HELP!..problem with sound & audio devices (volume control icon)
hi guys
i have discovered that the "volume control icon" in the taskbar is not active !! and it doesn't appear !
i opened "sound and audio devices" in control panel and it says that there is no audio device !! however iam using a Genius speakers and its working and when i play something on realplayer it works but any audio comes from a video at any site or a sound from a program it doesn't work:sad2:
look at the picture, you can notice that there is no icon....
so please help me solving this problem
iam too sad of this,, 0
but would you please tell me how to reinstall the audio device ?
however i dont have an audio card separated , it comes with the motherbored like the keybored in.
iam waiting your reply
my computer is not a brand with no name
its just collected parts, and i don't know the brand name of the motherboard so help me find its name, because the audio card is built-in .
any additional informations iam ready
waiting ya,,
unfortunately i didn't find "integrated audio" in device manager but i took a screen print of the device manager please check it and tell me the results,,
Adarry, i have mintioned that i don't know my motherbored name and i don't have a CD for it coz my pc is acually old. IS THERE A WAY TO KNOW ITS NAME ? & FROM WHERE I CAN GET THE AUDIO DRIVER? ofcourse after you tell me how i can reinstall it
hopping u'll reply soon
i finally solved the problem :d
it was so easy i only go to the control panel then to sounds and audio devices properties and i choosed a same defualt device for all options in "audio,voice&sound tabs" then a applied the changed and the icon appeared and the problem solved :d
thanx for everyone adarry and jokke for trying to help me and giving me little of ur time
bye and thank you
