floppy drive problem - help
hie guys, i just bought a new comp. but seem to have problems with the floppy drive. the drive is installed correctly, and i double-checked it (following the red line). the drive lights up when booting into windows xp but when i insert a diskette (any diskette), win explorer either asks me to format the diskette or "please insert disk..". ive checked in the bios and dont seem to find any problems there.. am i missing something here? hope yu can me out.. thanks.
there are several things u could try.
have u tried a diff floppy disk?
changed cables?
have u checked if the floppy is enabled in the bios.
I have windows Xp home and when I put a floppy disk into the drive it states that the door is open and I need to shut the door i thought it was always open when the disk is in ? this is what pops up in a box / window
The drive is not ready for use; its door may be open . Please check drive A :and make sure that disk is inserted and that the drive door is closed. then it has three buttons Cancel try again continue. What can I do ?
Thank for your Help!
