Hey, is there a right and wrong kind of tubing and connector?
Just visited HomeDepot tonight and looked around whole store. In the pluming section I saw lots. Basically I was wondering what kind of tubing everyone uses and what should be used for best results, or doesn't it matter? The tubing types I saw were stainless steel reinforced (not clear), polyrilene (VERY HARD, not flexible, takes a lot to kink but kinks good once it starts), pvc reinforced (like steel web in cement) vinyl, regular vinyl (clearest and most flexible of the bunch. Should I just use vinyl or reinforced pvc vinyl? Also, is PSI a possible problem ever? These hoses were rated at between 40 and 50 psi max (labeled "low pressure only"). I think the brand of most of it was Watt.
Now second question, what type of fitting is best? There are barb type and compression type. I have never used compression type, but have used barb type. The barb type I have used is on garden hose replacement ends, I havn't had good leak proof luck with those, and I always sealed them and made them tight with metal clamps. Also, how do compression get put on? Do I just stick the hose in and screw it tight?
There are two types of compression fittings. One where you just stick the hose in. The other where you stick it in and screw it in. The best one is where you just stick it in. Since the screw in compression fittings restrict waterflow because their inside diameter is smaller!
The best tubing to get is ClearFlex or Tygon. Tygon is the elite - best! But it's also hella expensive (ClearFlex is almost as good and cheaper). Also ClearFlex or Tygon cannot be used with compression fittings. Though I think if you get a certain type of ClearFlex and a certain compression fitting they willl work together, just don't know which.
Most comfortable of all is the stick it in compression fitting. It never leaks if you use the right size of tubing for the right size of compression fitting.
Right now I'm using barb fittings, they are overally good but sometimes leak right after installation. If mine leak I just put some teflon tape on them, then put the tube on, and then use a ... umm I don't know how its called in english, but you can see it on my watercooling pictures, those things that you screw in on the barb to tighten up the tubing.
Here's a few pics,
Compression fitting - stick the hose in type:
http://mcs.pc.pl/sklep_img/SM12P_big.jpg
Compression fitting - stick it in and screw it in:
http://mcs.pc.pl/sklep_img/SM9-12P_big.jpg
Barb fitting:
http://mcs.pc.pl/sklep_img/NK12P_38_big.jpg
90 degree compression fitting - stick in type (very useful for GPU water blocks!):
http://mcs.pc.pl/sklep_img/zlaczki/WT12_kat_big.jpg
Those fittings on the images are made by an Italian producer called Camozzi - they are ultra high quality!
Thank you
What does the Clearflex and Tygon have that make it better? Just wondering because I don't like barb fittings and I want to know if they would make me change my mind.
Compression would almost never leaks, right?
Clearflex and Tygon don't *break* as easily as other tubing. Tygon is the best, because it's hard to *break* it. ClearFlex is almost as good as Tygon. Other tubing *breaks* much more easily.
The word you are looking for is "kink".
In three of the pics that you posted the fitting that you are referring to, in semiconductor manufacturing, is called a press-to-lock. They are great as a quick disconnect for air lines, but I wouldn't trust them in a computer because they can leak as they get older. They use a soft rubber to seal and are not good at high pressure.
A true compression fitting will crimp (squeeze) the tubing and form a seal at the chamfered (angled) face(also called a ferrule). This does not restrict waterflow because their inside diameter is smaller, because the inside diameter reduction is really minimal.
What I am saying is you are best to use compression fittings with rigid tubing such as most poly/vinyl types, or use hosebarbs with softer tubing like tygon. Tygon can be better in that it is softer and more flexible, it won't "kink" as easy. Both types will work fine, it is just preference and cost. Just make sure you use the right size tubing for whatever fitting you use, tighten the clamp or compression nut and you shouldn't have leaks.
Also, does anybody have any idea what the psi will be in the tubes if say, someone had a pump rated at 300-400gph?
But personall I'd go for ClearFlex and barb fittings
Eheim pump
Swiftech waterblock with 1/2 inch ID
Procore radiator or a Black Ice extreme (both have 1/2 inch ID fittings) + 120mm fan and a shroud
Ehem tubing, about 3 feet
A "T" fitting for the homemade "reservoir"
Threadtejp (or whatever you call it) The white silicon tejp that you use on the threads of the plumbing stuff
That's it. Can't get much better.
