noob question - case cooling fan?
so I've just bought a new PSU with intelligent cooling to power my pair of new SATA HDDs. This is great, but my case has a small 8cm fan which is really noisy. question is ... do I really need the case cooling fan at all?
The graphics card has it's own fan. The AMD Athlon CPU has it's own heat sink and fan. The PSU fan turns on when the system is getting hot and cools the whole case, right???? what am I missing.
If the fan is noisy, it may be failing anyway. How much cooling your computer needs is dependent upon a no. of factors.
What size is your case?
What wattage is your PSU?
What speed processor are you running?
Where is the case fan located?
Is it the only case fan?
What devices are installed inside your computer?
thanks for the welcome. I've got a regular size case with ATX ECS Socket 754 Mobo with AMD Athlon 64 processor with heatsink and fan. AGP graphics card with own mini fan. new PSU is 600W with intelligent cooling 120mm fan. Only hot thing in the case is a stack of 4 HDDs (2x80GB maxtors and 2x320GB Seagates) all 7200rpm. I suppose I am worried that the case fan is just interfering with all the other fans.... I've left a gap next to the graphics card to help it out based on some suff I read. can't I just let the PSU fan pull air over the Mobo through the case? case cooling fan slot is at the back (80mm size).
Two $10 fans... or
$100+ for a new motherboard...
Removing warm air from a chip is one thing but removing it from the case completes the whole cycle. Monitor your systems temperature with and without the fan and that should tell the story.
I'd buy a quiet fan from newegg and be done with it. I tend to go with high cfm/low dba. Evercool comes to mind right off hand but aerocool and other brands fit that category.
Something else you might want to consider (instead of the mounting brackets) is putting a removable hard drive rack in the 5.25" bay. (Get one that has a fan mounted in the back and a case that is constructed of aluminum for maximum heat dissipation.) I use VANTEC SATA and ATA removable hard drive racks and have been happy w/ them. They have displays on the front that include the temperature inside the drawer (in F or C) and other readings as well. They're really great for easy installation and removal of HDDs. I use them for troubleshooting, backing up, and imaging HDDs.
Yes. Cyberguys has those adapters: http://www.cyberguys.com/
http://www.startech.com/Product/ItemDetail.aspx?productid=FANDRIVE2&c=UK
which also improve the case cooling flow no doubt. I've mounted my two new SATA HDDs in these, so they are nice and cool. I've spread out the other two HDDs in the original HDD rack and using speedfan they seem to stay below 40 deg C, which, having done some reading seems OK. The core temp is also below 40 with the fan running, so altogether, things seem sorted.
ps. I also bought a new rear fan too, thanks to all your advice.
