Abit NF7-S: FPIO2 headers - can they work with normal front connectors on ATX cases?
JLamyJLamy UK
edited January 2004 in Hardware
I was wondering if the ABit NF7-S mobo's FPIO2 headers would be compatible with the connectors from any PC case that has Front Panel connectors. In the manual it states that these headers are designed for use with ABit Media XP product. Am also lookin for Aluminium case, all recommedations appreciated. Thanks in advance.
  • stoopidstoopid Albany, NY New
    edited December 2003
    I looked at the PIN configuration for that header here (page 3-14). You'll need to manually lineup/match the case's PINs with the manual's definitions.
  • JLamyJLamy UK
    Well this set of headers are more to do with the audio connectors. I seen most ATX cases come with header pins to connect to motherboard, while some others have standard 3.5cm jack pass thru (which is much easier).
  • ktdragonktdragon Denver
    I just purchased the Abit AN-7 Socket A motherboard.
    With the 400mhz(FSB) There's plenty of room for
    upgrades. Right now im using the Barton 2500+
    processor. I noticed that it's a fairly new board not
    having very many reviews on the net. I decided to
    stay with Abit instead of Asus over the bios features.
    Other than that both boards are almost the same.
    Anyway i just wanted some advice on what Brand
    of Dual 400mhz Memory to install.
    And let me know what you think about the Abit AN-7.
    I paid $116.00 @ Directron.com
    Full Tower Case w/side window/Led's
    Antec 430watt power supply
    Abit AN-7 Socket A mobo/400fsb/dual400mhz memory
    Memory ???????
    2 Maxter 80gb. / 7200rpm/ata-133 Harddrives
    PNY GeForce FX5200/128mbDDR Video Card
    Zalman 7000a CPU cooling fan
    Super Flower Fan Master controller
    19"MV920 Compaq monitor w/ 17"second monitor.
  • ZuntarZuntar North Carolina Icrontian
    edited January 2004
    Bump on this thread, cuz Im very interested in either the Abit AN-7 or the NF7-S for my next upgrade.
    ktdragon, What do you think about the AN-7 since you've had it a little while?
  • EQuitoEQuito SoCal, USA
    edited January 2004
    The AN7 failed to impress most users and the newer NF7's v2.0 do not OC as well as they used to.
    There are rumors of a new NF2 based board coming out soon so I'd wait a little longer.
    edited January 2004
    Hmmmmm.........:confused::cool:;)
