Need help. Will not post
I'm helping my friend build a computer but after I set everything up it either freezes at the first page or freezes in bios within 30 seconds or less. Does anyone have any idea what might be the problem? Any help would be great, thanks.
Specs (in case you were wondering):
thermaltake tr2 500w
abit at8 32x socket 939
san diego 3700+
sapphire x1600pro
sony 16x dvd-rom
corsair value select 1gb (2x512)
san diego 3700+
sapphire x1600pro
sony 16x dvd-rom
Hi xxkkangxx
You've probably seen us make this recommendations to others....
The high pitched sound may be emanating from your power supply. Do you have another PSU you can use?
I recommend you swap out the PSU b4 proceeding at this point.
I replaced the PSU with a really old PSU that I used in a comp around 4-5 years ago. I have it in bios right now(for the past 10 minutes) and there hasn't been any freeze ups or anything of that kind yet. Though the first 2 times I booted it up and had it in bios it shut down in a minute or so. Should I connect the mobo to the new PSU that I was using earlier just to check? Thanks for the help.
- I don't trust your new PSU because of the whining sound you were hearing.
- That sound is characteristic of a failing PSU.
- It could potentially cause further damage.
- At the very least, if it is in fact failing, it's output is very likely noisy (not clean) and possibly out of tolerance which will cause your computer to behave unpredictably.
- If your current PSU works properly and supplies sufficient load capacity, I'd stay w/ it for now.
You're certainly welcome! :smiles:EDIT
I think i've had it on for close to 10 minutes. No problems or unusual activity. Should I leave it on for longer?
- I would, yes.
- ONLY if you're in the same room w/ it, though.
- The issue could be heat-related in which case it would need time to heat up b4 starting to fail (or make that noise again).
- The HDD should provide it w/ sufficient load.
- Just leave it running while you're working w/ the rest of the computer (in the SAME room).
How's that going, BTW? (working w/ the motherboard, etc. out of the case.)EDIT://
Btw, this has only happened once or twice, but sometimes it goes to a black page where it has the name of the BIOS at the top. The first line after that says cannot detect keyboard? And then it says searching for A: then says it failed to find A drive. Thanks again.
EDIT://
I re-read the thread and I see that you have the motherboard out of the case, etc. and that you've no on-board video so you're having to use a video adapter.
Is this a high end video adapter? (one that will require a lot of horse power to run?) It should be OK, I think as long as you're not revving it up.
Just in case, though, how many watts is that old PSU you have plugged in?
Please, go HERE and download BartPE 3.1.10a EDIT: Please, skip this recommendation. See post # 16 instead.
Create a boot-able CD w/ the ISO image file.
If you don't have a utility to create boot-able CDs from an ISO file, please, go HERE and download BurnCDCC - a free ISO utility.
lol I didn't know because I didn't bother to check earlier but the psu is 250w.
I'll get on the BartPE.
Might want to go ahead and install the newer higher wattage PSU.
Keep an eye on it w/ frequent checks in the BIOS of the voltage levels, though.
(BTW, if you need help w/ any of these steps just let us know, ok?)
Instead, please, download UBCD (Ultimate Boot CD) and create a bootable CD w/ it.
You'll need to create a boot-able CD w/ it as well.
