Two switches, same problem...
Tell me if this makes sense, there is a switch which was giving us some problems... basically every hour or so we would be unable to ping anything behind it, power cycling it and only it worked each time in bringing it back up. So we replaced the switch, same exact issue occurred?
What do you think?
What do you think?
If the switch was replaced with an equivalent model/capacity switch (or smaller) then it sounds like at some point the switch is overloaded.
Are you running the spanning tree protocol? Try disabling it or checking if its configured correctly?
And this is an admin switch... plugged into the internet gateway which has multiple public IP's which is handed out to various equipment including our server.
