For some reason I went to boot up my comp and nothing will show up on the monitor. Monitor is plugged into power and vid card. Any ideas? Is the vid card shot? Any suggestions? Thank you a ton!
Card is a Radeon 9500 Pro
Windows XP
P4 2.4GHz
1GB Ram
> trash
EDIT: Avs you could just take it out and reseat it. That's always worth a shot with cards. But what you've done does narrow it right down to that.
Reseat it as in take it out and put it back in? If so, i tried that and it didn't work.
