath : C:\PROGRA~1\Lavasoft\AD-AWA~1\
ProcessID : 4672
ThreadCreationTime : 1-1-2007 10:08:47 AM
FileVersion : 6.2.0.236
ProductVersion : SE 106
ProductName : Lavasoft Ad-Aware SE
CompanyName : Lavasoft Sweden
FileDescription : Ad-Aware SE Core application
InternalName : Ad-Aware.exe
LegalCopyright : Copyright © Lavasoft AB Sweden
OriginalFilename : Ad-Aware.exe
Comments : All Rights Reserved
#:64 [hh.exe]
ProcessID : 4732
FileVersion : 5.2.3790.2453 (srv03_sp1_gdr.050525-1542)
ProductVersion : 5.2.3790.2453
ProductName : HTML Help
FileDescription : Microsoft® HTML Help Executable
InternalName : HH 1.41
OriginalFilename : HH.exe
Memory scan result:
New critical objects: 0
Objects found so far: 0
Started registry scan
Adware.BHO(generic) Object Recognized!
Type : Regkey
Data :
TAC Rating : 3
Category : Adware
Comment :
Rootkey : HKEY_CLASSES_ROOT
Object : clsid\{35f7813a-af74-4474-b1dc-7ee6fb6c43c6}
SearchFast Object Recognized!
Type : Regkey
Data :
TAC Rating : 5
Category : Malware
Comment :
Object : clsid\{49232000-16e4-426c-a231-62846947304b}
Type : Regkey
Data :
TAC Rating : 5
Category : Malware
Comment :
Object : interface\{8da729b1-b0fc-4fab-9d33-0b004e0f0592}
Type : Regkey
Data :
TAC Rating : 5
Category : Malware
Comment :
Object : sysinfo.sysdata
Type : Regkey
Data :
TAC Rating : 5
Category : Malware
Comment :
Object : sysinfo.sysdata.1
Type : Regkey
Data :
TAC Rating : 5
Category : Malware
Comment :
Object : typelib\{980bcd41-0313-4693-88be-d036753fa898}
Registry Scan result:
New critical objects: 6
Objects found so far: 6
Started deep registry scan
Deep registry scan result:
Started Tracking Cookie scan
Tracking cookie scan result:
Deep scanning and examining files (C:)
Coulomb Dialer Object Recognized!
Type : File
Data : AtlBrowser.exe
TAC Rating : 5
Category : Dialer
Comment :
Object : C:\Program Files\Online Services\PeoplePC\Utilities\
FileVersion : 5, 5, 0, 6
ProductVersion : 5, 0, 0, 0
ProductName : AtlBrowser Module
CompanyName : PeoplePC
FileDescription : AtlBrowser Module
InternalName : ATLBROWSER
LegalCopyright : Copyright 2003
OriginalFilename : ATLBROWSER.DLL
Disk Scan Result for C:\
Objects found so far: 7
Deep scanning and examining files (D:)
Disk Scan Result for D:\
Scanning Hosts file......
Hosts file location:"C:\WINDOWS\system32\drivers\etc\hosts".
Hosts file scan result:
2 entries scanned.
New critical objects:0
Performing conditional scans...
Type : File
Data : SysInfo.dll
TAC Rating : 5
Category : Malware
Comment :
Object : C:\WINDOWS\downloaded program files\
FileVersion : 1, 0, 0, 4
ProductVersion : 1, 0, 0, 4
ProductName : SysInfo Module
CompanyName : Rapidigm Inc
FileDescription : SysInfo Module
InternalName : SysInfo
OriginalFilename : SysInfo.DLL
Type : File
Data : SysInfo.inf
TAC Rating : 5
Category : Malware
Comment :
Conditional scan result:
New critical objects: 2
Objects found so far: 9
2:40:35 AM Scan Complete
Summary Of This Scan
Total scanning time:00:31:33.579
Objects scanned:351882
Objects identified:9
Objects ignored:0
New critical objects:9
  • edited January 2007
    PART # 2 OF INITIAL POST:
    Spybot – Search & Destroy FIXED log files
    #1 FIXED
    --- Report generated: 2007-01-01 04:23 ---
    Smitfraud-C.Toolbar888: User settings (Registry key, fixed)
    HKEY_USERS\S-1-5-21-135222386-1693323512-2442114782-1008\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{B64F4A7C-97C9-11DA-8BDE-F66BAD1E3F3A}
    Smitfraud-C.Toolbar888: Settings (Registry key, fixed)
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Juan
    VirtuMonde: User settings (Registry key, fixed)
    HKEY_USERS\S-1-5-21-135222386-1693323512-2442114782-1008\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{F18F04B0-9CF1-4B93-B004-77A288BEE28B}
    WildTangent: Settings (Registry value, fixed)
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Java VM\ClassPath=...;C:\Program Files\WildTangent\Apps\DRM0302Java.jar...
    WildTangent: Program directory (Directory, fixed)
    C:\WINDOWS\wt\
    WildTangent: Class ID (Registry key, fixed)
    HKEY_CLASSES_ROOT\CLSID\{65E7DB1D-0101-4100-BD66-C5C78C917F93}
    WildTangent: Interface (Registry key, fixed)
    HKEY_CLASSES_ROOT\Interface\{1FAD572E-1A3D-44D9-9C23-A87F922DA8C0}
    HKEY_CLASSES_ROOT\Interface\{D8E9CCF6-8E64-4E39-95CE-C5333FCFBD1F}
    WildTangent: Type library (Registry key, fixed)
    HKEY_CLASSES_ROOT\TypeLib\{11066F62-0388-458C-B7E7-47E824894F20}
    HKEY_CLASSES_ROOT\TypeLib\{7946205B-FEF7-494F-A64B-3E992A780866}
    WildTangent: Root class (Registry key, fixed)
    HKEY_LOCAL_MACHINE\Software\Classes\Wtdmmpv.WTDMMPVersion
    HKEY_LOCAL_MACHINE\Software\Classes\Wtdmmpv.WTDMMPVersion.1
    HKEY_LOCAL_MACHINE\Software\Classes\CLSID\{65E7DB1D-0101-4100-BD66-C5C78C917F93}
    HKEY_CLASSES_ROOT\CLSID\{3A7FE611-1994-4ef1-A09F-99456752289D}
    HKEY_CLASSES_ROOT\Interface\{1DE680D4-84B7-4239-A887-9482A29DBE14}
    HKEY_CLASSES_ROOT\Interface\{25F53F41-0C37-40FA-AE9F-A260DB2D64CF}
    HKEY_CLASSES_ROOT\TypeLib\{4A165BD0-165F-474F-AF66-40CD5AC4613E}
    HKEY_LOCAL_MACHINE\Software\Classes\WildTangent.ActiveLauncher
    HKEY_LOCAL_MACHINE\Software\Classes\WildTangent.ActiveLauncher.2
    WildTangent: Class ID (Registry key, fixing failed)
    HKEY_LOCAL_MACHINE\Software\Classes\CLSID\{3A7FE611-1994-4ef1-A09F-99456752289D}
    HKEY_LOCAL_MACHINE\Software\Classes\WildTangent.ActiveLauncher.1
    WildTangent: Uninstall settings (Registry key, fixed)
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WildTangent CDA
    HKEY_LOCAL_MACHINE\Software\Classes\Logger.LogSession
    HKEY_LOCAL_MACHINE\Software\Classes\Logger.LogSession.1
    HKEY_LOCAL_MACHINE\Software\Classes\CLSID\{A62FA99E-922E-4ECA-A1D9-B54EF294A3CC}
    WildTangent: Library (File, fixed)
    C:\WINDOWS\wt\webdriver.dll
    C:\WINDOWS\wt\wtupdates\
    C:\WINDOWS\wt\updater\
    C:\WINDOWS\wt\webdriver\
    Microsoft.WindowsSecurityCenter_disabled: Settings (Registry change, fixed)
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\wscsvc\Start!=W=2
    Win32.Agent.At: Settings (Registry key, fixed)
    HKEY_USERS\S-1-5-21-135222386-1693323512-2442114782-1008\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{013A653B-49A6-4F76-8B68-E4875EA6BA54}
    Win32.Agent.At: Class ID (Registry key, fixed)
    HKEY_CLASSES_ROOT\CLSID\{013A653B-49A6-4f76-8B68-E4875EA6BA54}
    Avenue A, Inc.: Tracking cookie (Firefox: default) (Cookie, fixed)
    DoubleClick: Tracking cookie (Firefox: default) (Cookie, fixed)
    HitBox: Tracking cookie (Firefox: default) (Cookie, fixed)
    LinkSynergy: Tracking cookie (Firefox: default) (Cookie, fixed)
    --- Spybot - Search & Destroy version: 1.4 (build: 20050523) ---
    2005-05-31 blindman.exe (1.0.0.1)
    2005-05-31 SpybotSD.exe (1.4.0.3)
    2005-05-31 TeaTimer.exe (1.4.0.2)
    2007-01-01 unins000.exe (51.41.0.0)
    2005-05-31 Update.exe (1.4.0.0)
    2006-02-06 advcheck.dll (1.0.2.0)
    2005-05-31 aports.dll (2.1.0.0)
    2005-05-31 borlndmm.dll (7.0.4.453)
    2005-05-31 delphimm.dll (7.0.4.453)
    2005-05-31 SDHelper.dll (1.4.0.0)
    2006-02-20 Tools.dll (2.0.0.2)
    2005-05-31 UnzDll.dll (1.73.1.1)
    2005-05-31 ZipDll.dll (1.73.2.0)
    2006-12-29 Includes\Cookies.sbi (*)
    2006-12-08 Includes\Dialer.sbi (*)
    2006-12-29 Includes\DialerC.sbi (*)
    2006-11-24 Includes\Hijackers.sbi (*)
    2006-12-29 Includes\HijackersC.sbi (*)
    2006-10-27 Includes\Keyloggers.sbi (*)
    2006-12-29 Includes\KeyloggersC.sbi (*)
    2004-11-29 Includes\LSP.sbi (*)
    2006-12-22 Includes\Malware.sbi (*)
    2006-12-29 Includes\MalwareC.sbi (*)
    2006-10-20 Includes\PUPS.sbi (*)
    2006-12-29 Includes\PUPSC.sbi (*)
    2006-12-29 Includes\Revision.sbi (*)
    2006-12-08 Includes\Security.sbi (*)
    2006-12-29 Includes\SecurityC.sbi (*)
    2006-10-13 Includes\Spybots.sbi (*)
    2006-12-29 Includes\SpybotsC.sbi (*)
    2005-02-16 Includes\Tracks.uti
    2006-12-08 Includes\Trojans.sbi (*)
    2006-12-29 Includes\TrojansC.sbi (*)
    #2 FIXED:
    --- Report generated: 2007-01-01 04:39 ---
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Java VM\ClassPath=...;C:\WINDOWS\wt\webdriver\wtdmmpi.jar...
    Panda Active Scan
    Panda_ActiveScan_5-54-01_5-40AM_1-1-2007
    Incident Status Location
    Spyware:spyware/virtumonde Not disinfected Windows Registry
    Spyware:Cookie/Com.com Not disinfected C:\Documents and Settings\HP_Administrator\Application Data\Mozilla\Firefox\Profiles\c2xtu8wn.default\cookies.txt[.com.com/]
    Spyware:Cookie/Atlas DMT Not disinfected C:\Documents and Settings\HP_Administrator\Application Data\Mozilla\Firefox\Profiles\c2xtu8wn.default\cookies.txt[.atdmt.com/]
    Spyware:Cookie/Doubleclick Not disinfected C:\Documents and Settings\HP_Administrator\Application Data\Mozilla\Firefox\Profiles\c2xtu8wn.default\cookies.txt[.doubleclick.net/]
    Spyware:Cookie/QuestionMarket Not disinfected C:\Documents and Settings\HP_Administrator\Application Data\Mozilla\Firefox\Profiles\c2xtu8wn.default\cookies.txt[.questionmarket.com/]
    Spyware:Cookie/PointRoll Not disinfected C:\Documents and Settings\HP_Administrator\Application Data\Mozilla\Firefox\Profiles\c2xtu8wn.default\cookies.txt[.ads.pointroll.com/]
    Spyware:Cookie/myaffiliateprogram Not disinfected C:\Documents and Settings\HP_Administrator\Application Data\Mozilla\Firefox\Profiles\c2xtu8wn.default\cookies.txt[www.myaffiliateprogram.com/]
    Spyware:Cookie/Com.com Not disinfected C:\Documents and Settings\HP_Administrator\Cookies\hp_administrator@com[1].txt
    Virus:Trj/Mitglieder.FL Disinfected Archive_July2005 Folders\Deleted Items\[SUSPECT ATTACHMENT] \Business.zip[Text5546.exe]
    Potentially unwanted tool:Application/KillApp.B Not disinfected C:\hp\bin\KillIt.exe
    KASPERSKY ONLINE SCANNER REPORT
    Monday, January 01, 2007 1:03:17 PM
    Operating System: Microsoft Windows XP Professional, Service Pack 2 (Build 2600)
    Kaspersky Online Scanner version: 5.0.83.0
    Kaspersky Anti-Virus database last update: 1/01/2007
    Kaspersky Anti-Virus database records: 255424
    Scan Settings:
    Scan using the following antivirus database: extended
    Scan Archives: true
    Scan Mail Bases: true
    Scan Target - My Computer:
    C:\
    D:\
    E:\
    F:\
    G:\
    H:\
    I:\
    J:\
    K:\
    Scan Statistics:
    Total number of scanned objects: 221625
    Number of viruses found: 4
    Number of infected objects: 19 / 0
    Number of suspicious objects: 0
    Duration of the scan process: 01:36:47
    Infected Object Name / Virus Name / Last Action
    C:\Documents and Settings\All Users\Application Data\Microsoft\eHome\logs\ehRecvr.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\Common Client\settings.dat Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\LiveUpdate\2007-01-01_Log.ALUSchedulerSvc.LiveUpdate Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\BBConfig.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\BBDebug.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\BBDetect.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\BBNotify.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\BBRefr.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\BBSetCfg.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\BBSetCfg2.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\BBSetDev.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\BBSetLoc.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\BBSetUsr.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\BBStHash.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\BBValid.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\SPPolicy.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\SPStart.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SPBBC\SPStop.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SRTSP\SrtErEvt.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SRTSP\SrtETmp\73D48182.TMP Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SRTSP\SrtETmp\7A98E49A.TMP Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SRTSP\SrtMoEvt.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SRTSP\SrtNvEvt.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SRTSP\SrtScEvt.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SRTSP\SrtTxFEvt.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SRTSP\SrtViEvt.log Object is locked skipped
    C:\Documents and Settings\All Users\Application Data\Symantec\SubEng\submissions.idx Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Cookies\index.dat Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\ApplicationHistory\hpqimzone.exe.3204510e.ini.inuse Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\administrativeInfo.dbf Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\albumImagesTable.cdx Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\albumImagesTable.dbf Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\albumTable.cdx Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\albumTable.dbf Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\CB_Server_Errors.txt Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\EXIFTable.cdx Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\EXIFTable.dbf Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\imageTable.cdx Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\imageTable.dbf Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\imageTable.fpt Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\keywordImagesTable.cdx Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\keywordImagesTable.dbf Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\keywordTable.cdx Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\keywordTable.dbf Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\managedFolderTable.dbf Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\pathnameTable.cdx Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\pathnameTable.dbf Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\propertiesTable.cdx Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\propertiesTable.dbf Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\ROFImagesTable.cdx Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\ROFImagesTable.dbf Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\ROFTable.cdx Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\HP\Digital Imaging\db\ROFTable.dbf Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.LOG Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\History\History.IE5\index.dat Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\History\History.IE5\MSHist012007010120070102\index.dat Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Temp\hpodvd09.log Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Temp\Perflib_Perfdata_f5c.dat Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Temp\_hphtra07.log Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Temp\~DFCADB.tmp Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Temp\~DFCBD0.tmp Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Temp\~DFEE74.tmp Object is locked skipped
    C:\Documents and Settings\HP_Administrator\Local Settings\Temporary Internet Files\Content.IE5\index.dat Object is locked skipped
    C:\Documents and Settings\HP_Administrator\NTUSER.DAT Object is locked skipped
    C:\Documents and Settings\HP_Administrator\ntuser.dat.LOG Object is locked skipped
    C:\Documents and Settings\LocalService\Cookies\index.dat Object is locked skipped
    C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat Object is locked skipped
    C:\Documents and Settings\LocalService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.LOG Object is locked skipped
    C:\Documents and Settings\LocalService\Local Settings\History\History.IE5\index.dat Object is locked skipped
    C:\Documents and Settings\LocalService\Local Settings\Temp\Cookies\index.dat Object is locked skipped
    C:\Documents and Settings\LocalService\Local Settings\Temp\History\History.IE5\index.dat Object is locked skipped
    C:\Documents and Settings\LocalService\Local Settings\Temp\Temporary Internet Files\Content.IE5\index.dat Object is locked skipped
    C:\Documents and Settings\LocalService\Local Settings\Temporary Internet Files\Content.IE5\index.dat Object is locked skipped
    C:\Documents and Settings\LocalService\NTUSER.DAT Object is locked skipped
    C:\Documents and Settings\LocalService\ntuser.dat.LOG Object is locked skipped
    C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat Object is locked skipped
    C:\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Windows\UsrClass.dat.LOG Object is locked skipped
    C:\Documents and Settings\NetworkService\NTUSER.DAT Object is locked skipped
    C:\Documents and Settings\NetworkService\ntuser.dat.LOG Object is locked skipped
    C:\hp\bin\KillWind.exe Infected: not-a-virus:RiskTool.Win32.PsKill.p skipped
    C:\Program Files\ComcastToolbar\comcasttoolbar.dll_0_ Infected: not-a-virus:AdWare.Win32.BHO.al skipped
    C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcrst.dll Object is locked skipped
    C:\Program Files\Common Files\Symantec Shared\EENGINE\EPERSIST.DAT Object is locked skipped
    C:\Program Files\Common Files\Symantec Shared\NFWEVT.LOG Object is locked skipped
    C:\Program Files\Common Files\Symantec Shared\SNDALRT.log Object is locked skipped
    C:\Program Files\Common Files\Symantec Shared\SNDCON.log Object is locked skipped
    C:\Program Files\Common Files\Symantec Shared\SNDDBG.log Object is locked skipped
    C:\Program Files\Common Files\Symantec Shared\SNDFW.log Object is locked skipped
    C:\Program Files\Common Files\Symantec Shared\SNDIDS.log Object is locked skipped
    C:\Program Files\Common Files\Symantec Shared\SNDSYS.log Object is locked skipped
    C:\Program Files\Norton Internet Security\Norton AntiVirus\AVApp.log Object is locked skipped
    C:\Program Files\Norton Internet Security\Norton AntiVirus\AVError.log Object is locked skipped
    C:\Program Files\Norton Internet Security\Norton AntiVirus\AVVirus.log Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\chandir.dat Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\chandir.idx Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\chn.dat Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\chn.idx Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\D0000000.FCS Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\inuse.txt Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\L0000002.FCS Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\main.log Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\prs.dat Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\prs.idx Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\prs_die.dat Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\prs_die.idx Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\prs_dnd.dat Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\prs_dnd.idx Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\prs_ext.dat Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\prs_ext.idx Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\prs_rcv.dat Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\prs_rcv.idx Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\storydb.dat Object is locked skipped
    C:\Program Files\Updates from HP\9972322\Users\Default\Data\storydb.idx Object is locked skipped
    C:\Program Files\Yahoo!\Messenger\ypager.log Object is locked skipped
    C:\System Volume Information\MountPointManagerRemoteDatabase Object is locked skipped
    C:\VundoFix Backups\jkklm.dll.bad Infected: not-a-virus:AdWare.Win32.Virtumonde.fj skipped
    C:\WINDOWS\Debug\PASSWD.LOG Object is locked skipped
    C:\WINDOWS\pfirewall.log Object is locked skipped
    C:\WINDOWS\Registration\{02D4B3F1-FD88-11D1-960D-00805FC79235}.{55EA7C34-7164-484D-97B9-5024C2942946}.crmlog Object is locked skipped
    C:\WINDOWS\SchedLgU.Txt Object is locked skipped
    C:\WINDOWS\SoftwareDistribution\EventCache\{5B98A1CC-B41B-480A-A81E-3747667FFB2F}.bin Object is locked skipped
    C:\WINDOWS\SoftwareDistribution\ReportingEvents.log Object is locked skipped
    C:\WINDOWS\Sti_Trace.log Object is locked skipped
    C:\WINDOWS\system32\auvvkbnf.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\CatRoot2\edb.log Object is locked skipped
    C:\WINDOWS\system32\CatRoot2\tmp.edb Object is locked skipped
    C:\WINDOWS\system32\config\AppEvent.Evt Object is locked skipped
    C:\WINDOWS\system32\config\default Object is locked skipped
    C:\WINDOWS\system32\config\default.LOG Object is locked skipped
    C:\WINDOWS\system32\config\Internet.evt Object is locked skipped
    C:\WINDOWS\system32\config\Media Ce.evt Object is locked skipped
    C:\WINDOWS\system32\config\SAM Object is locked skipped
    C:\WINDOWS\system32\config\SAM.LOG Object is locked skipped
    C:\WINDOWS\system32\config\SecEvent.Evt Object is locked skipped
    C:\WINDOWS\system32\config\SECURITY Object is locked skipped
    C:\WINDOWS\system32\config\SECURITY.LOG Object is locked skipped
    C:\WINDOWS\system32\config\software Object is locked skipped
    C:\WINDOWS\system32\config\software.LOG Object is locked skipped
    C:\WINDOWS\system32\config\SysEvent.Evt Object is locked skipped
    C:\WINDOWS\system32\config\system Object is locked skipped
    C:\WINDOWS\system32\config\system.LOG Object is locked skipped
    C:\WINDOWS\system32\csihgvyc.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\cvmyrmtw.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\deaqvvfh.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\dpwvbruh.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\dqdnipuc.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\fxpuwhlf.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\gmfpdtvx.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\h323log.txt Object is locked skipped
    C:\WINDOWS\system32\igqmaebn.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\jyhlklml.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\lfiqlyka.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\qwhhldtw.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\uiaqgwbs.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\wbem\Repository\FS\INDEX.BTR Object is locked skipped
    C:\WINDOWS\system32\wbem\Repository\FS\INDEX.MAP Object is locked skipped
    C:\WINDOWS\system32\wbem\Repository\FS\MAPPING.VER Object is locked skipped
    C:\WINDOWS\system32\wbem\Repository\FS\MAPPING1.MAP Object is locked skipped
    C:\WINDOWS\system32\wbem\Repository\FS\MAPPING2.MAP Object is locked skipped
    C:\WINDOWS\system32\wbem\Repository\FS\OBJECTS.DATA Object is locked skipped
    C:\WINDOWS\system32\wbem\Repository\FS\OBJECTS.MAP Object is locked skipped
    C:\WINDOWS\system32\wwfuljom.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\yivaxosl.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\system32\ywsfoaio.dll Infected: Trojan-Spy.Win32.VBStat.j skipped
    C:\WINDOWS\wiadebug.log Object is locked skipped
    C:\WINDOWS\wiaservc.log Object is locked skipped
    C:\WINDOWS\WindowsUpdate.log Object is locked skipped
    Scan process completed.
    BitDefender Online Scanner - Real Time Virus Report
    Generated at: Mon, Jan 01, 2007 - 15:46:22
    Scan Info
    Scanned Files
    1104510
    Infected Files
    Virus Detected
    No virus found.
    THIS HIJACKTHIS LOG WAS CREATED AFTER RUNNING ALL THE ABOVE APPLICATIONS.
    Logfile of HijackThis v1.99.1
    Scan saved at 4:48:35 PM, on 1/1/2007
    MSIE: Internet Explorer v7.00 (7.00.5730.0011)
    Running processes:
    C:\WINDOWS\System32\smss.exe
    C:\WINDOWS\system32\lsass.exe
    C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
    C:\Program Files\Common Files\Symantec Shared\AppCore\AppSvc32.exe
    C:\WINDOWS\Explorer.EXE
    C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
    C:\WINDOWS\eHome\ehRecvr.exe
    C:\WINDOWS\eHome\ehSched.exe
    C:\Program Files\Common Files\LightScribe\LSSrvc.exe
    C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
    C:\WINDOWS\system32\dllhost.exe
    C:\WINDOWS\ehome\ehtray.exe
    C:\WINDOWS\system32\hkcmd.exe
    C:\WINDOWS\system32\igfxpers.exe
    C:\WINDOWS\sm56hlpr.exe
    C:\hp\drivers\hplsbwatcher\lsburnwatcher.exe
    C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
    C:\Program Files\Common Files\Real\Update_OB\realsched.exe
    C:\Program Files\Java\jre1.5.0_10\bin\jusched.exe
    C:\Program Files\Adobe\Photoshop Album Starter Edition\3.0\Apps\apdproxy.exe
    C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb07.exe
    C:\WINDOWS\system32\hphmon04.exe
    C:\PROGRA~1\Maxtor\OneTouch\Utils\OneTouch.exe
    C:\WINDOWS\MXOALDR.EXE
    C:\Program Files\iTunes\iTunesHelper.exe
    C:\Program Files\QuickTime\qttask.exe
    C:\Program Files\Common Files\Symantec Shared\ccApp.exe
    C:\WINDOWS\eHome\ehmsas.exe
    C:\Program Files\Messenger\msmsgs.exe
    C:\WINDOWS\system32\ctfmon.exe
    C:\Program Files\Yahoo!\Messenger\ypager.exe
    C:\Program Files\iPod\bin\iPodService.exe
    C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
    C:\Program Files\Hewlett-Packard\AiO\hp officejet g series\Bin\hpoavn07.exe
    C:\Program Files\Updates from HP\9972322\Program\Updates from HP.exe
    C:\Program Files\HP\Digital Imaging\bin\hpqimzone.exe
    C:\PROGRA~1\HEWLET~1\AiO\Shared\Bin\hpoevm07.exe
    C:\Program Files\Hewlett-Packard\AiO\Shared\bin\hpOSTS07.exe
    C:\Program Files\Hewlett-Packard\AiO\Shared\bin\hpOFXM07.exe
    C:\Program Files\HP\Digital Imaging\bin\hpqnrs08.exe
    C:\Program Files\HP\Digital Imaging\bin\hpqSTE08.exe
    C:\HP\KBD\KBD.EXE
    C:\WINDOWS\SOUNDMAN.EXE
    C:\WINDOWS\ALCMTR.EXE
    C:\WINDOWS\ALCWZRD.EXE
    c:\windows\system\hpsysdrv.exe
    C:\WINDOWS\system32\igfxsrvc.exe
    C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
    C:\WINDOWS\system32\HPZinw12.exe
    C:\WINDOWS\system32\HPHipm11.exe
    C:\WINDOWS\system32\HPZipm12.exe
    C:\Documents and Settings\HP_Administrator\Desktop\hijackthis\HijackThis.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=Q405&bd=pavilion&pf=desktop&parm1=seconduser
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q405&bd=pavilion&pf=desktop&parm1=seconduser
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://www.comcast.net/toolbar2.0/search/
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://red.clientapps.yahoo.com/customize/ycomp/defaults/sp/*http://www.yahoo.com
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iesearch&locale=EN_US&c=Q405&bd=pavilion&pf=desktop&parm1=seconduser
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://www.comcast.net/toolbar2.0/search/
    R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://red.clientapps.yahoo.com/customize/ycomp/defaults/su/*http://www.yahoo.com
    R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://ie.redirect.hp.com/svs/rdr?TYPE=3&tp=iehome&locale=EN_US&c=Q405&bd=pavilion&pf=desktop&parm1=seconduser
    O2 - BHO: Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
    O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
    O2 - BHO: (no name) - {1E8A6170-7264-4D0F-BEAE-D42A53123C75} - C:\Program Files\Common Files\Symantec Shared\coShared\Browser\1.0\NppBho.dll
    O2 - BHO: Comcast Toolbar - {4E7BD74F-2B8D-469E-93BE-BE2DF4D9AE29} - C:\PROGRA~1\COMCAS~1\COMCAS~2.DLL
    O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
    O2 - BHO: Yahoo! IE Services Button - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
    O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_10\bin\ssv.dll
    O2 - BHO: (no name) - {7DA39570-5FD2-4f18-94B4-20730CB3F727} - C:\WINDOWS\system32\oymmkkke.dll
    O2 - BHO: (no name) - {9991FFBE-7AF4-4DCC-B353-99E9C9345627} - C:\WINDOWS\system32\jkklm.dll (file missing)
    O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar2.dll
    O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\yt.dll
    O3 - Toolbar: Comcast Toolbar - {4E7BD74F-2B8D-469E-93BE-BE2DF4D9AE29} - C:\PROGRA~1\COMCAS~1\COMCAS~2.DLL
    O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar2.dll
    O3 - Toolbar: Show Norton Toolbar - {90222687-F593-4738-B738-FBEE9C7B26DF} - C:\Program Files\Common Files\Symantec Shared\coShared\Browser\1.0\UIBHO.dll
    O4 - HKLM\..\Run: [ehTray] C:\WINDOWS\ehome\ehtray.exe
    O4 - HKLM\..\Run: [High Definition Audio Property Page Shortcut] HDAShCut.exe
    O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\system32\hkcmd.exe
    O4 - HKLM\..\Run: [Persistence] C:\WINDOWS\system32\igfxpers.exe
    O4 - HKLM\..\Run: [HPHUPD08] c:\Program Files\HP\Digital Imaging\{33D6CC28-9F75-4d1b-A11D-98895B3A3729}\hphupd08.exe
    O4 - HKLM\..\Run: [HPBootOp] "C:\Program Files\Hewlett-Packard\HP Boot Optimizer\HPBootOp.exe" /run
    O4 - HKLM\..\Run: [SMSERIAL] sm56hlpr.exe
    O4 - HKLM\..\Run: [LSBWatcher] c:\hp\drivers\hplsbwatcher\lsburnwatcher.exe
    O4 - HKLM\..\Run: [HP Software Update] C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
    O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe" -osboot
    O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.5.0_10\bin\jusched.exe"
    O4 - HKLM\..\Run: [Adobe Photo Downloader] "C:\Program Files\Adobe\Photoshop Album Starter Edition\3.0\Apps\apdproxy.exe"
    O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb07.exe
    O4 - HKLM\..\Run: [HPHmon04] C:\WINDOWS\system32\hphmon04.exe
    O4 - HKLM\..\Run: [HPHUPD04] "C:\Program Files\HP Photosmart 11\hphinstall\UniPatch\hphupd04.exe"
    O4 - HKLM\..\Run: [MaxtorOneTouch] C:\PROGRA~1\Maxtor\OneTouch\Utils\OneTouch.exe
    O4 - HKLM\..\Run: [MXO Auto Loader] C:\WINDOWS\MXOALDR.EXE
    O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
    O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
    O4 - HKLM\..\Run: [osCheck] "C:\Program Files\Norton Internet Security\osCheck.exe"
    O4 - HKLM\..\Run: [DllRunning] rundll32.exe "C:\WINDOWS\system32\eitcucnk.dll",setvm
    O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
    O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
    O4 - HKCU\..\Run: [Yahoo! Pager] C:\Program Files\Yahoo!\Messenger\ypager.exe -quiet
    O4 - HKCU\..\Run: [DW4] "C:\Program Files\The Weather Channel FW\Desktop Weather\DesktopWeather.exe"
    O4 - Global Startup: Adobe Gamma Loader.lnk = ?
    O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
    O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
    O4 - Global Startup: HP Photosmart Premier Fast Start.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe
    O4 - Global Startup: HPAiODevice(hp officejet g series) - 1.lnk = C:\Program Files\Hewlett-Packard\AiO\hp officejet g series\Bin\hpoavn07.exe
    O4 - Global Startup: Updates from HP.lnk = C:\Program Files\Updates from HP\9972322\Program\Updates from HP.exe
    O8 - Extra context menu item: &Yahoo! Search - file:///C:\Program Files\Yahoo!\Common/ycsrch.htm
    O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MI1933~1\OFFICE11\EXCEL.EXE/3000
    O8 - Extra context menu item: Yahoo! &Dictionary - file:///C:\Program Files\Yahoo!\Common/ycdict.htm
    O8 - Extra context menu item: Yahoo! &Maps - file:///C:\Program Files\Yahoo!\Common/ycmap.htm
    O8 - Extra context menu item: Yahoo! &SMS - file:///C:\Program Files\Yahoo!\Common/ycsms.htm
    O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_10\bin\ssv.dll
    O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_10\bin\ssv.dll
    O9 - Extra button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
    O9 - Extra button: (no name) - {85d1f590-48f4-11d9-9669-0800200c9a66} - %windir%\bdoscandel.exe (file missing)
    O9 - Extra 'Tools' menuitem: Uninstall BitDefender Online Scanner v8 - {85d1f590-48f4-11d9-9669-0800200c9a66} - %windir%\bdoscandel.exe (file missing)
    O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MI1933~1\OFFICE11\REFIEBAR.DLL
    O9 - Extra button: Connection Help - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
    O9 - Extra 'Tools' menuitem: Connection Help - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
    O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
    O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - %windir%\Network Diagnostic\xpnetdiag.exe (file missing)
    O11 - Options group: [INTERNATIONAL] International*
    O16 - DPF: {01010E00-5E80-11D8-9E86-0007E96C65AE} (SupportSoft SmartIssue) - http://www.symantec.com/techsupp/asa/ctrl/tgctlsi.cab
    O16 - DPF: {01012101-5E80-11D8-9E86-0007E96C65AE} (SupportSoft Script Runner Class) - http://www.symantec.com/techsupp/asa/ctrl/tgctlsr.cab
    O16 - DPF: {0EB0E74A-2A76-4AB3-A7FB-9BD8C29F7F75} (CKAVWebScan Object) - http://www.kaspersky.com/kos/eng/partner/default/kavwebscan_unicode.cab
    O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
    O16 - DPF: {2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} (Symantec AntiVirus scanner) - http://security.symantec.com/sscv6/SharedContent/vc/bin/AvSniff.cab
    O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (YInstStarter Class) - C:\Program Files\Yahoo!\Common\yinsthelper.dll
    O16 - DPF: {49232000-16E4-426C-A231-62846947304B} - http://ipgweb.cce.hp.com/rdqcpc/downloads/sysinfo.cab
    O16 - DPF: {5D86DDB5-BDF9-441B-9E9E-D4730F4EE499} (BDSCANONLINE Control) - http://download.bitdefender.com/resources/scan8/oscan8.cab
    O16 - DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} (Windows Live Safety Center Base Module) - http://cdn.scan.safety.live.com/resource/download/scanner/wlscbase8460.cab
    O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) - http://security.symantec.com/sscv6/SharedContent/common/bin/cabsa.cab
    O16 - DPF: {6A344D34-5231-452A-8A57-D064AC9B7862} (Symantec Download Manager) - https://webdl.symantec.com/activex/symdlmgr.cab
    O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1140289090046
    O16 - DPF: {9A9307A0-7DA4-4DAF-B042-5009F29E09E1} (ActiveScan Installer Class) - http://acs.pandasoftware.com/activescan/as5free/asinst.cab
    O16 - DPF: {AB86CE53-AC9F-449F-9399-D8ABCA09EC09} (Get_ActiveX Control) - https://h17000.www1.hp.com/ewfrf-JAVA/Secure/HPGetDownloadManager.ocx
    O16 - DPF: {CE28D5D2-60CF-4C7D-9FE8-0F47A3308078} (ActiveDataInfo Class) - http://www.symantec.com/techsupp/asa/ctrl/SymAData.cab
    O16 - DPF: {E7D2588A-7FB5-47DC-8830-832605661009} (Live Collaboration) - https://livewc01.custhelp.com/7520-b289h-turbotax/rnl/java/RntX.cab
    O20 - Winlogon Notify: igfxcui - C:\WINDOWS\SYSTEM32\igfxdev.dll
    O20 - Winlogon Notify: WgaLogon - C:\WINDOWS\SYSTEM32\WgaLogon.dll
    O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll
    O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
    O23 - Service: Symantec Event Manager (ccEvtMgr) - Unknown owner - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe" /h ccCommon (file missing)
    O23 - Service: Symantec Settings Manager (ccSetMgr) - Unknown owner - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe" /h ccCommon (file missing)
    O23 - Service: Symantec Lic NetConnect service (CLTNetCnService) - Unknown owner - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe" /h ccCommon (file missing)
    O23 - Service: COM Host (comHost) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\VAScanner\comHost.exe
    O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
    O23 - Service: iPodService - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe
    O23 - Service: Symantec IS Password Validation (ISPwdSvc) - Symantec Corporation - C:\Program Files\Norton Internet Security\isPwdSvc.exe
    O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Common Files\LightScribe\LSSrvc.exe
    O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
    O23 - Service: Pml Driver HPH11 - HP - C:\WINDOWS\system32\HPHipm11.exe
    O23 - Service: Symantec Core LC - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
    O23 - Service: Symantec AppCore Service (SymAppCore) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\AppCore\AppSvc32.exe
    Thanks again for taking the time to look through and analyze all of these logs.
    RdRash
  • PterocarpousPterocarpous Rosie the Riveter Lives On in CA, USA! New
    edited January 2007
    Hello RdRash,
    These are the suspicious entries I found in your HJT. You have one suspicious BHO (browser helper object) and the remnants of another spyware BHO. You also have a registry RUN entry that I find suspicious.
    Suspicious BHO:
    This BHO remnant is related to a spyware variant of "Winfixer"
    Suspicious:
    (1) Download and install BHO Demon
    (2) Run BHO Demon and let us know how the "oymmkkke.dll" BHO is identified.
    We already know we need to get rid of the "jkklm.dll" BHO reference.
    (3) While still in NORMAL MODE, create a RESTORE POINT
    (4) Next, click on START
    (5) Click on RUN
    (6) Type in MSCONFIG in the OPEN field
    (7) Click on the STARTUP tab
    (8) Remove the check mark from the "eitcucnk.dll" entry
    (9) Click OK
    Your system will now reboot.
    (10) While the system is rebooting, hit the F8 key and choose SAFE MODE WITHOUT NETWORKING when the boot menu appears.
    (11) Run HJT again
    (12) Find the item(s) I listed above (the two BHO references)
    (13) Select both of them and choose FIX
    (Note: Don't select the BHO "oymmkkke.dll" if it has been determined to be a legitimate BHO by BHO Demon.)
    (14) Reboot your computer (into NORMAL MODE).
    (15) Run HJT again and post the log here.
    Thank you.
    Hi Pterocarpous,
    Awesome, Thanks for the quick reply
    I did as you said and BHODemon determined that BHO "oymmkkke.dll" was a Malware file associated with VirtuMonde/Vundo.
    I used BHODemon to disable it, then booted in Safe mode and had HJT remove it and the other two files you specified.
    Below is the HJT log after I re-booted in normal mode.
    Note that before I saw your reply I had launched IE and tried to go to Microsoft.com but got redirected to a different site, Heavy.com. Which indicated that Vundo was still infecting my system. Hopefully what you instructed me to remove were the final remnants of Vundo and any other virus. I will wait to hear back from you before launching IE again :-)
    Scan saved at 9:41:30 PM, on 1/1/2007
    Running processes:
    C:\Program Files\BHODemon 2\BHODemon.exe
    C:\HP\KBD\KBD.EXE
    O4 - Startup: BHODemon 2.0.lnk = C:\Program Files\BHODemon 2\BHODemon.exe
    Thanks
    RdRash
    edited January 2007
    RdRash wrote:
    Hi Pterocarpous, Awesome, Thanks for the quick reply
    You're certainly welcome.
    OK. Give me a few to analyze the log.
    RdRash wrote:
    ...I had launched IE...[and] got redirected to a different site, Heavy.com....Which indicated that Vundo was still infecting my system. Hopefully what you instructed me to remove were the final remnants of Vundo and any other virus. I will wait to hear back from you before launching IE again
    Right. Hopefully it was caused by that BHO. Lemmee take a look at your log and I'll get back to you.
    edited January 2007
    Your HijackThis (HJT) log looks pretty good now. Just two references to remove using HJT. After you do that, try your browser again.
    Broken reference - can be deleted:
    For the two above items in your HijackThis log... Please, run HJT again. Select these two items and choose FIX.
    Take no action on these in HijackThis:
    Have you uninstalled any of your Symantec products? There are (3) references to a missing Symantec shared file. Please, check your Symantec products to be sure they are working properly.:
    Hi Pterocarpous,
    I booted into Safe mode and used HJT to fix the two O9 broken references you called out.
    Looking at the log there are two other O9 items I listed below that have broken references their files are missing, should I do anything with these?
    I previously had Symantec Norton Internet Security 2005 installed that I messed up on and let the subscription and definition files expire on and then I got the viruses. After getting the viruses I upgraded to Symantec Norton Internet Security 2007 in an attempt to remove the viruses. NIS 2007 virus scan and its other functions seem to work (at least it doesn’t crash or doesn’t flag that it is missing some files), BUT NIS 2007 has not been able to detect and remove the Vundo virus.
    Could these O23 files be remnants of NIS 2005 or could they belong to my current version NIS 2007 that the viruses blocked from getting installed properly?
    I’m not quite sure how else to check to see if my NIS 2007 is working properly. Do you have any suggestions?
    I have not yet launch IE since performing these latest fixes.
    I just realized that I didn’t read your initial post correctly and didn’t follow steps 7 to 10 as you stated. I guess I was just tired and glazed over them and did what I had previously been doing when going into Safe boot mode.
    I did two things differently, when I went to MSCONFIG
    1) I went to the BOOT.INI tab and selected /SAFEBOOT WITH NETWORK, instead of using F8 and selecting WITHOUT NETWORKING (I previously had an issue in Safe mode of not getting the Start tool bar if I didn’t select networking.).
    2) I DID NOT go to the STARTUP tab and remove the check mark from “eitcucnk.dll” entry.
    Now after I used HJT to fix/remove “eitcucnk.dll”, when I look at my MSCONFIG STARTUP tab there is an item that has a check mark next to it but there is no name in the “Startup Item” column (it is blank) and the “Command” column is blank while the “Location” column contains “HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run”.
    Could this be a remnant of the “eitcucnk.dll” entry or something else?
    Should I uncheck this item?
    Scan saved at 1:51:31 AM, on 1/2/2007
    Running processes:
    Thanks again for all your help
    RdRash
  • TroganTrogan London, UK
    edited January 2007
    Hi RdRash!
    Those Norton services are not missing. HijackThis has a bug where it shows them as missing, when they are really not.
    Please do the following...
    Download Killbox and save it to your desktop.
    Copy everything in the Quote box below by pressing Ctrl+C
    Next, open Killbox
    Go to the File tab and select Paste from Clipboard
    Select the Delete on Reboot option
    Select All Files
    Now click on the Red Circle with the White X
    Press Yes to reboot your computer.
    Do the following, after the computer has rebooted.
    Open HijackThis
    - Click the Do a system scan only button
    - Check the following entries (below)
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://red.clientapps.yahoo.com/cust.../www.yahoo.com
    R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://red.clientapps.yahoo.com/cust.../www.yahoo.com
    - Close ALL open windows (especially Internet Explorer!)
    - Click Fix Checked
    Close HiajckThis
    I need to see another log from HijackThis.
    • Run Hijackthis.
    • Click on Open the Misc Tools section.
    • Next click on Open uninstall manager.
    • Press the Save list button.
    • Save the file to your desktop, with the default name of uninstall_list
    • Copy & Paste the entire contents of that file in your in your next post.
    Please post a new HijackThis log, along with the Uninstall list.
    edited January 2007
    Trogan wrote:
    Hi RdRash!...Those Norton services are not missing. HijackThis has a bug where it shows them as missing, when they are really not....Please do the following...
    Ahhhhh! My mistake. Good info., Trogan! Very nice instructions, too. (Copying them for my own reference... :smiles: )
    Hi
    Thanks for the new things to do.
    I used Killbox to delete the 16 .dlls and used HJT to remove the two R1 entries.
    Here is HJT uninstall managers list
    Ad-Aware SE Personal
    Adobe Flash Player 9 ActiveX
    Adobe Photoshop Elements 2.0
    Adobe Reader 7.0.8
    Adobe® Photoshop® Album Starter Edition 3.0
    AppCore
    AV
    Barnyard Invasion from HP Media Center (remove only)
    Bejeweled 2 Deluxe from HP Media Center (remove only)
    BHODemon 2.0.0.23
    Big Kahuna Reef from HP Media Center (remove only)
    Blackhawk Striker 2 from HP Media Center (remove only)
    Blasterball 2 from HP Media Center (remove only)
    Blasterball 2 Holidays from HP Media Center (remove only)
    Boggle Supreme from HP Media Center (remove only)
    Bookworm Deluxe from HP Media Center (remove only)
    Bounce Symphony from HP Media Center (remove only)
    ccCommon
    Comcast Toolbar
    Crystal Maze from HP Media Center (remove only)
    Desktop Weather by The Weather Channel
    Digby's Donuts from HP Media Center (remove only)
    Easy Internet Sign-up
    FATE Demo from HP Media Center (remove only)
    Flip Words from HP Media Center (remove only)
    GdiplusUpgrade
    GemMaster Mystic
    Google Toolbar for Internet Explorer
    High Definition Audio Driver Package - KB888111
    HijackThis 1.99.1
    Hotfix for Windows Media Format SDK (KB902344)
    Hotfix for Windows Media Player 10 (KB903157)
    Hotfix for Windows XP (KB888795)
    Hotfix for Windows XP (KB891593)
    Hotfix for Windows XP (KB895961)
    Hotfix for Windows XP (KB896344)
    Hotfix for Windows XP (KB899337)
    Hotfix for Windows XP (KB899510)
    Hotfix for Windows XP (KB902841)
    Hotfix for Windows XP (KB912024)
    Hotfix for Windows XP (KB914440)
    Hotfix for Windows XP (KB915865)
    Hotfix for Windows XP (KB926239)
    HP Boot Optimizer
    HP Deskjet Printer Preload
    HP DigitalMedia Archive
    HP Document Viewer 6.1
    HP Extended Capabilities 6.1
    HP Game Console and games
    HP Image Zone for Media Center PC
    HP Imaging Device Functions 6.1
    HP Multimedia Keyboard Software
    HP Photosmart 330,380,420,470,7800,8000,8200 Series
    HP Photosmart Cameras 5.0
    HP Photosmart Premier Software 6.1
    HP PSC & OfficeJet 5.3.B
    HP PSC & OfficeJet 6.1.A
    HP Software Update
    HP Solution Center and Imaging Support Tools 6.1
    HP Tunes
    Insaniquarium Deluxe from HP Media Center (remove only)
    Intel(R) Graphics Media Accelerator Driver
    IntelliMover Data Transfer Demo
    InterActual Player
    InterVideo WinDVD Player
    iTunes
    J2SE Runtime Environment 5.0
    J2SE Runtime Environment 5.0 Update 10
    J2SE Runtime Environment 5.0 Update 6
    Jewel Quest from HP Media Center (remove only)
    LiveUpdate 3.1 (Symantec Corporation)
    Mah Jong Quest from HP Media Center (remove only)
    Maxtor OneTouch
    Microsoft .NET Framework 1.0 Hotfix (KB887998)
    Microsoft .NET Framework 1.1
    Microsoft .NET Framework 1.1 Hotfix (KB886903)
    Microsoft .NET Framework 2.0
    Microsoft Base Smart Card Cryptographic Service Provider Package
    Microsoft Compression Client Pack 1.0 for Windows XP
    Microsoft Internationalized Domain Names Mitigation APIs
    Microsoft Money 2005
    Microsoft National Language Support Downlevel APIs
    Microsoft Office Professional Edition 2003
    Microsoft Plus! Dancer LE
    Microsoft Plus! Digital Media Edition Installer
    Microsoft Plus! Photo Story 2 LE
    Microsoft User-Mode Driver Framework Feature Pack 1.0
    Microsoft Works
    Motorola SM56 Speakerphone Modem
    Mozilla Firefox (2.0.0.1)
    MSN
    MSRedist
    MSXML 4.0 SP2 (KB925672)
    MSXML 4.0 SP2 (KB927978)
    muvee autoProducer 4.0
    muvee autoProducer unPlugged 1.1 - HPD
    Norton AntiVirus
    Norton Confidential Browser Component
    Norton Confidential Web Protection Component
    Norton Internet Security (Symantec Corporation)
    Norton Protection Center
    Otto
    Panda ActiveScan
    PC-Doctor 5 for Windows
    Photosmart 130,230,7150,7345,7350,7550 (Remove only)
    Polar Bowler from HP Media Center (remove only)
    Polar Golfer from HP Media Center (remove only)
    PS2
    Puzzle Express from HP Media Center (remove only)
    Python 2.2 pywin32 extensions (build 203)
    Python 2.2.3
    Quicken 2005
    Quicken WillMaker Plus 2005
    QuickTime
    RealPlayer
    Retrospect 6.0
    Ricochet Lost Worlds from HP Media Center (remove only)
    SCRABBLE Blast from HP Media Center (remove only)
    SCRABBLE from HP Media Center (remove only)
    SCRABBLE Rack Attack from HP Media Center (remove only)
    Security Update for Microsoft .NET Framework 2.0 (KB917283)
    Security Update for Microsoft .NET Framework 2.0 (KB922770)
    Security Update for Step By Step Interactive Training (KB898458)
    Security Update for Windows Media Player 10 (KB911565)
    Security Update for Windows Media Player 10 (KB917734)
    Security Update for Windows Media Player 6.4 (KB925398)
    Security Update for Windows XP (KB883939)
    Security Update for Windows XP (KB890046)
    Security Update for Windows XP (KB893756)
    Security Update for Windows XP (KB896358)
    Security Update for Windows XP (KB896422)
    Security Update for Windows XP (KB896423)
    Security Update for Windows XP (KB896424)
    Security Update for Windows XP (KB896428)
    Security Update for Windows XP (KB899587)
    Security Update for Windows XP (KB899589)
    Security Update for Windows XP (KB899591)
    Security Update for Windows XP (KB900725)
    Security Update for Windows XP (KB901017)
    Security Update for Windows XP (KB901214)
    Security Update for Windows XP (KB902400)
    Security Update for Windows XP (KB904706)
    Security Update for Windows XP (KB905414)
    Security Update for Windows XP (KB905749)
    Security Update for Windows XP (KB905915)
    Security Update for Windows XP (KB908519)
    Security Update for Windows XP (KB911280)
    Security Update for Windows XP (KB911562)
    Security Update for Windows XP (KB911567)
    Security Update for Windows XP (KB911927)
    Security Update for Windows XP (KB912812)
    Security Update for Windows XP (KB912919)
    Security Update for Windows XP (KB913446)
    Security Update for Windows XP (KB913580)
    Security Update for Windows XP (KB914388)
    Security Update for Windows XP (KB914389)
    Security Update for Windows XP (KB916281)
    Security Update for Windows XP (KB917159)
    Security Update for Windows XP (KB917344)
    Security Update for Windows XP (KB917422)
    Security Update for Windows XP (KB917953)
    Security Update for Windows XP (KB918439)
    Security Update for Windows XP (KB918899)
    Security Update for Windows XP (KB919007)
    Security Update for Windows XP (KB920213)
    Security Update for Windows XP (KB920214)
    Security Update for Windows XP (KB920670)
    Security Update for Windows XP (KB920683)
    Security Update for Windows XP (KB920685)
    Security Update for Windows XP (KB921398)
    Security Update for Windows XP (KB921883)
    Security Update for Windows XP (KB922616)
    Security Update for Windows XP (KB922760)
    Security Update for Windows XP (KB922819)
    Security Update for Windows XP (KB923191)
    Security Update for Windows XP (KB923414)
    Security Update for Windows XP (KB923694)
    Security Update for Windows XP (KB923980)
    Security Update for Windows XP (KB924191)
    Security Update for Windows XP (KB924270)
    Security Update for Windows XP (KB924496)
    Security Update for Windows XP (KB925486)
    Security Update for Windows XP (KB926255)
    Shrek 2 Ogre Bowler from HP Media Center (remove only)
    Slingo Deluxe from HP Media Center (remove only)
    Slyder from HP Media Center (remove only)
    Sonic Encoders
    Sonic Express Labeler
    Sonic MyDVD Plus
    Sonic RecordNow Audio
    Sonic RecordNow Copy
    Sonic RecordNow Data
    Sonic Update Manager
    SPBBC 32bit
    Spelling Dictionaries For Adobe Reader Package
    Spybot - Search & Destroy 1.4
    SpywareBlaster v3.5.1
    Super Granny from HP Media Center (remove only)
    SureThing CD Labeler SE - Sonic
    Swarm from HP Media Center (remove only)
    SymNet
    Tradewinds from HP Media Center (remove only)
    TurboTax ItsDeductible 2005
    TurboTax Premier 2005
    Update for Windows Media Player 10 (KB910393)
    Update for Windows Media Player 10 (KB913800)
    Update for Windows XP (KB894391)
    Update for Windows XP (KB898461)
    Update for Windows XP (KB900485)
    Update for Windows XP (KB900930)
    Update for Windows XP (KB904942)
    Update for Windows XP (KB908531)
    Update for Windows XP (KB910437)
    Update for Windows XP (KB912945)
    Update for Windows XP (KB916595)
    Update for Windows XP (KB920342)
    Update for Windows XP (KB920872)
    Update for Windows XP (KB922582)
    Update for Windows XP (KB925876)
    Update Rollup 2 for Windows XP Media Center Edition 2005
    Updates from HP (remove only)
    USB Storage Adapter FX (MXO)
    Viewpoint Media Player
    Weather Services
    WexTech AnswerWorks
    Windows Genuine Advantage v1.3.0254.0
    Windows Installer 3.1 (KB893803)
    Windows Internet Explorer 7
    Windows Live OneCare safety scanner
    Windows Media Connect
    Windows Media Format 11 runtime
    Windows Media Player 10 Hotfix [See KB889858 for more information]
    Windows Media Player 11
    Windows Rights Management Client Backwards Compatibility SP2
    Windows Rights Management Client with Service Pack 2
    Windows XP Hotfix - KB873339
    Windows XP Hotfix - KB883667
    Windows XP Hotfix - KB885250
    Windows XP Hotfix - KB885354
    Windows XP Hotfix - KB885835
    Windows XP Hotfix - KB885836
    Windows XP Hotfix - KB886185
    Windows XP Hotfix - KB887472
    Windows XP Hotfix - KB887742
    Windows XP Hotfix - KB887797
    Windows XP Hotfix - KB888113
    Windows XP Hotfix - KB888302
    Windows XP Hotfix - KB890175
    Windows XP Hotfix - KB890859
    Windows XP Hotfix - KB891220
    Windows XP Hotfix - KB891781
    Windows XP Hotfix - KB893066
    Windows XP Media Center Edition 2005 KB888316
    Windows XP Media Center Edition 2005 KB895678
    Windows XP Media Center Edition 2005 KB925766
    Yahoo! Anti-Spy
    Yahoo! extras
    Yahoo! Install Manager
    Yahoo! Internet Mail
    Yahoo! Messenger
    Yahoo! Toolbar
    And another HJT log in normal boot mode:
    Scan saved at 8:57:55 PM, on 1/2/2007
    Running processes:
    C:\HP\KBD\KBD.EXE
    C:\Program Files\Mozilla Firefox\firefox.exe
    Thanks
    RdRash
    edited January 2007
    Hi again RdRash!
    Click Start > Run > type in appwiz.cpl and hit enter. From the list uninstall the following, if present:
    __________________________________
    Download ATF (Atribune Temp File) Cleaner© by Atribune to your desktop.
    This program is for XP and Windows 2000 only!
    Double-click ATF Cleaner.exe to open it.
    Under Main select the following:
      [*]Windows Temp
      [*]Current User Temp
      [*]All Users Temp
      [*]Temporary Internet Files
      [*]Prefetch
      [*]Java Cache
      *The other boxes are optional*
      Then click the Empty Selected button.
      If you use Firefox:
      • Click Firefox at the top and choose: Select All
      • Click the Empty Selected button.
      • NOTE: If you would like to keep your saved passwords, please click NO at the prompt.
      Click Exit on the Main menu to close the program.
      You may wish to Print or Save the following instructions, as the internet will not be available once in Safe Mode!
      Please download AVG Anti-Spyware to your Desktop or to your usual Download Folder.
      http://www.ewido.net/en/download/
      • Install AVG Anti-Spyware by double clicking the installer.
      • Follow the prompts. Make sure that Launch AVG Anti-Spyware is checked.
      • On the main screen under Your Computer's security.
        • Click on Change state next to Resident shield. It should now change to inactive.
        • Click on Change state next to Automatic updates. It should now change to inactive.
        • Next to Last Update, click on Update now. (You will need an active internet connection to perform this)
        • Wait until you see the Update succesfull message.
      • Right-click the AVG Anti-Spyware Tray Icon and uncheck Start with Windows.
      • Right-click the AVG Anti-Spyware Tray Icon and select Exit. Confirm by clicking Yes.
      If you are having problems with the updater, you can use this link to manually update ewido.
      AVG Anti-Spyware manual updates.
      Download the Full database to your Desktop or to your usual Download Folder and install it by double clicking the file. Make sure that AVG Anti-Spyware is closed before installing the update.
      Reboot your computer in Safe Mode.
      • If the computer is running, shut down Windows, and then turn off the power.
      • Wait 30 seconds, and then turn the computer on.
      • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
      • Ensure that the Safe Mode option is selected.
      • Press Enter. The computer then begins to start in Safe mode.
      • Login on your usual account.
      Once in Safe Mode:
      Close ALL open Windows / Programs / Folders. Please start AVG Anti-Spyware and run a full scan.
      • Click on Scanner on the toolbar.
      • Click on the Settings tab.
        • Under How to act?
          • Click on Recommended Action and choose Quarantine from the popup menu.
        • Under How to scan?
          • All checkboxes should be ticked.
        • Under Possibly unwanted software:
        • Under Reports:
          • Select Automatically generate report after every scan and uncheck Only if threats were found.
        • Under What to scan?
          • Select Scan every file.
      • Click on the Scan tab.
      • Click on Complete System Scan to start the scan process.
      • Let the program scan the machine.
      • When the scan has finished, follow the instructions below.
        IMPORTANT : Don't click on the "Save Scan Report" button before you did hit the "Apply all Actions" button.
        • Make sure that Set all elements to: shows Quarantine (1), if not click on the link and choose Quarantine from the popup menu. (2)
        • At the bottom of the window click on the Apply all Actions button. (3)
      • When done, click the Save Scan Report button. (4)
        • Click the Save Report as button.
        • Save the report to your Desktop.
      Reboot back into Normal Mode, and post a new HJT log, along with the AVG Anti-Spyware log.
      Hi Trogan
      Thanks again for the info. I have a question
      I Uninstalled
      I also have J2SE Runtime Environment 6 Installed but I left that in place since you didn’t instruct me to remove it. Should leave it installed or remove it also?
      In the mean time I have left it installed and am in the process of following the remainder of your instructions.
      If you want me to uninstall it also, I assume once I do then I should repeat the above instructions again, correct?
      Thanks
      Will
      edited January 2007
      Hi Will,
      J2SE Runtime Environment 6 is the latest version of Java and is the reason why I did not get you to uninstall it. The other two are older versions, which serve no purpose now.
      You've done everything correctly, so you can carry on with ATF Cleaner and AVG anti-spyware.
    • edited January 2007
      Hi Trogan
      Thanks for the quick reply.
      ARRHH
      I hate it when I can't type correctly, especially when I thought I caught and corrected my error.
      What I was supposed to type was I also have JSE Runtime Environment 5.0 Update 6 Installed. Should I remove the 5.0 Update 6?
      I don't see JSE Runtime Environment 6 installed though.
      Thanks
      RdRash
      edited January 2007
      I apologise, too. I completely misread J2SE Runtime Environment 5.0 Update 6 for JSE Runtime Environment 6, which is the latest version.
      OK, so you also need to remove J2SE Runtime Environment 5.0 Update 6. Once all the Java components have been removed, reboot your computer. Then follow these instructions:
      • Download the latest version of Java Runtime Environment (JRE) 6 .
      • Click the "Download" button to the right.
      • Check the box that says: "Accept License Agreement."
      • The page will refresh.
      • Click on the link to download Windows Offline Installation with or without Multi-language and save to your desktop.
      • Close any programs you may have running - especially your web browser.
      • Then from your desktop double-click on jre-6-windows-i586.exe to install the newest version.
      Continue with the rest of the instructions.
      I apologise again for any confusion.
      Hi Trogan
      No problem. It looks like we both need to rub our eyes a little, that 6 moved its way over to the left on both of us :-)
      I will send a new post once I finish following your instructions
      Thanks
      RdRash
      Hi Trogan
      I'm back from work, now ready to work :-0
      OK JRE 5 and Updates uninstalled
      JRE 6 installed
      Ran AVG and Quarantined the one item
      HJT log in normal mode
      Scan saved at 10:10:53 PM, on 1/3/2007
      Running processes:
      C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
      C:\Program Files\Java\jre1.6.0\bin\jusched.exe
      C:\HP\KBD\KBD.EXE
      O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0\bin\ssv.dll
      O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0\bin\jusched.exe"
      O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\npjpi160.dll
      O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\npjpi160.dll
      O23 - Service: AVG Anti-Spyware Guard - Anti-Malware Development a.s. - C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
      AVG log
      AVG Anti-Spyware - Scan Report
      + Created at: 10:03:38 PM 1/3/2007
      + Scan result:
      C:\Program Files\ComcastToolbar\comcasttoolbar.dll_0_ -> Adware.BHO : Cleaned with backup (quarantined).
      ::Report end
      Thanks
      RdRash
      edited January 2007
      Hi RdRash! :)
      Log is clean. How is the computer?
      Hi Trogan
      I have been holding off on using IE until I got the all clear from you just to make sure I didn't re-infect myself. :-)
      I have been using IE for about an hour and it looks pretty good so far. Let me use it through out the day to see how it goes and then I will let you know if it is all good or not.
      Immense thanks for helping me clean it up. I couldn't have done it without your help.
      Question for you: Do you have a preference in using Windows Firewall versus Norton Internet Security's Firewall? I currently have Windows Firewall turned on and Norton's turned off.
      Also I still have second issue I originally mentioned but I knew we wanted to leave this till the end after we cleaned up all the viruses. I am not sure if this is the correct forum for it or not since now it doesn't appear to be a virus related issue since my system looks to be clean.
      The second issue is:
      With my PC connected to the internet and running in normal boot mode I get the following pop up window occurring rather frequently with the following message:
      “Server Busy
      This action cannot be completed because the other program is busy. Choose ‘Switch To’ to activate the busy program and correct the problem.”
      When I click the ‘Switch To’ button on the popup window it activates the “Start” button on the toolbar. But I don’t know what server or program it is looking for me to take action on. After doing this the message window will disappear for a while then come back again later. Some times in a very short time period, other times after a long time period. The longer my PC is running the longer the time period is between when the message window pops up. This message window does not appear to occur when the PC is running in safe boot mode or if the network cable is unplugged.
      Do you know what is causing this error message window?
      Is it due to a virus or something else?
      How can I fix the issue?
      How can I determine which application is causing this "Server Busy" issue which is causing the message window to pop up?
      If this isn't the correct forum for this issue can you suggest a forum that I might try to see if they can help me resolve it?
      Thanks immensely
      RdRash
      edited January 2007
      Hi RdRash!
      I'm not sure what would be causing that error. Could you grab a screenshot when it next happens?
      Lets run another tool...
      1. Download this file - combofix.exe
      2. Double click combofix.exe & follow the prompts.
      3. When finished, it shall produce a log for you. Post that log in your next reply
      Note:
      Do not mouseclick combofix's window whilst it's running. That may cause it to stall
      Hi Trogan
      When it comes up next I will get a screen shot and send. It looks to be a standard Windows messaging box with the verbage I described.
      Here is the log from combofix.exe
      HP_Administrator - 07-01-04 8:54:55.01 Service Pack 2
      ComboFix 06.11.27 - Running from: "C:\Documents and Settings\HP_Administrator\Desktop"
      ((((((((((((((((((((((((((((((( Files Created from 2006-12-04 to 2007-01-04 ))))))))))))))))))))))))))))))))))
      2007-01-03 07:55 3,968 --a
      C:\WINDOWS\system32\drivers\AvgAsCln.sys
      2007-01-03 07:55 <DIR> d
      2007-01-03 07:29 <DIR> d
      C:\Program Files\Common Files\Java
      2007-01-02 20:30 <DIR> d
      C:\!KillBox
      2007-01-01 20:38 <DIR> d
      2007-01-01 13:18 <DIR> d
      C:\WINDOWS\BDOSCAN8
      2007-01-01 10:13 <DIR> d
      C:\WINDOWS\system32\Kaspersky Lab
      2007-01-01 05:04 <DIR> d
      C:\WINDOWS\system32\ActiveScan
      2007-01-01 04:53 <DIR> d
      C:\Program Files\SpywareBlaster
      2007-01-01 03:29 <DIR> d
      C:\Program Files\Spybot - Search & Destroy
      C:\Documents and Settings\All Users\Application Data\Spybot - Search & Destroy
      2007-01-01 02:08 <DIR> d
      C:\Program Files\Lavasoft
      C:\Documents and Settings\HP_Administrator\Application Data\Lavasoft
      2006-12-31 20:29 <DIR> d
      C:\VundoFix Backups
      2006-12-19 17:09 276,792 --a
      C:\WINDOWS\system32\drivers\srtspl.sys
      2006-12-19 17:09 25,400 --a
      C:\WINDOWS\system32\drivers\srtspx.sys
      2006-12-19 17:09 247,096 --a
      C:\WINDOWS\system32\drivers\srtsp.sys
      2006-12-14 12:15 118,804 --a
      2006-12-05 06:44 <DIR> d
      C:\Documents and Settings\HP_Administrator\Application Data\Mozilla
      2006-12-04 22:25 <DIR> d--hs---- C:\WINDOWS\CSC
      2006-12-04 20:38 <DIR> d
      C:\WINDOWS\system32\LogFiles
      C:\WINDOWS\system32\drivers\UMDF
      2006-12-04 20:36 <DIR> d
      C:\WINDOWS\system32\DRM
      2006-12-04 20:32 36,352
      C:\WINDOWS\system32\tsgqec.dll
      2006-12-04 20:32 288,768
      C:\WINDOWS\system32\rhttpaa.dll
      2006-12-04 20:32 116,736
      C:\WINDOWS\system32\aaclient.dll
      2006-12-04 01:26 <DIR> d
      C:\WINDOWS\pss
      2006-12-04 00:52 <DIR> d
      (((((((((((((((((((((((((((((((((((((((((((((((( Find3M Report )))))))))))))))))))))))))))))))))))))))))))))))))))))
      2007-01-04 08:52
      d
      2007-01-03 07:29
      d
      2007-01-03 07:29
      d
      2007-01-02 20:23
      d---s---- C:\Documents and Settings\HP_Administrator\Application Data\Microsoft
      2007-01-01 20:08
      d
      C:\Program Files\Windows Live Safety Center
      2007-01-01 06:28
      d
      C:\Program Files\Windows Media Player
      2007-01-01 06:25
      d
      2007-01-01 06:20
      d
      2007-01-01 06:19
      d
      2007-01-01 06:18
      d
      C:\Program Files\Internet Explorer
      2007-01-01 06:14
      d
      C:\Program Files\Google
      2007-01-01 06:12
      d-a
      2007-01-01 06:12
      d
      2006-12-31 21:43 48776 --a
      C:\WINDOWS\system32\S32EVNT1.DLL
      2006-12-31 21:43 115000 --a
      C:\WINDOWS\system32\drivers\SYMEVENT.SYS
      2006-12-31 21:43
      d
      2006-12-17 16:22
      d
      C:\Program Files\VSAdd-in
      2006-12-14 06:49
      d
      C:\Program Files\Outlook Express
      2006-12-14 06:49
      d
      C:\Program Files\Common Files\System
      2006-12-04 20:42
      d
      C:\Program Files\Windows Media Connect 2
      2006-11-20 21:32
      d
      2006-11-12 22:02 1866240 --a
      C:\WINDOWS\system32\mstscax.dll
      2006-11-07 21:06 679424 --a
      C:\WINDOWS\system32\inetcomm.dll
      2006-11-07 21:03 6049280
      C:\WINDOWS\system32\ieframe.dll
      2006-11-07 21:03 50688
      C:\WINDOWS\system32\msfeedsbs.dll
      2006-11-07 21:03 458752
      C:\WINDOWS\system32\msfeeds.dll
      2006-11-07 21:03 413696 --a
      C:\WINDOWS\system32\vbscript.dll
      2006-11-07 21:03 231424 --a
      C:\WINDOWS\system32\webcheck.dll
      2006-11-07 21:03 180736
      C:\WINDOWS\system32\ieui.dll
      2006-11-07 21:03 156160 --a
      C:\WINDOWS\system32\msls31.dll
      2006-11-07 03:27 382976 --a
      C:\WINDOWS\system32\iedkcs32.dll
      2006-11-07 03:27 229376 --a
      C:\WINDOWS\system32\ieaksie.dll
      2006-11-07 03:26 71680 --a
      C:\WINDOWS\system32\admparse.dll
      2006-11-07 03:26 55296 --a
      C:\WINDOWS\system32\iesetup.dll
      2006-11-07 03:26 54784 --a
      C:\WINDOWS\system32\ie4uinit.exe
      2006-11-07 03:26 43008 --a
      C:\WINDOWS\system32\iernonce.dll
      2006-11-07 03:26 152064 --a
      C:\WINDOWS\system32\ieakeng.dll
      2006-11-07 03:26 13312 --a
      C:\WINDOWS\system32\ieudinit.exe
      2006-11-07 03:26 123904 --a
      C:\WINDOWS\system32\advpack.dll
      2006-11-07 03:25 161792 --a
      C:\WINDOWS\system32\ieakui.dll
      2006-11-07 00:06 600576 --a
      C:\WINDOWS\system32\mstsc.exe
      2006-11-06 11:35 531568 --a
      C:\WINDOWS\system32\RmActivate_isv.exe
      2006-11-06 11:35 523376 --a
      C:\WINDOWS\system32\RmActivate.exe
      2006-11-06 11:35 519280 --a
      C:\WINDOWS\system32\SecProc_isv.dll
      2006-11-06 11:35 518768 --a
      C:\WINDOWS\system32\SecProc.dll
      2006-11-06 11:35 358000 --a
      C:\WINDOWS\system32\RmActivate_ssp.exe
      2006-11-06 11:35 354416 --a
      C:\WINDOWS\system32\RmActivate_ssp_isv.exe
      2006-11-06 11:35 323696 --a
      C:\WINDOWS\system32\msdrm.dll
      2006-11-06 11:35 192624 --a
      C:\WINDOWS\system32\SecProc_ssp_isv.dll
      C:\WINDOWS\system32\SecProc_ssp.dll
      2006-11-04 14:14 1245696 --a
      C:\WINDOWS\system32\msxml4.dll
      2006-10-19 05:56 713216 --a
      C:\WINDOWS\system32\sxs.dll
      2006-10-18 21:58 8704 --a
      C:\WINDOWS\system32\wdfmgr.exe
      C:\WINDOWS\system32\uwdf.exe
      2006-10-18 21:47 99840 --a
      C:\WINDOWS\system32\wmpshell.dll
      2006-10-18 21:47 937984 --a
      C:\WINDOWS\system32\WMNetMgr.dll
      2006-10-18 21:47 8231936 --a
      C:\WINDOWS\system32\wmploc.dll
      2006-10-18 21:47 767488
      C:\WINDOWS\system32\WMVSENCD.dll
      2006-10-18 21:47 757248 --a
      C:\WINDOWS\system32\WMADMOD.dll
      2006-10-18 21:47 7168 --a
      C:\WINDOWS\system32\asferror.dll
      2006-10-18 21:47 656896
      C:\WINDOWS\system32\WMVXENCD.dll
      2006-10-18 21:47 63488 --a
      C:\WINDOWS\system32\wpdmtpus.dll
      2006-10-18 21:47 629760 --a
      C:\WINDOWS\system32\wpd_ci.dll
      2006-10-18 21:47 613376
      C:\WINDOWS\system32\wmpmde.dll
      2006-10-18 21:47 603648 --a
      C:\WINDOWS\system32\WMSPDMOD.dll
      2006-10-18 21:47 542720 --a
      C:\WINDOWS\system32\blackbox.dll
      2006-10-18 21:47 535040 --a
      C:\WINDOWS\system32\wmdrmsdk.dll
      2006-10-18 21:47 429056 --a
      C:\WINDOWS\system32\wmdrmdev.dll
      2006-10-18 21:47 414208 --a
      C:\WINDOWS\system32\msscp.dll
      2006-10-18 21:47 4096 --a
      C:\WINDOWS\system32\wmvdmoe2.dll
      C:\WINDOWS\system32\wmvdmod.dll
      C:\WINDOWS\system32\WMVADVE.DLL
      C:\WINDOWS\system32\WMVADVD.dll
      C:\WINDOWS\system32\wmsdmoe2.dll
      C:\WINDOWS\system32\wmsdmod.dll
      C:\WINDOWS\system32\wdfapi.dll
      C:\WINDOWS\system32\MPG4DMOD.dll
      C:\WINDOWS\system32\MP4SDMOD.dll
      C:\WINDOWS\system32\MP43DMOD.dll
      2006-10-18 21:47 38400
      C:\WINDOWS\system32\wpdshextres.dll
      2006-10-18 21:47 37376 --a
      C:\WINDOWS\system32\wmdmps.dll
      2006-10-18 21:47 35840 --a
      C:\WINDOWS\system32\wpdconns.dll
      2006-10-18 21:47 356352 --a
      C:\WINDOWS\system32\wpdsp.dll
      2006-10-18 21:47 348672 --a
      C:\WINDOWS\system32\wmdrmnet.dll
      2006-10-18 21:47 33792 --a
      C:\WINDOWS\system32\wmdmlog.dll
      2006-10-18 21:47 321536 --a
      C:\WINDOWS\system32\mswmdm.dll
      2006-10-18 21:47 317440
      C:\WINDOWS\system32\MP4SDECD.dll
      2006-10-18 21:47 314880 --a
      C:\WINDOWS\system32\wmpdxm.dll
      2006-10-18 21:47 295936
      C:\WINDOWS\system32\wmpeffects.dll
      2006-10-18 21:47 284160
      C:\WINDOWS\system32\PortableDeviceApi.dll
      2006-10-18 21:47 276992 --a
      C:\WINDOWS\system32\audiodev.dll
      2006-10-18 21:47 27136 --a
      C:\WINDOWS\system32\mspmsnsv.dll
      2006-10-18 21:47 2603008
      C:\WINDOWS\system32\WpdShext.dll
      2006-10-18 21:47 259072
      C:\WINDOWS\system32\MPG4DECD.dll
      C:\WINDOWS\system32\MP43DECD.dll
      2006-10-18 21:47 2450944 --a
      C:\WINDOWS\system32\wmvcore.dll
      2006-10-18 21:47 242688 --a
      C:\WINDOWS\system32\wmpasf.dll
      2006-10-18 21:47 229376 --a
      C:\WINDOWS\system32\cewmdm.dll
      2006-10-18 21:47 227328 --a
      C:\WINDOWS\system32\wmerror.dll
      2006-10-18 21:47 222208 --a
      C:\WINDOWS\system32\WMASF.dll
      2006-10-18 21:47 212992 --a
      C:\WINDOWS\system32\MFPLAT.dll
      2006-10-18 21:47 211456 --a
      C:\WINDOWS\system32\qasf.dll
      2006-10-18 21:47 204288 --a
      C:\WINDOWS\system32\wmpsrcwp.dll
      2006-10-18 21:47 199168
      C:\WINDOWS\system32\PortableDeviceWMDRM.dll
      2006-10-18 21:47 179712 --a
      C:\WINDOWS\system32\msnetobj.dll
      2006-10-18 21:47 175616 --a
      C:\WINDOWS\system32\mspmsp.dll
      2006-10-18 21:47 166912
      C:\WINDOWS\system32\PortableDeviceTypes.dll
      2006-10-18 21:47 1661440 --a
      C:\WINDOWS\system32\wmpencen.dll
      2006-10-18 21:47 1574912
      C:\WINDOWS\system32\WMVENCOD.dll
      2006-10-18 21:47 157184 --a
      C:\WINDOWS\system32\wmidx.dll
      2006-10-18 21:47 154624 --a
      C:\WINDOWS\system32\wpdmtp.dll
      2006-10-18 21:47 1543680
      C:\WINDOWS\system32\WMVDECOD.dll
      2006-10-18 21:47 1382912
      C:\WINDOWS\system32\WMVSDECD.dll
      2006-10-18 21:47 133632
      2006-10-18 21:47 1329152 --a
      C:\WINDOWS\system32\WMSPDMOE.dll
      2006-10-18 21:47 132096
      C:\WINDOWS\system32\PortableDeviceWiaCompat.dll
      2006-10-18 21:47 130048
      C:\WINDOWS\system32\wmpps.dll
      2006-10-18 21:47 11264 --a
      C:\WINDOWS\system32\LAPRXY.dll
      2006-10-18 21:47 1117696 --a
      C:\WINDOWS\system32\WMADMOE.dll
      2006-10-18 21:47 101888
      C:\WINDOWS\system32\PortableDeviceClassExtension.dll
      2006-10-18 20:03 100864 --a
      C:\WINDOWS\system32\logagent.exe
      2006-10-18 20:00 17408
      C:\WINDOWS\system32\wpdshextautoplay.exe
      2006-10-17 12:06 78336 --a
      C:\WINDOWS\system32\ieencode.dll
      2006-10-17 12:05 40960 --a
      C:\WINDOWS\system32\licmgr10.dll
      2006-10-17 12:05 206336
      C:\WINDOWS\system32\WinFXDocObj.exe
      2006-10-17 12:05 105984 --a
      C:\WINDOWS\system32\url.dll
      2006-10-17 12:04 101376 --a
      C:\WINDOWS\system32\occache.dll
      2006-10-17 12:03 17408 --a
      C:\WINDOWS\system32\corpol.dll
      2006-10-17 11:58 61952
      C:\WINDOWS\system32\icardie.dll
      2006-10-17 11:58 12288
      C:\WINDOWS\system32\msfeedssync.exe
      2006-10-17 11:57 36352 --a
      C:\WINDOWS\system32\imgutil.dll
      2006-10-17 11:57 266752
      C:\WINDOWS\system32\iertutil.dll
      2006-10-17 11:56 45568 --a
      C:\WINDOWS\system32\mshta.exe
      2006-10-17 11:28 48128 --a
      C:\WINDOWS\system32\mshtmler.dll
      2006-10-17 11:27 380928
      C:\WINDOWS\system32\ieapfltr.dll
      2006-10-13 04:35 65536 --a
      C:\WINDOWS\system32\nwwks.dll
      2006-10-13 04:35 64000 --a
      C:\WINDOWS\system32\nwapi32.dll
      2006-10-13 04:35 142336 --a
      C:\WINDOWS\system32\nwprovau.dll
      2006-10-09 16:12 456192 --a
      C:\WINDOWS\system32\encdec.dll
      2006-10-09 16:12 235008
      C:\WINDOWS\system32\psisdecd.dll
      (((((((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))
      *Note* empty entries are not shown
      [HKEY_CURRENT_USER\software\microsoft\windows\currentversion\run]
      "MSMSGS"="\"C:\\Program Files\\Messenger\\msmsgs.exe\" /background"
      "ctfmon.exe"="C:\\WINDOWS\\system32\\ctfmon.exe"
      "Yahoo! Pager"="C:\\Program Files\\Yahoo!\\Messenger\\ypager.exe -quiet"
      "DW4"="\"C:\\Program Files\\The Weather Channel FW\\Desktop Weather\\DesktopWeather.exe\""
      [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run]
      "ehTray"="C:\\WINDOWS\\ehome\\ehtray.exe"
      "High Definition Audio Property Page Shortcut"="HDAShCut.exe"
      "HotKeysCmds"="C:\\WINDOWS\\system32\\hkcmd.exe"
      "Persistence"="C:\\WINDOWS\\system32\\igfxpers.exe"
      "HPHUPD08"="c:\\Program Files\\HP\\Digital Imaging\\{33D6CC28-9F75-4d1b-A11D-98895B3A3729}\\hphupd08.exe"
      "PCDrProfiler"=""
      "HPBootOp"="\"C:\\Program Files\\Hewlett-Packard\\HP Boot Optimizer\\HPBootOp.exe\" /run"
      "SMSERIAL"="sm56hlpr.exe"
      "LSBWatcher"="c:\\hp\\drivers\\hplsbwatcher\\lsburnwatcher.exe"
      "HP Software Update"="C:\\Program Files\\HP\\HP Software Update\\HPWuSchd2.exe"
      "TkBellExe"="\"C:\\Program Files\\Common Files\\Real\\Update_OB\\realsched.exe\" -osboot"
      "Adobe Photo Downloader"="\"C:\\Program Files\\Adobe\\Photoshop Album Starter Edition\\3.0\\Apps\\apdproxy.exe\""
      "HPDJ Taskbar Utility"="C:\\WINDOWS\\system32\\spool\\drivers\\w32x86\\3\\hpztsb07.exe"
      "HPHmon04"="C:\\WINDOWS\\system32\\hphmon04.exe"
      "HPHUPD04"="\"C:\\Program Files\\HP Photosmart 11\\hphinstall\\UniPatch\\hphupd04.exe\""
      "MaxtorOneTouch"="C:\\PROGRA~1\\Maxtor\\OneTouch\\Utils\\OneTouch.exe"
      "MXO Auto Loader"="C:\\WINDOWS\\MXOALDR.EXE"
      "iTunesHelper"="\"C:\\Program Files\\iTunes\\iTunesHelper.exe\""
      "QuickTime Task"="\"C:\\Program Files\\QuickTime\\qttask.exe\" -atboottime"
      "ccApp"="\"C:\\Program Files\\Common Files\\Symantec Shared\\ccApp.exe\""
      "osCheck"="\"C:\\Program Files\\Norton Internet Security\\osCheck.exe\""
      "SunJavaUpdateSched"="\"C:\\Program Files\\Java\\jre1.6.0\\bin\\jusched.exe\""
      [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run\OptionalComponents]
      [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run\OptionalComponents\IMAIL]
      "Installed"="1"
      [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run\OptionalComponents\MAPI]
      "Installed"="1"
      "NoChange"="1"
      [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run\OptionalComponents\MSFS]
      "Installed"="1"
      [HKEY_CURRENT_USER\software\microsoft\internet explorer\desktop\components]
      "DeskHtmlVersion"=dword:00000110
      "DeskHtmlMinorVersion"=dword:00000005
      "Settings"=dword:00000001
      "GeneralFlags"=dword:00000001
      [HKEY_CURRENT_USER\software\microsoft\internet explorer\desktop\components\0]
      "Source"="About:Home"
      "SubscribedURL"="About:Home"
      "FriendlyName"="My Current Home Page"
      "Flags"=dword:00000002
      "Position"=hex:2c,00,00,00,00,01,00,00,00,00,00,00,00,04,00,00,a2,03,00,00,00,\
      00,00,00,01,00,00,00,01,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00
      "CurrentState"=hex:04,00,00,40
      "OriginalStateInfo"=hex:18,00,00,00,ff,ff,00,00,ff,ff,00,00,ff,ff,ff,ff,ff,ff,\
      ff,ff,04,00,00,00
      "RestoredStateInfo"=hex:18,00,00,00,6a,02,00,00,23,00,00,00,a4,00,00,00,9a,00,\
      00,00,01,00,00,00
      [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\sharedtaskscheduler]
      "{438755C2-A8BA-11D1-B96B-00A0C90312E1}"="Browseui preloader"
      "{8C7461EF-2B13-11d2-BE35-3078302C2030}"="Component Categories cache daemon"
      [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shellexecutehooks]
      "{AEB6717E-7E19-11d0-97EE-00C04FD91972}"=""
      "{57B86673-276A-48B2-BAE7-C6DBB3020EB8}"="AVG Anti-Spyware 7.5"
      [HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\explorer]
      "NoDriveTypeAutoRun"=dword:00000091
      "NoSaveSettings"=dword:00000000
      [HKEY_CURRENT_USER\software\microsoft\windows\currentversion\policies\explorer\Run]
      [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\policies\system]
      "dontdisplaylastusername"=dword:00000000
      "legalnoticecaption"=""
      "legalnoticetext"=""
      "shutdownwithoutlogon"=dword:00000001
      "undockwithoutlogon"=dword:00000001
      "InstallVisualStyle"=hex(2):43,3a,5c,57,49,4e,44,4f,57,53,5c,52,65,73,6f,75,72,\
      63,65,73,5c,54,68,65,6d,65,73,5c,52,6f,79,61,6c,65,5c,52,6f,79,61,6c,65,2e,\
      6d,73,73,74,79,6c,65,73,00
      "InstallTheme"=hex(2):43,3a,5c,57,49,4e,44,4f,57,53,5c,52,65,73,6f,75,72,63,65,\
      73,5c,54,68,65,6d,65,73,5c,52,6f,79,61,6c,65,2e,74,68,65,6d,65,00
      [HKEY_USERS\.default\software\microsoft\windows\currentversion\policies\explorer]
      [HKEY_USERS\s-1-5-18\software\microsoft\windows\currentversion\policies\explorer]
      [HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\shellserviceobjectdelayload]
      "PostBootReminder"="{7849596a-48ea-486e-8937-a2a3009f31a9}"
      "CDBurn"="{fbeb8a05-beee-4442-804e-409d6c4515e9}"
      "WebCheck"="{E6FB5E20-DE35-11CF-9C87-00AA005127ED}"
      "SysTray"="{35CEC8A3-2BE6-11D2-8773-92E220524153}"
      "WPDShServiceObj"="{AAA288BA-9A4C-45B0-95D7-94D524869DB5}"
      [HKEY_LOCAL_MACHINE\system\currentcontrolset\control\securityproviders]
      "SecurityProviders"="msapsspc.dll, schannel.dll, digest.dll, msnsspc.dll"
      Contents of the 'Scheduled Tasks' folder
      C:\WINDOWS\tasks\Easy Internet Sign-up.job
      C:\WINDOWS\tasks\HP Usg Login.job
      C:\WINDOWS\tasks\Norton Internet Security - Run Full System Scan - HP_Administrator.job
      Completion time: 07-01-04 8:57:25.70
      C:\ComboFix.txt ... 07-01-04 08:57
      Thanks
      RdRash
      edited January 2007
      Only one file to delete.
      Next, open Killbox
      In the Full Path of File to Delete box, press Ctrl+V and the eitcucnk.dll file should show.
      Select Single File
      Let me know if that helps.
      Hi Trogan
      I got a email message indicating an update but it doesn't appear in the web thread. Can you repost since all the information didn't come across in the email thread, especially the quote box portion.
      Here is what was included in the email:
      Here is the message that has just been posted:
      Next, open Killbox
      Select Single File
      Now click on the Red Circle with the White X Press Yes to reboot your computer.
      Thanks
      RdRash
      edited January 2007
      The email shows my last post. Do you see my post above yours?
      Hi Trogan
      OK now it shows up in the thread. Looks like the post number is different so don't know if that caused the issue.
      I'll do this when I get home this evening.
      Thanks
      RdRash
      Hi Trogan
      I have captured a screen shot of the "Server Busy" Window message box but I do not know how to post it to this thread (copy/paste doesn't work for this). Can you tell me how I can post the screen capture?
      I used Killbox to remove C:\WINDOWS\system32\eitcucnk.dll
      But unfortunately the "Server Busy" message box still appears.
      Below is are new logs from Combofix and HJT in normal boot mode.
      HP_Administrator - 07-01-04 23:27:55.07 Service Pack 2
      C:\!KillBox
      C:\WINDOWS\BDOSCAN8
      C:\VundoFix Backups
      C:\WINDOWS\pss
      2007-01-04 22:48
      d
      2007-01-03 07:29
      d
      2007-01-03 07:29
      d
      2007-01-02 20:23
      2007-01-01 20:08
      d
      2007-01-01 06:28
      d
      2007-01-01 06:25
      d
      2007-01-01 06:20
      d
      2007-01-01 06:19
      d
      2007-01-01 06:18
      d
      2007-01-01 06:14
      d
      2007-01-01 06:12
      d-a
      2007-01-01 06:12
      d
      2006-12-31 21:43
      d
      2006-12-17 16:22
      d
      2006-12-14 06:49
      d
      2006-12-14 06:49
      d
      2006-12-04 20:42
      d
      2006-11-20 21:32
      d
      "PCDrProfiler"=""
      "Installed"="1"
      "Installed"="1"
      "NoChange"="1"
      "Installed"="1"
      ff,ff,04,00,00,00
      00,00,01,00,00,00
      Completion time: 07-01-04 23:30:32.31
      C:\ComboFix.txt ... 07-01-04 23:30
      C:\ComboFix2.txt ... 07-01-04 08:57
      Scan saved at 12:02:40 AM, on 1/5/2007
      Running processes:
      C:\HP\KBD\KBD.EXE
      C:\Program Files\Microsoft Office\OFFICE11\WINWORD.EXE
      O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\ssv.dll
      O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0\bin\ssv.dll
      Thanks
      RdRash
      edited January 2007
      Click New Reply and scroll down to Manage Attachments. You should be able to upload the image. :)
      HI Trogan
      Alright I see where I was being stupid :doh: , I just used the message box below the thread typed in my responses then click on a quick post, didn't click on New Reply.
      Here is a Word file with the screen shots plus some of the processes running
      Thanks
      RdRash
      edited January 2007
      Hmm...I don't think that malware would cause that error. You could try the General Hardware forum and see what suggestions you get.
      Hi Trogan,
      OK that sounds good. I'll try the General Hardware forum to see what they might think of.
      My PC seems to be clean of malware and running fine thanks to all of your assistance and Pterocarpous's assistance.
      Thanks very much to both of you I couldn't have done it without your help.
      RdRash
      edited January 2007
      You're welcome and good luck! :)
