Help!!
heres the thing i got some sort of virus and then got rid of it. but it left me with a load of damaged software for my hardware and i can use the reload cd. so if anyone knows how to restore a windows xp home to factory settings without using the reload cd it would be a great help
thanks
thanks
Anyways, restoring XP to a 'default' state may prove troublesome. In Windows 2000 you could easily just swap the registry with the default-state backup reg and your PC would be good as new, but in XP I've always had troubles... and *especially* in XP Home *shudders*.
On a personal note. I really hate the fact now that you buy a system from dell/hp/etc.. and they say it comes with XP...What they really mean is it comes with a bundled version of XP that doesn't actually work on it's own.
I've installed Dell's bundled XP on another computer.
