Possible Problem with RAID
It seems that i have some sort of problem. When Norton AV was doing a virus scan this morning, the computer restarted. When I went and looked at the log, it said the decomposition engine had an error trying to open several archives. I should note that I can open the specified files and even are fine after testing the archive with WinRAR.
I also got a few of these errors:
Event Type: Error
Event Source: hpt3xx
Event Category: None
Event ID: 9
Date: 01/21/2007
Time: 12:22:26 PM
User: N/A
Computer: DANBALL1976
Description:
The device, \Device\Scsi\hpt3xx1, did not respond within the timeout period.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 00 00 10 00 01 00 66 00 ......f.
0008: 00 00 00 00 09 00 04 c0 .......À
0010: 01 01 00 50 00 00 00 00 ...P....
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
0028: 00 00 00 00 00 00 00 00 ........
0030: 00 00 00 00 07 00 00 00 ........
AND
Event Type: Warning
Event Source: Disk
Event ID: 51
Date: 01/21/2007
Time: 12:22:26 PM
User: N/A
Description:
An error was detected on device \Device\Harddisk1\D during a paging operation.
Data:
0000: 03 00 68 00 01 00 b6 00 ..h...¶.
0008: 00 00 00 00 33 00 04 80 ....3..€
0010: 2d 01 00 00 00 00 00 00 -.......
0028: dc b1 0f 00 00 00 00 00 ܱ......
0030: ff ff ff ff 03 00 00 00 ÿÿÿÿ....
0038: 40 00 00 0e 00 01 00 00 @.......
0048: 00 80 00 00 0a 00 00 00 .€......
0050: 00 00 00 00 c0 63 c9 86 ....ÀcɆ
0058: 00 00 00 00 d0 36 d1 86 ....Ð6ц
0060: 80 25 34 87 91 27 a5 00 €%4‡‘'¥.
0068: 28 00 00 a5 27 91 00 00 (..¥'‘..
0070: 40 00 00 00 00 00 00 00 @.......
0078: 00 00 00 00 00 00 00 00 ........
0080: 00 00 00 00 00 00 00 00 ........
0088: 00 00 00 00 00 00 00 00 ........
When I went to do scandisk during boottime to automatically fix errors, It got to 12%, stayed there for a few minutes, and then said "An unspecified error has occured", stated sometime about a file or cluster number and said that there was insufficient disk space to recover file clusters, even after I had moved around 40GB and burned 22GB of stuff so that there was 98GB of free space. Also, after Windows terminates the scan and goes into Windows, the RAID 0 array is offline, and I need to restart to get it back online. Both disks are Maxtor 120GB 7200RPM, 8MB drives that are about 3 years old.
Also, in the HPT372 BIOS, primary master is listed as hidden and the secondary master as Boot. Should I remove the boot flag from the secondary master and let it just list as HDD0?
Event Type: Error
Event ID: 9
Date: 01/21/2007
Time: 12:22:26 PM
User: N/A
Description:
Data:
AND
Event Type: Warning
Event Source: Disk
Event ID: 51
Date: 01/21/2007
Time: 12:22:26 PM
User: N/A
Description:
Data:
