Vapor Phase Cooling Question!!
HEY GUYS!!! I haven't written anything in awhile...missed y'all!
I am SERIOUSLY looking into using the Asetek VapoChill Lightspeed Vapor cooling system on a computer that I hope to build in the next year. (Of course AMD hasn't released it yet, but it will be a Quad-Core AMD system...along with Quad-Core/SLI Nvidia BFG OC 8800GTX's).
What I'm dying to learn about, is whether I can cool multiple components using Phase Cooling with a single compressor unit...and if so...would it be difficult to do it with the Asetek solution I mentioned above? Or...if there's something completely different that I should look into? I've looked around, and haven't even found any commercially available evaporator blocks even designed for a GPU. In the end, I want the entire system including CPU, GPU, and perhaps memory/motherboard Chipset, to be Vapor Phase Cooled. Any ideas??
(And I'm NOT handy enough to build something on my own from scratch...)
Thanks guys!
Thanks guys!
Are two of these Asetek units required in order to cool two cpu's I wonder?
Thanks!
Howdy G4,
If you want four cores, it's probably cheaper, faster, and easier to go for a single quad-core Intel processor. That way you only have to cool one chip.
It may change, but right now, Intel is spanking the pants off AMD with its Core 2 series chips.
We'll see what happens later this month with AMD's mega-release. If nothing else I bet the AMD quads will be comprable performance, but with less heat & better per watt performance (altho deep down I hope they rock the socks off the Core 2 in all possible ways)
/self admitted AMD fanboy
Now that would be impressive.
Man, if that's the case, I can't WAAAIIIT for AMD's release here in a few weeks. (Of course, I dunno why...it's not like I'll be building this system anytime this month, rofl). I guess I Just can't wait to see some benchies, and reviews!
Of course, I think I've pretty much decided that my platform will be a Vapochilled Quad-Core AMD on an NForce chipset, with the GPU/Chipset/Memory water-cooled. mwa-haha! Not to mention the BGF (Do I wanna do this, because of the performance, or just to show off the neat cooling technologies???)
The AMD TDP sounds nice, and its 27% better than kentsfields 130W (CPU speed not considered), which is great
Asetek VapoChill LS on a quad kentsfield. Every forum i checked or posted on said what everyone above stated. QX6700 or QX6600 produce too much heat when trying for a decent overclock.
My new plan, eventually, will be to use the LS with a E6600. Less heat, more overclocking possibilities. Can't say what it will do for any future AMD proc's though.
