Power LED connector doesn't fit motherboard
I have an ECS K7S5A motherboard and the leads for the power led connector isn't designed for the way my case's led connector was shipped. Is there any way to modify the led connector? I have attached a pic below. Notice how the wires are at the edges. The connector has 3 holes, but 2 are being used. The one in the middle is left unused. Can I move one of the connectors to the middle?
What do I do? I use a sharp scissor or exacto knife to cut the connector in half and then shave the excess plastic on each half to make it look like a single one so they'll fit properly.
anything... a file, course sand paper, dremel bit, and exacto knife... etc
Just don't cut the wire and you'll be fine.
take a thin item, yet stiff, like a needle, and hold the connector, the side with the 3 plastic flaps in front of you, pry the flap of the wire you want to move, untill it is bent to a 90 angle. now, you can simply pull the wire out, and push it into the middle hole.
NS
Sometimes, next to the PWR LED there is something else so you cannot use a 3 wire connector.
A little tip for keeping all the headers in the same position is to fit them, then use a securey tie thing around them as close to the plastic as possible. This makes it easier when installing a new mobo, or if you ever take them out.
OR
You can snag any two pin connector from an old PC or a friends old PC and swap the three for the two.
NS
Technically the black connector surrounding is not required if you have some 1\8" or 3\16" milspec heatshrink tube from Home Depot around and a cigarette lighter. I suppose you could even take some 1\4 heatshrink and join the two, but usually do not bother. Knowing that fix should help if one does botch the cut in any way and wants a nice neat look.
For my own machines I do not bother making it super neat(just safe and efficient air flow), for others who have windowed boxes all is hyper-tidy.
Even my 3M electrical tape keeps wanting to unravel a bit, so I use heatshrink tube.
John Danielson.
John Danielson.
