Well... you could cause a catastrophic meltdown of the nuclear reactor, plummeting the world into a state of post-apocalyptic turmoil for the next thousand years.
Just check if the fan is disconnected from its power source or replace it It's easy as pie and you can pick one up at any local computer store... otherwise you may experience slowness / lock-ups.
Hahaha Vers, Nuclear meltdown.
neo, You can also experience total shutdown when the cpu overheats or burn up the cpu completely. And vers is right, easy to find in stores, easy to replace. Just a few screws or clips (depending on your system) and a plug that powers it. Make sure you get an adequate fan that will cool efficiently.
