Nvidia/LCD Monitor Refresh Rate Problem
I recently received my new Sceptre X9G Komodo II from newegg.
The monitor is listed as 75hz on both the website and documentation that came with the monitor. I'm using Windows XP and when I go to the monitor tab in display setting 60hz is the only option and the "Hide modes that cannot be displayed" box is grayed out. I'm using the latest whql detonator drivers from Nvidia's website. I've tried several Nvidia refresh rate fix programs and they don't work. I've gone into the Nvidia display settings and set all the direct 3d refresh rates to 75hz already, I'd really like to be able to set windows to 75 as well. Anyone know a fix for this.
Q: What does "refresh rate" mean to me in an LCD monitor?
A: For LCD monitors, the refresh rate is much less relevant. LCD monitors display a stable, flicker-free image at 60Hz. There are no visible differences between 85Hz and 60Hz.
Q: What does Refresh Rate mean for LCDs?
A: Unlike CRT display technology in which the speed the electron beam is swept from the top to the bottom of the screen determines flicker, an active matrix display uses an active element (TFT) to control each individual pixel and thus refresh rate is not really applicable to LCD technology.
As for you experiencing less ghosting, are you comparing two exact same things from before and after? Response time is the main factor when it comes to ghosting, not refresh rate.
I'm having this same exact problem with my Sceptre x9g-Gamer LCD monitor. It is definitely supposed to support 75hz in its native resolution, and I can't find any way to do it. The company's own drivers don't give it support for anything above 60hz. I even double checked the manual, and it confirmed that they RECOMMEND you run it at 75hz. I'll keep looking into it. I don't think I trust that program that forces it into 75hz though...
The Display properties don't show anything other than 60hz, even when I select "show refresh rates not supported by this monitor". Anyone know a safe way to get Sceptre monitors to work correctly? I have an Nvidia card too. GF4 6600 Ti.
- Sega
Old, but unfortunately still relevant. Sceptre hasn't answered my email, and I can't seem to find many threads anywhere about Sceptre LCDs. Here I find one, and it is the same exact problem I'm having. I forced it to 75hz with the Nvidia program, and it only pretended to do it. I checked the hardware menu on the monitor, and it still said it was at 60hz. I believe the X9G-Gamer is considered one of the Kodomo series, but I'm not sure. Kodomo is an X9G.
- Sega
My system:
AMD Athlon 64 3500+
ASUS A8N-SLI Deluxe with 4x512MB Kingston DDR-400 PC3200 RAM
ATI AIW X600 Pro with 256MB RAM - PCI Express
19" Sceptre Gamer (12ms video response) using the supplied DVI cable
MS Windows XP Media Edition 2005.
I bought this monitor hoping that the high video response and advertised 75 Hz refresh rate would give us pain-free computing, but the OSD info never varies from 60 Hz, though I can get a "-/-" instead of "+/+" when I try 1024x768 resolution.
Has anyone out there truly been able to get a 75 Hz refresh rate? Check your OSD info and the FPD Attributes under Displays.
Thanks for any help.
wyntrout
