KG7 and RAM problem. A little help please.
Bought two new 256 mb sticks of crucial 2100 to match the two sticks I already had to bring me up to a gig of ram. The only thing is that the two new sticks are single sided and the two older are double sided. Didn't realize the diff when purchased online.
They are the same model # and timing (2.5) just one's denser. When installed the comp beeps one beep about every three seconds and hangs on a black screen at boot. Reseated, changed slots with original two, no change.
Two old sticks are: CT3264Z265.16T CL2.5
Two new sticks: CT3264Z265.8LT3 CL2.5
Both kinds are Crucial brand name 266 mhz 2100 ddr modules.
The manual made no distinction between using single or double sided together on the Abit KG7. Right now I have the two new sticks in the rig I'm typing this on without any problems so far. I bought two new sticks to BOOST my memory, not replace it.
Any suggestions out there?
Thanks, MGK
Thanks, MGK
Any comments on that fellas? I'm too stupid to figure it out.
MGK
Unfortunately, I don't remember the exact steps I took to get it that way. If it's any help, my configuration looks like this:
Chipset Driving Control = All AUTO
Super Bypass Mode = Enabled
Super Bypass Wait State = 0 Cycle
SDRAM Timing = All AUTO
I'd let memtest run all the way through at least once; overnight would be even better.
Finally, random reboots might be a PSU problem. Do you have a good spare you could try?
No, I don't have a spare. Maybe I'll try rearranging the sticks in pairs and reseating firmly.
It's not actually bsod, my monitor just goes black and states 'computer will restart in ten seconds' or something like that. I've never seen that before.
Do you know how should I enable the bios settings to see the ECC registered ram sticks in addition to those you gave me?
THANKS, MGK
If you're getting a shutdown message then it's not the PSU.
Shuffling the sticks is a good idea.
One other quirk I remembered is that many of my problems went away when I enabled the onboard Highpoint Controller - even though there were no drives attached to it - and used the WinXP default driver for it.
Thanks, MGK
